查看: 1052|回复: 0
[ARX程序]:ef.h的内容
发表于 2004-7-1 10:52:32 | 显示全部楼层 |阅读模式
#include "assoc.h"
void ef();
static CString test;
void ef()
        struct resbuf *cmd;
        CString str1,style;
        ads_name name,adsname1;
        ads_point point1;
        str1.Format("请选择需要读出属性的块:");
        acedEntSel(str1,adsname1,point1);
        acdbNameSet(adsname1,name);
        struct resbuf *da;
        ads_real hight,angle,scale,wscale;
        ads_point inpoint;
        int i=0;
        acdbEntNext(adsname1,adsname1);
        da=acdbEntGet(adsname1);
        if(da->rbnext!=0)
                da=da->rbnext;
        test.Format(assoc(1,da,test));
        ads_real hightt=0.0;
        hightt=assoc(40,da,hightt);
        ads_point pnt;
        *pnt=*assoc(10,da,pnt);
        *(pnt+1)=*(assoc(10,da,pnt)+1);
        *(pnt+2)=*(assoc(10,da,pnt)+2);
//        AfxMessageBox(test);
        while((da->restype==0)&&(da->rbnext!=0))
                CString att,at1;
                att.Format("ATTRIB");
                at1.Format(da->resval.rstring);
                if(att==at1)
                        while((da->rbnext!=0)&&(da->rbnext!=0))
                                if(da->restype==40)
                                        hight=da->resval.rreal;
                                if(da->restype==41)
                                        wscale=da->resval.rreal;
                                if(da->restype==10)
                                        ads_point_set(da->resval.rpoint,inpoint);
                                if(da->restype==50)
                                        angle=da->resval.rreal;
                                if(da->restype==41)
                                if(da->restype==7)
                                        style.Format(da->resval.rstring);
                                        break;
                                if(da->restype==1)
                                        str1.Format(da->resval.rstring);
                                        i=1;
//                                        break;
                                if(da->rbnext!=0)
                                        da=da->rbnext;
                                else goto END;
                        cmd=acutBuildList(RTSTR,"style",RTSTR,style,RTSTR,"",RTSTR,"0",RTREAL,wscale,RTSTR,"0",RTSTR,"",RTSTR,"",RTSTR,"",0);
                        acedCmd(cmd);
                        cmd=acutBuildList(RTSTR,"text",RTSTR,"S",RTSTR,style,RTPOINT,inpoint,RTREAL,hight,RTREAL,angle,RTSTR,str1,0);
                        acedCmd(cmd);
                else break;
                if(da->rbnext!=0)
                        da=da->rbnext;
                else goto END;
END:
        if(i==1)
                cmd=acutBuildList(RTSTR,"explode",RTENAME,name,0);
                acedCmd(cmd);
                struct resbuf glv;
                glv.restype=0;glv.resval.rstring="ATTDEF";glv.rbnext=NULL;
                ads_name ssnamel,delname;
                acedSSGet("P",NULL,NULL,&glv,ssnamel);
                long length;
                acedSSLength(ssnamel,&length);
                for(int ijk=0;ijk<length;ijk++)
                        acedSSName(ssnamel,ijk,delname);
                        acedCommand (RTSTR, "_.erase", RTENAME, delname,RTSTR,"",RTNONE);
        else
                AfxMessageBox("没有选择有效的属性块!");
GMT+8, 2026-11-2 22:52 , Processed in 0.524188 second(s), 32 queries , Gzip On.
