查看: 1390|回复: 3
[转贴]:Text2MText
已领礼包: 593个
发表于 2004-8-14 11:25:20 | 显示全部楼层 |阅读模式
  1. ;;; Text2MText
  2. ;;; (c) 1995 CR/LF GmbH, Essen/Germany
  3. ;;; Custom AutoCAD Programming since 1986
  4. ;;;
  5. ;;; CR/LF GmbH                               -----------
  6. ;;; Obere Fuhr 27                           |  CR /   | |
  7. ;;; D-45136 Essen                          ||    / LF | |
  8. ;;; Tel.:     ++49 201 254566              || <-------+ |
  9. ;;; Fax:      ++49 201 256669              | -----------
  10. ;;; CIS:      100015,1632                   -----------
  11. ;;; Internet: [email]100015.1632@CompuServe.com[/email]
  12. ;;;
  13. ;;; This program is copyrighted. It may be distributed freely however.
  14. ;;;
  15. ;;; Benefit:
  16. ;;;   This file implements an AutoCAD command to combine selected text lines
  17. ;;;   to a single mtext object.
  18. ;;;
  19. ;;; Usage:
  20. ;;;   Load this file with AutoCAD's APPLOAD command.
  21. ;;;   Enter TEXT2MTEXT.
  22. ;;;   Pick the reference text. The mtext object will use this entity's
  23. ;;;     properties including style, text height, layer a.s.o.
  24. ;;;   Select the other text entities to append to the reference text.
  25. ;;;   Done.
  26. ;;;
  27. ;;; Restrictions:
  28. ;;;   Select the text to combine by clicking. Using crossing or windowing
  29. ;;;   may result in an unwanted text sequence.
  30. ;;;
  31. (defun c:text2mtext (/ dxf ss index ent mtext)
  32.   (defun dxf (tag obj) (cdr (assoc tag obj)))
  33.   (cond
  34.     ((not (setq reftext (car (entsel "Pick reference text"))))
  35.        (princ "Nothing selected"))
  36.     ((not (= (dxf 0 (setq reftext (entget reftext))) "TEXT"))
  37.        (princ "Not a text"))
  38.     ((not (setq ss (ssget)))
  39.        (princ "Nothing selected"))
  40.     (T
  41.      (setq index 0.0
  42.            mtext '((0 . "MTEXT") (100 . "AcDbEntity") (100 . "AcDbMText"))
  43.            mtext (append mtext
  44.                          (list (assoc 8 reftext) (assoc 10 reftext)
  45.                                (assoc 7 reftext) (assoc 40 reftext)
  46.                                (cons 41 (abs (- (caar (textbox reftext))
  47.                                                 (caadr (textbox reftext)))))
  48.                                (cons 3 (strcat (dxf 1 reftext) "\\P"))))
  49.      )
  50.      (entdel (dxf -1 reftext))
  51.      (repeat (sslength ss)
  52.        (cond ((not
  53.                 (= (dxf 0 (setq ent (entget (ssname ss index)))) "TEXT")
  54.               )
  55.                 (princ "Non-text ignored")
  56.              )
  57.              (T (setq mtext (append mtext
  58.                                (list (cons 3 (strcat (dxf 1 ent) "\\P")))))
  59.                 (entdel (dxf -1 ent))
  60.              )
  61.        )
  62.        (setq index (1+ index))
  63.      )
  64.      (entmake (append mtext '((1 . " "))))
  65.     )
  66.   )
  67.   (princ)
  68. )
发表于 2004-8-16 10:38:56 | 显示全部楼层
请问是做什么用的?
发表于 2004-8-16 11:59:30 | 显示全部楼层
标题已经很清楚了,“单行文字转换为多行文字”。
发表于 2004-8-17 19:06:24 | 显示全部楼层
CAD本身有這個工具的啊. 試試看
GMT+8, 2026-11-3 08:33 , Processed in 0.461219 second(s), 38 queries , Gzip On.
