查看: 704|回复: 2
[其他]:objecrarx2005 支持.net2003了,但是不能用
发表于 2004-7-16 19:47:55 | 显示全部楼层 |阅读模式
Version 3.2.0.0:
* New feature list:
- Now install on both .NET 2002 and 2003 (NOTE you must use VC7.0 still)
- Dropped ARX Help button in favor of the Integrated Visual Studio Help (See DevNote #83661)
- Dropped 'Code Finder' button in favor of the Dynamic Help from the Integrated Visual Studio Help (See DevNote #83661)
- Code Gallery is now available (and synchronized with ADN)
- LiveUpdate is not anymore automatic
- acad.rx generation is turned off by default.
发表于 2004-7-18 13:33:56 | 显示全部楼层
是的可以用,但是编译器你还得用 VC7.0的。
发表于 2006-4-18 10:06:01 | 显示全部楼层
对,有什么办法可以在目前的情况下就能在2003下搞定的?
GMT+8, 2026-11-5 07:41 , Processed in 0.391869 second(s), 36 queries , Gzip On.
