查看: 993|回复: 4
[分享]:DWG文件按图层分解输出
发表于 2004-6-10 04:13:17 | 显示全部楼层 |阅读模式
将DWG中的每一个图层输出为一个单独的文件。
[PHP](defun c:tt ( / pa la-lst ss fn)
  (defun tablelist (s / d r)
    (while
      (setq d (tblnext s (null d)))
       (setq r (cons (cdr (assoc 2 d)) r))
  (setq pa (getfiled "文件输出到" "" "dwg" 1))
  (setq pa (substr pa 1 (- (strlen pa) 4)))
  (setq la-lst (tablelist "layer"))
  (foreach n la-lst
    (setq ss (ssget "x" (list (cons 8 n))))
    (if        ss
      (if (findfile (setq fn (strcat pa "_" n ".dwg")))
        (command "-wblock" fn "y" "" "0,0,0" ss "" "oops")
        (command "-wblock" fn "" "0,0,0" ss "" "oops")
)[/PHP]
发表于 2004-6-11 09:19:42 | 显示全部楼层
测试了一下,不错,能用也好用!
做了个附件,给像我一样不会LSP的网友!
命令:TT
已领礼包: 488个
发表于 2004-6-12 19:55:20 | 显示全部楼层
注意图层,不能为锁定
pickstyle要关上.
发表于 2004-6-14 00:14:27 | 显示全部楼层
Sub Wblockonlayer()
Dim Layer As AcadLayer
Dim i As Integer
Dim Layername As String
Dim Ftype(0) As Integer
Dim Fdata(0) As Variant
Dim sset As AcadSelectionSet
For i = 0 To ThisDrawing.SelectionSets.Count - 1
    ThisDrawing.SelectionSets.Item(i).Clear
    ThisDrawing.SelectionSets.Item(i).Delete
Next
Set sset = ThisDrawing.SelectionSets.Add("Layersel")
For i = 0 To ThisDrawing.Layers.Count - 1
    Layername = ThisDrawing.Layers.Item(i).Name
    Ftype(0) = 8
    Fdata(0) = Layername
sset.Select acSelectionSetAll, , , Ftype, Fdata
If sset.Count > 0 Then
ThisDrawing.Wblock "l:\" & Layername & ".dwg", sset
End If
Next
End Sub
发表于 2004-6-14 13:35:00 | 显示全部楼层
Command: tt Unknown command "-WBLOCK".  Press F1 for help.
Unknown command "D:\DOCUMENTS AND SETTINGS\裙房11.12-1_地下室轮廓.DWG".  Press F1 for help.
Unknown command "TT".  Press F1 for help.
Unknown command "0,0,0".  Press F1 for help.
<Selection set: 1>
Command: *Cancel
怎么都是出错?r14里能用吗?
GMT+8, 2026-11-4 23:53 , Processed in 1.249911 second(s), 41 queries , Gzip On.
