查看: 1697|回复: 2
[教学]:如何在MFC的“模式”对话框执行ACAD的acedGetXXX函数
已领礼包: 145个
发表于 2002-3-10 09:37:36 | 显示全部楼层 |阅读模式
How can I use acedGetxxx() functions from a MFC modal dialog box ?
ID    1597
Applies to:    AutoCAD 2000
AutoCAD 2000I
AutoCAD 2002
This document is part of    MFC
Question
How can I use acedGetXXX() functions from a MFC modal dialog box ?
Answer
There is no user intervention allowed at the AutoCAD main frame window or other
child windows when a child modal dialog is active. Since acedGetXXX functions
need to get user inputs mostly, they cannot be used pending an active modal
dialog.
Fortunately, you can hide and activate a modal dialog in your ARX application
inside AutoCAD. Generally speaking, when a modal dialog is active, MFC disables
the access to the parent window until the modal dialog is dismissed. This is
true for most of the windows applications, so there is no exception for AutoCAD.
To do this, you need to hide the modal dialog first, activate the parent, do
acedGetXXX(), activate the modal dialog, set the focus on it and set the parent
window disabled.
  1. GetParent ()->EnableWindow (TRUE) ; // Enable the parent
  2. ShowWindow (SW_HIDE) ; // Hide ourself
  3. GetParent ()->SetFocus () ; // Give focus to the parent
  4.                 // you do not really need to
  5.                 // do that (but it's better)
  6. ads_point pt ; // Do something...
  7. acedGetPoint (NULL, "\nPick a point: ", pt) ;
  8. acutPrintf ("\nYou picked (%.2lf, %.2lf, %.2lf,)\n",
  9.     pt [X], pt [Y], pt [Z]
  10. ) ;
  11. ShowWindow (SW_SHOW) ; // Show ourself
  12. SetFocus () ; // Give focus to ourself
  13. GetParent ()->EnableWindow (FALSE) ; // Disable the parent
  14. EnableWindow (TRUE) ; // Because our parent was disabled
  15.               // we need to enable ourself
复制代码
发表于 2002-3-12 06:52:49 | 显示全部楼层
已经调试成功!
void gongchengtu::OnButton3()
ads_point pt1;
GetTopLevelParent()->EnableWindow(TRUE
ShowWindow(SW_HIDE);
GetTopLevelParent()->SetFocus();
ads_getpoint(NULL,"\n 坐标点:",pt1);
m_px=pt1[0];
m_py=pt1[1];
ShowWindow(SW_SHOW);
SetFocus() ; // Give focus to ourself
UpdateData(FALSE);
已领礼包: 145个
 楼主| 发表于 2002-3-13 01:05:13 | 显示全部楼层
最初由 xulixin 发布
[B]已经调试成功!
ads_point pt1;
ads_getpoint(NULL,"\n 坐标点:",pt1)... [/B]
能跟大家说说问题的原因吗? 如何改就可以了?
GMT+8, 2026-11-2 16:53 , Processed in 0.428487 second(s), 36 queries , Gzip On.
