查看: 938|回复: 7
[求助]:How can I view the DWG documents?
发表于 2002-11-25 00:02:46 | 显示全部楼层 |阅读模式
I just download some drafts, but they are all DWG style.Please give me some hint, thank you.
发表于 2002-11-25 00:06:00 | 显示全部楼层
Re: [求助]:How can I view the DWG documents?
最初由 xiaogengxu 发布
[B]I just download some drafts, but they are all DWG style.Please give me some hint, thank you. [/B]
MS 可以加载DWG图纸吧?
发表于 2002-11-25 00:07:40 | 显示全部楼层
不是很清楚你的问题
Microstation可以直接读写dwg,或者你也可以透过批次转档,转换成dgn格式
 楼主| 发表于 2002-11-25 00:19:13 | 显示全部楼层
*I'm sorry, I just misled your guys.I am supposed to put this topic in the DRAFT CENTRE, NOT MICROSTATION.
It's that I download the drafts whose file name is DWG, I don't know how to open it. Thanks
发表于 2002-11-25 00:28:38 | 显示全部楼层
最初由 xiaogengxu 发布
[B]*I'm sorry, I just misled your guys.I am supposed to put this topic in the DRAFT CENTRE, NOT MICROSTATION.
It's that I download the drafts whose file name is DWG, I don't know how to open it. Thank... [/B]
你好,朋友,先问问,你能看懂论坛上的中文吗?
DWG是AUTOCAD的软件图形格式,MS也可以打开它的。
 楼主| 发表于 2002-11-25 00:42:12 | 显示全部楼层
Hello, xdsoft,
Sorry to make you confused.
I can't type Chinese character because of the computer's problem.
Yet I can read the Chinese.
I don't know the DWG also is Autodesk's,
but I have Autocad 2002 in my computer, it doesn't work to open the DWG draft.Why is that.
By the way, I've learned a lot from yours.This website is awsome.
发表于 2002-11-27 22:47:28 | 显示全部楼层
如果是这个问题,建议到
※ AutoCAD 软件使用技术※
http://www.xdcad.net/forum/forumdisplay.php?s=&forumid=92
那里的autocad高手相当多,应该可以协助您
 楼主| 发表于 2002-11-28 23:10:23 | 显示全部楼层
God, I finally can open the drafts and all load documents.
It's that I use the computer in the university, probably it's been ddone som permisstion for the download function.This time, I download the documents on the softdisc.It's settled.
Thanks your guys and XD.Please terminate this topic.
GMT+8, 2026-11-22 10:33 , Processed in 0.314780 second(s), 22 queries , Gzip On, File On.
