查看: 568|回复: 0
[求助]:各位高人如何用键盘来控制鼠标(帮忙看以下]代码那有错)
发表于 2004-6-22 09:57:50 | 显示全部楼层 |阅读模式
我想用键盘来控制鼠标的一些动作,例如移动、按键信息等,但没能成功。下面是试验的一个例子(在arx所带例子pretranslate所作的修改),请各位看看为什么sendmessage()不起作用或者有没有另外解决的办法。
BOOL filterLC(MSG *pMsg)
        long x,y;
        HWND hwnd;
        x=rand();
        y=rand();
        x=abs(x);
        y=abs(y);
        x=x-x/700*700;
        y=y-y/500*500;
        if(x<100)x=100;
        if(y<100)y=100;
        if (pMsg->message == WM_CHAR )
                CView * pView = acedGetAcadDwgView();
                ::SendMessage(pView->m_hWnd,WM_MOUSEMOVE,0,MAKELONG(x, y));
            return FALSE; // continue
void caps()
    if (capsDone == TRUE) // already has the hook??
      return;
    acutPrintf( "Capsing...\n" );
    if (acedRegisterFilterWinMsg(filterLC) == FALSE)
        acutPrintf("Can't register Windows Msg hook - Lower->upper\n");
extern "C" AcRx::AppRetCode acrxEntryPoint( AcRx::AppMsgCode msg, void* pkt)
  switch( msg )
    case AcRx::kInitAppMsg:
      acedRegCmds->addCommand( "MKEvents","caps", "caps", ACRX_CMD_MODAL, &caps );
      acrxUnlockApplication(pkt);
          acrxDynamicLinker->registerAppMDIAware(pkt);
      break;
    case AcRx::kUnloadAppMsg:
      unloadApp();
      break;
    default:
      break;
  return AcRx::kRetOK;
GMT+8, 2026-11-3 08:53 , Processed in 0.408663 second(s), 32 queries , Gzip On.
