查看: 1417|回复: 6
[教学]:用MFC,如何给一个bitmap按钮添加tooltip提示
已领礼包: 145个
发表于 2002-3-1 19:21:34 | 显示全部楼层 |阅读模式
How to create the tooltip for a bitmap button?
ID    45283
Applies to:    AutoCAD 2000
Date    5/31/2000
This document is part of    AcUi/AdUi   ObjectARX   MFC   User Interface   ObjectARX Technical Newsletter - November 1999
Question
I have created a CAcUiBitmapButton. How do I create the tooltip text that
displays when the cursor is placed over the button?
Answer
CAcUiBitmapButton has implemented everything necessary for doing this; you only
need to provide the tooltip string within the caption, such as SAMP|Sample
Button1.
Notice the SAMP before the vertical bar is the bitmap's resource ID name. This
is when you design the dialog button and set the properties. Also, make sure you
choose owner draw style for the button.
Moreover, you can create multiple lines of tooltip by overriding OnGetTipText()
and modifying the reference parameter to the text string you want.
To demonstrate these approaches, the attached sample application has two
separate buttons; one uses CAcUiBitmapButton and the other is derived from
CAdUiOwnerDrawButton. In addition, it shows how to draw a text button that
changes it appearance when it is clicked.
Note that this approach also applies to all CAxUiWhatever control classes, such
as CAcUiColorComboBox, CAcUiAngleComboBox, CAcUiAngleEdit, and so on.
Also see DevNote #45267.
发表于 2003-8-15 16:00:47 | 显示全部楼层
这篇文章真及时啊!
哈哈
哈
哈
发表于 2003-8-15 16:27:54 | 显示全部楼层
下载了,却不完全,打不开:(
CAcUiBitmapButton怎么用啊?
发表于 2003-8-31 23:01:18 | 显示全部楼层
解压文件损坏?
发表于 2003-9-4 21:48:27 | 显示全部楼层
我今天下了几个,都是这个问题。
发表于 2004-3-2 20:37:08 | 显示全部楼层
文件可以下载吗?请重新上传把,多些!
发表于 2004-3-15 19:31:07 | 显示全部楼层
经典呀
首先非常感谢楼主发出这样好的贴子
其次,楼主的英文很标准呀,值得佩服!!!
GMT+8, 2026-11-5 07:59 , Processed in 0.401353 second(s), 45 queries , Gzip On.
