查看: 862|回复: 0
[编程申请]:对话框图像显示技术
发表于 2004-6-20 09:33:09 | 显示全部楼层 |阅读模式
这个函数该怎样写(cline_cir)
下面是天正代码
(defun c:getfont (/           check_in show_list              pop_c    pop_e
                  defaults do_edit  do_fontig              onff     w_c
                  slt           clist    elist    lstyle   cstyle   cstrhw
                  estyle   estrsh   estrsw   tstyle   tstrhw   tftn
                  tfchh           tfnof    tfdo     fn              lst      is_win
  (defun check_in (input format kk /)
    (if        (and (distof input 2) (> (atof input) 0))
      (progn (rs_error) input)
      (progn (set_tile "error" (strcat "无效的" format "输入"))
             (mode_tile kk 2)
             nil
  (defun show_list (k1 l1)
    (start_list k1)
    (mapcar 'add_list l1)
    (end_list)
  (defun pop_c (pos)
    (if        clist
      (progn (setq cstyle (nth (atoi pos) clist)) (do_fontig))
  (defun pop_e (pos)
    (if        elist
      (progn (setq estyle (nth (atoi pos) elist)) (do_fontig))
  (defun defaults (/ c lpth lfn l)
    (if        (and (not (and _lhz _lxw))
             (setq fn (open (strcat _prefix1 "fonts.dat") "r"))
             (setq _lhz        (read-line fn)
                   _lxw        (read-line fn)
      (setq _lhz (read _lhz)
            _lxw (read _lxw)
            _ltt (read-line fn)
            _ltt (if _ltt
                   (read _ltt)
    (if        fn
      (close fn)
    (if        (and _lhz _lxw)
      (setq cstyle (strcase (car _lhz))
            cstrhw (cadr _lhz)
            estyle (strcase (car _lxw))
            estrsh (cadr _lxw)
            estrsw (last _lxw)
      (setq cstyle "HZTXT"
            estyle "SIMPLEX"
            cstrhw 0.8
            estrsw 0.6
            estrsh 0.8
    (if        _ltt
      (setq tstyle (car _ltt)
            tstrhw (cadr _ltt)
            tfchh  (caddr _ltt)
            tftn   (last _ltt)
      (setq tstyle "宋体"
            tstrhw 0.8
            tfchh  nil
            tftn   nil
    (setq lpth (cons "" (getpfxl)))
    (foreach pth lpth
      (setq lfn (append (fdfiles (strcat (TgAddPathTail pth) "*.SHX") 4 T) lfn))
    (setq lfn (range1 lfn))
    (foreach ll        lfn
      (if (> (cadr ll) 1e5)
        (setq clist (cons (strcase (car ll)) clist))
        (setq elist (cons (strcase (car ll)) elist))
    (if        clist
      (progn (setq l         clist
                   clist (reverse clist)
                   c         (member cstyle l)
             (show_list "c_list" clist)
             (if (not c)
               (progn (setq tfnof  T
                            cstyle "HZTXT"
                            c           (member cstyle l)
                      (if (not c)
                        (setq cstyle (car clist)
                              c             (list cstyle)
             (set_tile "c_list" (itoa (1- (length c))))
    (if        elist
      (progn (setq l         elist
                   elist (reverse elist)
                   c         (member estyle l)
             (show_list "e_list" elist)
             (if (not c)
                            estyle "TXT"
                            c           (member estyle l)
                      (if (not c)
                        (setq estyle (car elist)
                              c             (list estyle)
             (set_tile "e_list" (itoa (1- (length c))))
    (if        tfnof
      (setq _lhz (list cstyle cstrhw)
            _lxw (list estyle estrsh estrsw)
            _ltt (list tstyle tstrhw tfchh tftn)
    (set_tile "cstr_hw" (rtos cstrhw 2 2))
    (set_tile "estr_sw" (rtos estrsw 2 2))
    (set_tile "estr_sh" (rtos estrsh 2 2))
    (set_tile "win_cad"
              (if tftn
                "1"
                "0"
    (set_tile "chht"
              (if tfchh
                "1"
                "0"
    (set_tile "ttype" tstyle)
    (do_fontig)
  (defun do_edit (n m / temp)
    (cond ((= n 1)
           (if (and (setq temp (check_in m "高宽比" "cstr_hw"))
                    (< 0.02 (atof temp) 50)
             (setq cstrhw (atof temp))
             (set_tile "error" "高宽比超出有效范围")
          ((= n 2)
           (if (and (setq temp (check_in m "字宽方向比例" "estr_sw"))
             (setq estrsw (atof temp))
             (set_tile "error" "字宽方向比例超出有效范围")
          ((= n 3)
           (if (and (setq temp (check_in m "字高方向比例" "estr_sh"))
             (setq estrsh (atof temp))
             (set_tile "error" "字高方向比例超出有效范围")
    (do_fontig)
  (defun do_fontig (/ stl p1 p2 p3 p4 p5 p6 p7 p8 ll plist)
    (if        (not
          (equal lst
                 (setq ll (list estrsh estrsw cstrhw estyle cstyle))
      (progn (setq lst         ll
                   ll         (rdshx "建筑" '(0 0) 1 cstrhw estyle cstyle)
                   plist (append '(nil "7")
                                 (cdr ll)
                                 (cdr (rdshx (If _is_v14
                                               "3.0"
                                               "1.8"
                                             (if ll
                                               (car ll)
                                               '(0 0)
                                             estrsh
                                             (/ (* estrsw cstrhw) estrsh)
                                             estyle
                                             cstyle
             (start_image "font_ig")
             (fill_image 0 0 winx winy -2)
             (foreach sublt (apply 'cline_cir plist)
               (apply 'vector_image sublt)
             (end_image)
  (defun onff (tf)
    (if        tf
      (progn (mode_tile "cstr_hw" 1)
             (mode_tile "c_list" 1)
             (mode_tile "estr_sw" 1)
             (mode_tile "estr_sh" 1)
             (mode_tile "e_list" 1)
             (mode_tile "ttype" 0)
             (mode_tile "select" 0)
             (setq is_win T)
             ;(setvar "TEXTSTYLE" "
      (progn (mode_tile "cstr_hw" 0)
             (mode_tile "c_list" 0)
             (mode_tile "estr_sw" 0)
             (mode_tile "estr_sh" 0)
             (mode_tile "e_list" 0)
             (mode_tile "ttype" 1)
             (mode_tile "select" 1)
             (setq is_win nil)
  (defun w_c (tf) (setq tftn (= tf "1")) (onff tftn))
  (defun slt (/ ll)
    (if        (setq ll (ttfont tstyle tstrhw))
      (setq tstyle (car ll)
            tstrhw (cadr ll)
  (if
    (and (not fnt_id)
         (< (setq fnt_id (load_dialog (strcat _prefix "getfont.dcl")))
            0
     (exit)
  (setq what_next 5)
  (if (not (new_dialog "getfont" fnt_id))
    (exit)
  (setq        winx (dimx_tile "font_ig")
        winy (dimy_tile "font_ig")
  (transws winx winy)
  (defaults)
  (onff tftn)
  (action_tile "cstr_hw" "(do_edit 1 $value)")
  (action_tile "estr_sw" "(do_edit 2 $value)")
  (action_tile "estr_sh" "(do_edit 3 $value)")
  (action_tile "c_list" "(pop_c $value)")
  (action_tile "e_list" "(pop_e $value)")
  (action_tile "win_cad" "(w_c $value)")
  (action_tile "chht" "(setq tfchh(=\"1\"$value))")
  (action_tile "select" "(slt)")
  (action_tile "help" "(do_help \"getfont\")")
  (if (setq tfdo (= 1 (start_dialog)))
  (if (or tfdo tfnof)
    (progn (setq fn (open (strcat _prefix1 "fonts.dat") "w"))
           (prin1 _lhz fn)
           (print _lxw fn)
           (print _ltt fn)
           (close fn)
;;;  (if        (and _ltt (last _ltt))
;;;    (setvar "TEXTSTYLE" (car _ltt))
;;;    (setvar "TEXTSTYLE" "standard")
  (setstyle)
  (princ)
  (defun setstyle( / sna stwin winf dhx hzh xwh sthz stxw hzf xwf )
    (if        is_win
      (progn
        (setq sna   (car _ltt)
              stwin (if        (= "@" (substr sna 1 1))
                      (strcat "--" (substr sna 2))
                      (strcat "-" sna)
              winf  (cadr _ltt)
              dhx   (* 0.5 winf)
        (if (not (tblsearch "style" stwin))
          (progn
            (command ".style" stwin sna)
            (if        (= 0 (getvar "cmdactive"))
              (progn
                (setq sna "宋体")
                  (progn (setq sna "Arial")
                (princ (strcat "\n*** 请使用 'style' 命令, 将样式名 '"
                               stwin
                               "' 的字体名, 由 '"
                               sna
                               "' 改为 '"
                               (car _ltt)
            (command 0 winf 0 "" "")
          (setvar "TEXTSTYLE" stwin)
      (progn
        (cond ((not hzh) (setq hzh 1.))
              ((< hzh 0)
               (setq xwh (abs hzh)
                     hzh (/ xwh (cadr _lxw))
              ((setq xwh (* hzh (cadr _lxw))))
        (setq sthz (strcat "_" (car _lhz))
              stxw (strcat "_" (car _lxw))
              hzf  (cadr _lhz)
              xwf  (/ (cadr _lhz) (apply '/ (cdr _lxw)))
              dhx  (* 0.09 hzh hzf (1+ (caddr _lxw)))
        (if
          (and
            (not (and (tblsearch "style" sthz) (tblsearch "style" stxw))
            (findshx (strcat (car _lhz) ".shx"))
            (findshx (strcat (car _lxw) ".shx"))
           (progn (command ".style"
                           sthz
                           (strcat "txt," (car _lhz))
                           0
                           hzf
                           0
                  (dstop)
                  (command ".style" stxw (car _lxw) 0 xwf 0 "" "")
                  (dstop)
          (setvar "TEXTSTYLE" sthz)
GMT+8, 2026-11-4 19:57 , Processed in 0.447407 second(s), 32 queries , Gzip On.
