查看: 717|回复: 0
[转贴]:AutoCAD自动标注的尺寸,以文字的形式重新标注
发表于 2004-7-18 15:09:18 | 显示全部楼层 |阅读模式
我只是看见了这个程序决得不错在这里传贴,我也不懂,大家不要问我哈:)
(defun c:dimtotxt(/ ss ee leng n scale x y l text numb class al pre first second post) ;本程序用于将AutoCAD自动标注的尺寸,以文字的形式重新标注
(prompt "请选择要修改的实体")
(setq ss (ssget ) )
(setq leng (sslength ss) n 0 str "")
(setq scale (getvar "dimlfac") numb 0)
(repeat leng
(setq ee (ssname ss n))
(setq al (entget ee))
(setq name (cdr (assoc 0 al)))
(setq class (cdr (assoc 70 al)))
(setq pre "" post "")
(if (and (= "DIMENSION" name) (= (cdr (assoc 1 al)) ""))
(progn
(setq lx (cdr (assoc 70 al)))
(if (> lx 128)(setq lx (- lx 160))(setq lx (- lx 32)))
(if (= lx 0)(cc1))
(if (= lx 1)(cc2))
(if (= lx 2)(progn (setq post "%%d" )(cc3)))
(if (= lx 3)(progn (setq pre "%%c" )(cc4)))
(if (= lx 4)(progn (setq pre "R" ) (cc4)))
(if (= lx 6)(cc5))
(if (= lx 70)(cc6))
(setq text (rtos (* jbcc scale) 2 4) text (strcat pre text) text (strcat text post))
(setq al
(subst (cons 1 text) (assoc 1 al) al)
(entmod al)
(setq numb (1+ numb))
(princ "\n\n你修改的是对象是第几个:")
(princ numb)
(princ "\n现在标注为:")
(princ text)
) ;endprogn
) ;endif
(setq n (1+ n))
) ;endrep
(princ "\n\nSUMMARY:\n本程序将所有的自动标注转换成文本标注\n你所用的标注线性比例为:")
(princ scale);
(princ "\n总共修改个数")
(princ numb)
(princ "\n\n")
(princ)
(princ "如有问题,请与huihl@netease.com联系\n")
(command "line" '(0,0) "") ;此语句是为了回退(undo)的需要而编写,即一次只能回退一条操作。
) ;endfun
;;;以下函数得于司马奇
;;;==================基本尺寸查询函数==================
;;;======================BEGIN========================
;;;水平、垂直类型标注基本尺寸计算
(defun cc1(/ jj x1 x2)
(setq jj (cdr (assoc 50 al))
x1 (assoc 13 al)
x2 (assoc 14 al)
(if (= jj 0)
(setq jbcc (abs (- (nth 1 x1) (nth 1 x2))))
(setq jbcc (abs (- (nth 2 x1) (nth 2 x2))))
;;;倾斜类型标注基本尺寸计算
(defun cc2(/ x1 x2)
(setq x1 (assoc 13 al)
x2 (assoc 14 al)
(setq jbcc (sqrt (+ (* (- (nth 1 x1) (nth 1 x2)) (- (nth 1 x1) (nth 1 x2)))
(* (- (nth 2 x1) (nth 2 x2)) (- (nth 2 x1) (nth 2 x2)))
;;;角度类型标注基本尺寸计算
(defun cc3(/ x1 x2 x3 x4 x5 ang1 ang2)
x2 (assoc 14 al)
x3 (assoc 10 al)
x4 (assoc 15 al)
x5 (assoc 11 al)
(setq ang1 (angle (list (nth 1 x1) (nth 2 x1))
(list (nth 1 x2) (nth 2 x2)))
ang2 (angle (list (nth 1 x3) (nth 2 x3))
(list (nth 1 x4) (nth 2 x4)))
(setq jbcc (rtd (abs (- ang1 ang2))))
;;;直径、半径类型标注基本尺寸计算
(defun cc4(/ x1 x2)
(setq x1 (assoc 10 al)
x2 (assoc 15 al)
;;;Y向坐标类型标注基本尺寸计算
(defun cc5(/ x1 x2)
x2 (assoc 10 al)
;;;X向坐标类型标注基本尺寸计算
(defun cc6(/ x1 x2)
x2 (assoc 10 al)
;;;弧度转换成角度函数
(defun rtd(ang)
(setq ang (/ (* ang 180) pi))
;;;==================基本尺寸查询函数===================
;;;======================THE END=======================
GMT+8, 2026-11-4 23:35 , Processed in 0.604181 second(s), 32 queries , Gzip On.
