查看: 1025|回复: 5
[求助]:怎样读取dxf代码、改变数值重新画图?
发表于 2004-6-7 16:14:13 | 显示全部楼层 |阅读模式
我想实现以下功能:事先用pline线画好一个任意四边形。然后想通过程序读取四个点坐标,改变坐标值,重新画图。谢谢大家指导!
*-*3 *-*4 *-*6
发表于 2004-6-8 13:41:51 | 显示全部楼层
找我啊。
发表于 2004-6-8 20:58:56 | 显示全部楼层
Coordinates Property
Specifies the coordinates for each vertex in the object.
See Also | Example
Signature
object.Coordinates
object
3DFace, 3DPolyline , Leader, LightweightPolyline, MLine, Point, PolyfaceMesh, PolygonMesh, Polyline, Solid, Trace
The object or objects this property applies to.
Coordinates
Variant (array of doubles); read-write
The array of points.
LightweightPolyline objects: The variant is an array of 2D points in OCS.
Polyline objects: The variant is an array of 3D points: the X and Y coordinates are in OCS; the Z coordinate is ignored.
All other objects: The variant is an array of 3D points in WCS.
Remarks
This property will replace any existing coordinates for the specified object. Use standard array-handling techniques to process the coordinates contained in this property.
You cannot change the number of coordinates in the object by using this property. You can change only the location of existing coordinates.
For the following objects, the Z coordinate will always default to 0 on the active UCS: 3DFace, Leader, MLine, PolyfaceMesh, and Trace.
3DPolyline , Polyline, PolygonMesh: For simple polylines (not splined or curve fit), this property specifies simple vertices. For splined or curve-fit polylines, this property specifies control point vertices.
When setting the coordinates for a polyline, if you supply fewer coordinates than the object currently possesses, the polyline will be truncated. Any fit points applying to the truncated vertices will also be truncated. If you supply more coordinates than the object currently possesses, the extra vertices will be appended to the polyline.
The OCS coordinates for the Polyline and LightweightPolyline objects can be converted to and from other coordinate systems using the TranslateCoordinates method.
 楼主| 发表于 2004-6-9 09:36:38 | 显示全部楼层
最初由 huangyanshi 发布
[B]找我啊。 [/B]
向你请教!
发表于 2006-3-24 23:11:25 | 显示全部楼层
让找你,人家找了你咋不说话了呢?
发表于 2006-4-7 16:53:38 | 显示全部楼层
AutoCAD VBA开发精彩实例教程
GMT+8, 2026-11-3 06:10 , Processed in 0.531479 second(s), 42 queries , Gzip On.
