查看: 2267|回复: 2
[原创]:将CAD图形DWG文件批量转成SLD幻灯片
发表于 2009-5-10 22:12:39 | 显示全部楼层 |阅读模式
[php]
(defun C:DWG2SLD (/ ACADOBJ DOC DWG_DIR DWG_LST NAME SDI)
  ;;By carrot1983
  (defun CJW-FILE-GET (MSG / WINSHELL SHFOLDER PATH CATCHIT)
    (setq WINSHELL (vlax-create-object "Shell.Application"))
    (setq
      SHFOLDER (vlax-invoke-method WINSHELL 'BROWSEFORFOLDER 0 MSG 1)
    (setq
      CATCHIT (vl-catch-all-apply
                '(lambda ()
                   (setq SHFOLDER (vlax-get-property SHFOLDER 'SELF))
                   (setq PATH (vlax-get-property SHFOLDER 'PATH))
    (if        (vl-catch-all-error-p CATCHIT)
      NIL
      PATH
  (princ
    "\n将CAD图形DWG文件批量转成幻灯片(DWGTOSLD) By carrot1983 2009-05-10"
  (setvar "CMDECHO" 0)
  (alert "\n注意: 备份原图!!!")
  (if (and (setq DWG_DIR (CJW-FILE-GET "选择DWG文件夹"))
           (setq DWG_LST (vl-directory-files DWG_DIR "*.DWG" 1))
    (progn
      (foreach DWG DWG_LST
        (if (setq SS (ssget "x"))
          (command "._ERASE" SS "")
        (setq DWG (strcat DWG_DIR "\\" DWG))
        (setq SLD (strcat DWG_DIR "\\" (vl-filename-base DWG) ".sld"))
        (command ".-INSERT" DWG "_NON" '(0. 0. 0.) "1" "1" "0")
        (command "._ZOOM" "_E")
        (command "._MSLIDE" SLD)
        (print SLD)
      (alert "程序完毕 <DWG2SLD>")
      (command "._BROWSER" "http://carrot1983.blog.sohu.com/")
  (princ)
[/php][
发表于 2009-5-11 15:14:27 | 显示全部楼层
非常不错,支持原创!
 楼主| 发表于 2009-5-13 13:22:39 | 显示全部楼层
用php代码贴出来有些问题。
上我博客。
http://carrot1983.blog.sohu.com/116108270.html
GMT+8, 2026-11-22 08:32 , Processed in 0.337825 second(s), 14 queries , Gzip On, File On.
