查看: 2174|回复: 16
[原创]:等分标注程序
发表于 2004-8-29 14:21:30 | 显示全部楼层 |阅读模式
;;;dfbz.lsp 等分标注
;;;* C:dfbz
;;;-- XYP@bsedi.com
;;;2004.08.05
(prompt "\n\r      加载等分标注程序。")
;;;主程序
(defun c:dfbz (/ ss n m pt0 pt1 pt2 ang dist)
  (cmdla0)
  (setvar "osmode"0)
  (setq no3 (ureal 1 "" "\n\t等分数" no3))
  (setq ss (entsel "\n\t选择需等分的标注"))
  (if (and ss (> no3 1) (= (dxf-s1 0 (car ss)) "DIMENSION"))
    (progn
      (setq n 0 m 0)
        (setq s1 (car ss))
        (mkla"dim-等分"3)
        (setq pt2 (dxf-s1 13 s1) pt1 (dxf-s1 14 s1) pt0 (dxf-s1 10 s1))
        (setq ang (angle pt1 pt2))
        (setq dist (/ (distance pt1 pt2) no3))
        (setq pt2 (polar pt1 ang dist))
        (command "dim1" "ali" pt1 pt2 pt0 "")
        (while (< m (- no3 1))
          (setq pt2 (polar pt2 ang dist))
          (command "dim" "con" pt2 "" "e")
          (setq m (+ 1 m))
        (setq n (+ 1 n))
      (entdel s1)
  (prin1)
  (pxyp"dfbz      (等分标注)")
  (cmdla1)
;;;子程序
(defun CMDLA0 ()
  (setq cmdech (GETVAR "CMDECHO"))
  (setq oom (getvar "orthomode"))
  (setq osm (getvar "osmode"))
  (SETQ LA (getvar "clayer"))
  (setvar "regenmode" 1)
  (SETVAR "CMDECHO" 0)
(defun CMDLA1 ()
  (SETVAR "CMDECHO" cmdech)
  (setvar "orthomode" oom)
  (setvar "osmode" osm)
  (setvar "clayer" LA)
(defun ureal (bit kwd msg def / inp)
  (if def
    (setq msg (strcat "\n" msg "<" (rtos def 2) ">: ")
          bit (* 2 (fix (/ bit 2)))
    (setq msg (strcat "\n" msg ": "))
  (initget bit kwd)
  (setq inp (getreal msg))
  (if inp inp def)
(Defun MKLA (a b)
  (If (= (Tblsearch "layer" a) nil)
    (Command "layer" "m" a "c" b a "")
    (Command "layer" "t" a "s" a "c" b a "")
(defun dxf (code elist) (cdr (assoc code elist)))
(defun dxf-s1(code elist) (dxf code (entget elist)))
(DEFUN PXYP (TXT1)
  (SETQ        TXT1 (STRCAT "\n\r      程序命令: "  TXT1 "      -- XYP@bsedi.com"))
  (PRINC TXT1)
  (Princ)
  );defun
(pxyp"dfbz      (等分标注)")
;;;END
发表于 2004-8-31 09:01:11 | 显示全部楼层
源程序,就支持,我知道内容与帖子一样,下载。
发表于 2004-8-31 15:55:16 | 显示全部楼层
创意还不错,不过可能便用范围不大,毕竟等分的比较少。恕我直言
发表于 2004-9-1 08:46:06 | 显示全部楼层
最初由 lzy9788 发布
[B]创意还不错,不过可能便用范围不大,毕竟等分的比较少。恕我直言 [/B]
源码支持!
但是当标注点和尺寸线不平行时,程序有bug,没有判断!
发表于 2006-3-10 10:36:48 | 显示全部楼层
等分编号类似么?有人参考下么?
发表于 2006-4-19 08:43:46 | 显示全部楼层
就是找这个,支持,已经下载
发表于 2006-4-19 09:47:29 | 显示全部楼层
用理正建筑里的标志等分,好用!
发表于 2006-4-19 09:54:36 | 显示全部楼层
好东西,非常方便
发表于 2006-4-19 10:11:17 | 显示全部楼层
不错。原创的就是好东西
发表于 2006-4-24 22:54:04 | 显示全部楼层
老大的东西就是好用呀
发表于 2006-4-25 09:14:13 | 显示全部楼层
怎么加载后没什么异常,
使用也是没异常,
就是没标注出现啊?
发表于 2006-5-24 19:09:32 | 显示全部楼层
给个贴图先,不是很懂
发表于 2006-5-25 16:01:14 | 显示全部楼层
谢谢楼主贴出源码!
发表于 2006-6-7 18:02:34 | 显示全部楼层
謝謝了了了謝謝謝了了了謝謝
謝了了了了了謝了了了了了謝
謝了了了了了了了了了了了謝
謝了了真心地向您致敬了了謝
謝謝了了了謝謝谢了了了謝謝
謝謝謝了了了了了了了謝謝謝
謝謝謝謝了了了了了謝謝謝謝
謝謝謝謝謝了了了謝謝謝謝謝
謝謝謝謝謝謝了謝謝謝謝謝謝
发表于 2006-6-7 18:17:37 | 显示全部楼层
能不能弄成不等分也行,就是在任意位置断开都可以。。
GMT+8, 2026-11-7 04:32 , Processed in 0.630451 second(s), 61 queries , Gzip On.
