查看: 2397|回复: 11
[分享]:lisp程序(非常好用)
已领礼包: 6个
发表于 2004-5-30 17:16:25 | 显示全部楼层 |阅读模式
(defun c:cut ()
;;Please feel free to rename these commands as you desire.
(defun c:scb () (section t nil)); SECTION W/ BORDER
(defun c:sc () (section nil nil)); SECTION W/O BORDER
(defun c:scd () (section nil t)); DELETE INSIDE RECTANGLE
* * * * * ERROR ROUTINE * * * * *
(defun newerr (msg)
(prompt (strcat "\nSection cancelled: " msg)); PRINT ERROR
(setvar "cmdecho" cmd); RESET COMMAND ECHO
(setvar "highlight" hlt); RESET HIGHLIGHT
* * * * * MAIN FUNCTION * * * * *
;If the first argument has any value other than nil then the border will be left.  If it is nil
;then the border is erased.
;If the second argument is has any value other than nil then entities inside the border will be erased.
;If it is nil then entities outside the border are erase.
;For very large area drawings (maps or something), the DST variable may need to be changed.  If you
;find that not all entities are being trimmed properly try increasing the number higher than 1000.
(defun section (bdr n / olderr newerr cmd hlt p1 p2 p1x p1y p2x p2y p3 p4 dst plus minus p1a p2a p3a p4a lst)
(graphscr); CHANGE TO GRAPHICS SCREEN
(setq olderr *error* ; SET UP NEW
       *error* newerr ; ERROR ROUTINE
       cmd (getvar "cmdecho"); SAVE COMMAND ECHO SETTING
       hlt (getvar "highlight"); SAVE HIGHLIGHT SETTING
       p1 (getpoint "\nSelect first corner of rectangle: "); GET LL CORNER OF RECTANGLE
       p2 (getcorner p1 "\nSelect other corner: "); GET UR CORNER
       p1x (car p1)
       p1y (cadr p1)
       p2x (car p2)
       p2y (cadr p2)
       p3 (list p2x p1y); BUILD LR CORNER
       p4 (list p1x p2y); BUILD UL CORNER
       dst (/ (distance p1 p2) 1000.0); OFFSET FACTOR FOR TRIMMING
       plus (if n - +)
       minus (if n + -)
);END SETQ
(cond
  ((and (< p1x p2x) (< p1y p2y)); P1 IS LL CORNER
   (setq p1a (list (minus p1x dst) (minus p1y dst)); BUILD LL TRIM LINE POINT
         p2a (list (plus p2x dst) (plus p2y dst))); BUILD UR TRIM LINE POINT
  ((and (> p1x p2x) (< p1y p2y)); P1 IS UL CORNER
   (setq p1a (list (plus p1x dst) (minus p1y dst)); BUILD LL TRIM LINE POINT
         p2a (list (minus p2x dst) (plus p2y dst))); BUILD UR TRIM LINE POINT
  ((and (> p1x p2x) (> p1y p2y)); P1 IS UR CORNER
   (setq p1a (list (plus p1x dst) (plus p1y dst)); BUILD LL TRIM LINE POINT
         p2a (list (minus p2x dst) (minus p2y dst))); BUILD UR TRIM LINE POINT
  ((and (< p1x p2x) (> p1y p2y)); P1 IS LR CORNER
   (setq p1a (list (minus p1x dst) (plus p1y dst)); BUILD LL TRIM LINE POINT
         p2a (list (plus p2x dst) (minus p2y dst))); BUILD UR TRIM LINE POINT
); END COND
(setq p3a (list (car p2a) (cadr p1a)); BUILD LR TRIM LINE POINT
       p4a (list (car p1a) (cadr p2a)); BUILD UL TRIM LINE POINT
); END SETQ
(setvar "cmdecho" 0); TURN OFF COMMAND ECHO
(setvar "highlight" 0); TURN OFF HIGHLIGHT
(command "_.pline" p1 p3 p2 p4 "_c"); DRAW POLYLINE BORDER
(setq lst (entlast)); SAVE POLYLINE ENTITY NAME
(if n                                          ;ERASE ENTITIES
  (command "_.erase" "_w" p1 p2 "_r" lst "")    ;INSIDE RECTANGLE
  (command "_.erase" "_all" "_r" "_c" p1 p2 "") ;OUTSIDE RECTANGLE
); END IF
(command "_.trim" lst "" "_f" p1a p3a ""     ;TRIM ENTITIES AROUND BORDER
                          "_f" p3a p2a ""     ;DO TO THE FINICKY NATURE OF TRIMMING
                          "_f" p2a p4a ""     ;WITH THE FENCE OPTION, I HAVE USED FOUR
                          "_f" p4a p1a "" ""  ;FENCE LINES INSTEAD OF ONE LONG ONE
); END COMMAND
(if (not bdr) (entdel lst)); DELETE POLYLINE BORDER IF DESIRED
(setq *error* olderr); RESTORE ORIGINAL ERROR ROUTINE
(setvar "highlight" hlt); RESTORE HIGHLIGHT
(setvar "cmdecho" cmd); RESTORE COMMAND ECHO
(princ); EXIT CLEANLY
;;The following prompts are disabled when section.lsp is used with dialog box.
;(prompt "\nType SCB to create a section with a border.")
;(prompt "\nType SC to create a section without a border.")
;(prompt "\ntype SCD to delete entities inside rectangle.")
;(princ)
(defun cut_x ()
  (setq  C  0
        dcl_id (load_dialog "cut.dcl"))
  (if (not (new_dialog "cut" dcl_id))(exit))
    (action_tile "cut_outp" "(setq c 1)(done_dialog)")
    (action_tile "cut_out" "(setq c 2)(done_dialog)")
    (action_tile "cut_in" "(setq c 3)(done_dialog)")
    (action_tile "cancel" "(done_dialog)(exit)")
  (start_dialog)
  (unload_dialog dcl_id)
  (COND
       ((= C 1)(c:scb))
       ((= C 2)(c:sc))
       ((= C 3)(c:scd))
(princ)
(cut_x)
;;__________________________________________________________________
;;messages
(prompt "\nCut.LSP loaded - Type Cut to begin.")
(princ)
发表于 2004-5-31 09:32:03 | 显示全部楼层
是做什么用的,E文看不懂哈
发表于 2004-5-31 13:23:31 | 显示全部楼层
好像见过这个咚咚,似乎少了DCL文件。
发表于 2004-6-2 11:14:33 | 显示全部楼层
差东东!
发表于 2004-6-2 15:48:33 | 显示全部楼层
在下才输学浅看不懂,请楼主说明一下功用
发表于 2004-6-4 23:11:35 | 显示全部楼层
看不懂啊
发表于 2004-10-17 16:08:30 | 显示全部楼层
这程序是实现什么功能的,
发表于 2004-10-17 16:12:53 | 显示全部楼层
cut啥?讲讲明白。
发表于 2004-10-17 16:27:04 | 显示全部楼层
你这个程序是实现载剪功能,可没有说明文档,又没有DCL文件,但还是得谢谢你上传了一个好程序。
发表于 2004-10-19 11:01:07 | 显示全部楼层
看不懂哎
发表于 2004-10-21 16:09:34 | 显示全部楼层
有个说明就好了
发表于 2004-10-21 19:49:25 | 显示全部楼层
楼主,麻烦给个说明,或者是大家谁的e文好,给翻译一下也可以,代表所有e文不好的人先谢过了!
GMT+8, 2026-11-2 22:39 , Processed in 0.531155 second(s), 52 queries , Gzip On.
