查看: 975|回复: 2
[求助] [求助]:请教,图纸空间-模型空间的点坐标如何转换?
发表于 2004-10-5 13:54:20 | 显示全部楼层 |阅读模式
发表于 2004-10-5 15:01:29 | 显示全部楼层
Reply From: Barr, Doug
Date: Mar/06/03 - 05:31 (GMT)
    Re: converting point from mspace to pspace
I pulled this out of a routine I use. It should work for your needs.
Let me know if it doesn't!
-doug
While in mspace.....
(setq p1 (getpoint))
(if (= 0 (getvar "tilemode"))
(progn
(setq p1 (trans p1 1 2))
(setq p1 (trans p1 2 3))
(command "_pspace")
 楼主| 发表于 2004-10-5 15:08:37 | 显示全部楼层
多谢!
GMT+8, 2026-11-5 05:51 , Processed in 0.369541 second(s), 36 queries , Gzip On.
