查看: 699|回复: 1
[求助]:vba 代码转换成vb码
发表于 2004-8-30 09:33:39 | 显示全部楼层 |阅读模式
请问如何将画好的直线或圆弧命名成curvers(0)、curvers(1)等?
或者将下面的的代码转换成vb码
Sub Example_AddRevolvedSolid()
    ' This example creates a solid from a region
    ' rotated around an axis.
    ' The region is created from an arc and a line.
    Dim curves(0 To 1) As AcadEntity
    ' Define the arc
    Dim centerPoint(0 To 2) As Double
    Dim radius As Double
    Dim startAngle As Double
    Dim endAngle As Double
    centerPoint(0) = 5#: centerPoint(1) = 3#: centerPoint(2) = 0#
    radius = 2#
    startAngle = 0
    endAngle = 3.141592
    Set curves(0) = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngle, endAngle)
    ' Define the line
    Set curves(1) = ThisDrawing.ModelSpace.AddLine(curves(0).startPoint, curves(0).endPoint)
    ' Create the region
    Dim regionObj As Variant
    regionObj = ThisDrawing.ModelSpace.AddRegion(curves)
    ZoomAll
    MsgBox "Revolve the region to create the solid.", , "AddRevolvedSolid Example"
    ' Define the rotation axis
    Dim axisPt(0 To 2) As Double
    Dim axisDir(0 To 2) As Double
    Dim angle As Double
    axisPt(0) = 7: axisPt(1) = 2.5: axisPt(2) = 0
    axisDir(0) = 11: axisDir(1) = 1: axisDir(2) = 3
    angle = 6.28
    ' Create the solid
    Dim solidObj As Acad3DSolid
    Set solidObj = ThisDrawing.ModelSpace.AddRevolvedSolid(regionObj(0), axisPt, axisDir, angle)
    ZoomAll
     ' Change the viewing direction of the viewport
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
    ThisDrawing.ActiveViewport.direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ZoomAll
    MsgBox "Solid created.", , "AddRevolvedSolid Example"
End Sub
发表于 2004-8-30 14:43:14 | 显示全部楼层
1
获取用GetEntity方法或选择集
2
set obj=getobject(,"autocad.application")
set docobj=obj.activedocument
然后用docobj代替上面的Thisdrawing
GMT+8, 2026-11-3 16:15 , Processed in 0.487396 second(s), 34 queries , Gzip On.
