查看: 771|回复: 0
[LISP程序]:标注样式默认状态
发表于 2004-9-21 12:19:07 | 显示全部楼层 |阅读模式
(defun c:ii (/ )
(command "units" "2" "1" "1" "1" "0" "n") ;设置坐标和角度的显示格式和精度
(setvar "AttDia" 0) ;不使用属性对话框
(setvar "FileDia" 1) ;显示文件对话框
(setvar "CmdDia" 1) ;显示打印和外部命令对话框
(setvar "highlight" 1) ;对象被选定时,突出显示
(setvar "MenuCtl" 0) ;屏幕菜单将响应键盘输入命令,不进行页切换
(setvar "PickStyle" 0) ;不使用编组选择和关联填充选择
(setvar "MirrText" 0) ;保持文字方向
(setvar "LimCheck" 0) ;可以在图形界限外创建对象
(setvar "AttMode" 1) ;使全部属性可见
(command "DRAGMODE" "a" ) ;本系统变量控制被拖动对象的显示
(command "DIMADEC" "" ) ;角度小数位数
(command "DIMALT" "Off" ) ;选定的换算单位
(command "DIMALTD" "4" ) ;换算单位小数位数
(command "DIMALTF" "25.4000" ) ;换算单位比例因子
(command "DIMALTRND" "0.0000" ) ;换算单位舍入值
(command "DIMALTTD" "4" ) ;换算公差小数位数
(command "DIMALTTZ" "0" ) ;换算公差消零
(command "DIMALTU" "8" ) ;换算单位
(command "DIMALTZ" "0" ) ;换算单位消零
(command "DIMAPOST" "" ) ;替换文字的前缀和后缀
(command "DIMASZ" "1.5000" ) ;箭头大小
(command "DIMATFIT" "0" ) ;箭头和文字调整
(command "DIMAUNIT" "0" ) ;角度单位格式
(command "DIMAZIN" "0" ) ;角度消零
(command "DIMBLK" "ArchTick") ;箭头块名
(command "DIMBLK1" "ArchTick") ;第一个箭头块名
(command "DIMBLK2" "ArchTick") ;第二个箭头块名
(command "DIMCEN" "0.0900" ) ;圆心标记大小
(command "DIMCLRD" "0" ) ;尺寸线和引线颜色
(command "DIMCLRE" "0" ) ;尺寸界线颜色
(command "DIMCLRT" "3" ) ;标注文字颜色
(command "DIMDEC" "" ) ;小数位数
(command "DIMDLE" "1.0000" ) ;尺寸线
(command "DIMDLI" "5.5000" ) ;尺寸线间距
(command "DIMDSEP" "." ) ;小数分隔符
(command "DIMEXE" "1.0000" ) ;尺寸界线在尺寸线上
(command "DIMEXO" "1.0000" ) ;尺寸界线原点偏移
(command "DIMFRAC" "0" ) ;分数格式
(command "DIMGAP" "1.0000" ) ;尺寸线和文字的间距
(command "DIMJUST" "0" ) ;尺寸线上的文字对正
(command "DIMLDRBLK" "ArchTick") ;引线块名
(command "DIMLFAC" "1.0000" ) ;线性单位比例因子
(command "DIMLIM" "Off" ) ;生成标注界限
(command "DIMLUNIT" "2" ) ;线性单位格式
(command "DIMLWD" "-2" ) ;尺寸线和引线线宽
(command "DIMLWE" "-2" ) ;尺寸界线线宽
(command "DIMPOST" "" ) ;标注文字的前缀和后缀
(command "DIMRND" "0.0000" ) ;舍入值
(command "DIMSAH" "off" ) ;独立的箭头块
(command "DIMSD1" "Off" ) ;隐藏第一条尺寸线
(command "DIMSD2" "Off" ) ;隐藏第二条尺寸线
(command "DIMSE1" "Off" ) ;隐藏第一条尺寸界线
(command "DIMSE2" "Off" ) ;隐藏第二条尺寸界线
(command "DIMSOXD" "Off" ) ;隐藏外侧尺寸线
(command "DIMTAD" "1" ) ;文字位于尺寸线上方
(command "DIMTDEC" "0" ) ;公差小数位数
(command "DIMTFAC" "1.0000" ) ;公差文字高度比例因子
(command "DIMTIH" "Off" ) ;尺寸界线内侧的文字水平放置
(command "DIMTIX" "On" ) ;将文字放置于尺寸界线侧
(command "DIMTM" "0.0000" ) ;下偏差
(command "DIMTMOVE" "2" ) ;文字移动
(command "DIMTOFL" "On" ) ;强制在尺寸界线内侧画尺寸线
(command "DIMTOH" "Off" ) ;外侧文字水平放置
(command "DIMTOL" "Off" ) ;公差注
(command "DIMTOLJ" "1" ) ;公差垂直对齐
(command "DIMTP" "0.0000" ) ;上偏差
(command "DIMTSZ" "0.0000" ) ;标记大小
(command "DIMTVP" "0.0000" ) ;文字垂直位置
(command "DIMTXSTY" "hz" ) ;文字样式
(command "DIMTXT" "3.0000" ) ;文字高度
(command "DIMTZIN" "8" ) ;公差消零
(command "DIMUPT" "Off" ) ;用户定位的文字
(command "DIMZIN" "8" ) ;消除十进制标注中的后续零
(princ "\n标注样式已恢复到默认状态!!!")
(princ)
);defun
GMT+8, 2026-11-3 07:08 , Processed in 0.478795 second(s), 32 queries , Gzip On.
