查看: 1182|回复: 14
我最熟练的快捷键
发表于 2004-10-21 19:09:31 | 显示全部楼层 |阅读模式
我最熟练的快捷键,多多交流
 楼主| 发表于 2004-10-21 19:10:56 | 显示全部楼层
没人顶,自己来!!
发表于 2004-10-21 20:08:31 | 显示全部楼层
老大,没什么新意啊,不过还是顶你一下。
发表于 2004-10-21 20:29:58 | 显示全部楼层
来发个图片看看啊
发表于 2004-10-21 20:46:38 | 显示全部楼层
是什么呀,说的详细点,
发表于 2004-10-21 21:03:44 | 显示全部楼层
CATALOG,   DIR /W,         0,File specification: ,
DEL,       DEL,            0,File to delete: ,
DIR,       DIR,            0,File specification: ,
EDIT,      START EDIT,     1,File to edit: ,
SH,        ,               1,*OS Command: ,
SHELL,     ,               1,*OS Command: ,
START,     START,          1,*Application to start: ,
TYPE,      TYPE,           0,File to list: ,
; Examples of external commands for Windows
; See also the STARTAPP AutoLISP function for an alternative method.
EXPLORER,  START EXPLORER, 1,,
NOTEPAD,   START NOTEPAD,  1,*File to edit: ,
PBRUSH,    START PBRUSH,   1,,
; Command alias format:
;   <Alias>,*<Full command name>
;  The following are guidelines for creating new command aliases.
;  1.  Try the first character of the command, then try the first two,
;         then the first three.
;  2.  Ignore "DD" at the beginning of a command.
;  3.  Abbreviate the following prefixes:
;        Examples: 3 for 3D, A for ASE, D for Dim, I for Image, R for render.
;  4.  Once an alias is defined, add suffixes for related aliases:
;        Examples: R for Redraw, RA for Redrawall, L for Line, LT for Linetype.
;  5.  An alias should reduce a command by at least two characters.
;  6.  Commands with a control key equivalent, status bar button, or function key
;        do not require a command alias.
;        Examples: Use Control-N, -O, -P, and -S for New, Open, Print, and Save
;  7.  Use a hyphen to differentiate between command line and dialog box commands.
;  8.  Exceptions to the rules include AA for Area, T for Mtext, X for Explode.
;  Sample aliases for AutoCAD commands
;  These examples include most frequently used commands.
3A,        *3DARRAY
3F,        *3DFACE
3P,        *3DPOLY
A,         *ARC
AA,        *AREA
AL,        *ALIGN
AP,        *APPLOAD
AR,        *ARRAY
AW,        *ARROW
AAD,       *ASEADMIN
AEX,       *ASEEXPORT
ALI,       *ASELINKS
ASQ,       *ASESQLED
ARO,       *ASEROWS
ASE,       *ASESELECT
AT,        *DDATTDEF
-AT,       *ATTDEF
ATE,       *DDATTE
-ATE,      *ATTEDIT
AX,        *AXCHA
AXT,       *AXOUT
AXN,       *AXIN
B,         *BLOCK
BH,        *BHATCH
BO,        *BOUNDARY
-BO,       *-BOUNDARY
BR,        *BREAK
C,         *COPY
CI,        *CIRCLE
CG,        *DDCHPROP
-CG,       *CHANGE
CH,        *CHAMFER
COL,       *DDCOLOR
D,         *DVIEW
DD,        *DDIM
DM,        *dimlwf
DX,        *dmhor
DC,        *dmdiv
DG,        *dmmge
DAL,       *DIMALIGNED
DAN,       *DIMANGULAR
DBA,       *DIMBASELINE
DCE,       *DIMCENTER
DCO,       *DIMCONTINUE
DDI,       *DIMDIAMETER
DED,       *DIMEDIT
DI,        *DIST
DIV,       *DIVIDE
DLI,       *DIMLINEAR
DO,        *DONUT
DOR,       *DIMORDINATE
DOV,       *DIMOVERRIDE
DF,        *DDMODIFY
DR,        *DRAWORDER
DRA,       *DIMRADIUS
DST,       *DIMSTYLE
DT,        *DTEXT
E,         *ERASE
ED,        *DDEDIT
EL,        *ELLIPSE
EX,        *EXTEND
EXIT,      *QUIT
EXP,       *EXPORT
EXT,       *EXTRUDE
F,         *FILLET
FI,        *FILTER
G,         *GROUP
-G,        *GROUP
GR,        *DDGRIPS
H,         *HIDE
-H,        *HATCH
HE,        *HATCHEDIT
I,         *DDINSERT
-I,        *INSERT
IAD,       *IMAGEADJUST
IAT,       *IMAGEATTACH
ICL,       *IMAGECLIP
IM,        *IMAGE
-IM,       *-IMAGE
IMP,       *IMPORT
IN,        *INTERSECT
INF,       *INTERFERE
IO,        *INSERTOBJ
k,         *DscUpDown
ko,        *DscRestorBar
L,         *LINE
LA,        *LAYER
LO,        *LAYISO
LF,        *LAYOFF
LN,        *LAYON
-LA,       *-LAYER
LE,        *LEADER
LEN,       *LENGTHEN
LI,        *LIMITS
LT,        *LINETYPE
-LT,       *-LINETYPE
LS,        *LTSCALE
M,         *MOVE
MA,        *MATCHPROP
ME,        *MEASURE
MI,        *MIRROR
ML,        *MLINE
MO,        *DDMODIFY
MS,        *MSPACE
MT,        *MTEXT
MV,        *MVIEW
O,         *OFFSET
OP,        *OPEN
OS,        *OSNAP
P,         *PAN
-P,        *-PAN
PA,        *PASTESPEC
PE,        *PEDIT
PL,        *PLINE
PN,        *PLAN
PO,        *POINT
POL,       *POLYGON
PR,        *PREFERENCES
PRE,       *PREVIEW
PRINT,     *PLOT
PS,        *PSPACE
PU,        *PURGE
QS,        *QSAVE
R,         *REDRAW
RA,        *REDRAWALL
RE,        *REDO
RG,        *REGEN
REA,       *REGENALL
REC,       *RECTANGLE
REG,       *REGION
REN,       *DDRENAME
REV,       *REVOLVE
RM,        *DDRMODES
RPR,       *RPREF
RR,        *RENDER
RN,        *RENAME
RT,        *ROTATE
S,         *SNAP
SC,        *SCALE
SCR,       *SCRIPT
SE,        *DDSELECT
SEC,       *SECTION
SET,       *SETVAR
SHA,       *SHADE
SL,        *SLICE
SD,        *SOLID
SP,        *SPELL
SPL,       *SPLINE
SPE,       *SPLINEDIT
ST,        *STRETCH
SY,        *STYLE
SU,        *SUBTRACT
T,         *TRIM
-T,        *-MTEXT
TA,        *TABLET
TH,        *THICKNESS
TI,        *TILEMODE
TO,        *TOOLBAR
TOL,       *TOLERANCE
TOR,       *TORUS
TR,        *TRACE
UN,        *UNDO
UC,        *DDUCS
UCP,       *DDUCSP
UN,        *DDUNITS
-UN,       *UNITS
UNI,       *UNION
V,         *VPOINT
-V,        *VIEW
VP,        *DDVPOINT
-VP,       *VPOINT
W,         *WBLOCK
WE,        *WEDGE
X,         *EXPLODE
XA,        *XATTACH
XB,        *XBIND
-XB,       *-XBIND
XC,        *XCLIP
XL,        *XLINE
XR,        *XREF
-XR,       *-XREF
Z,         *ZOOM
发表于 2004-10-22 08:34:28 | 显示全部楼层
好记的不一定好用,因为常用命令左手操盘跳跃太大
发表于 2005-3-24 21:28:19 | 显示全部楼层
6楼的根本不是左手键嘛,ellipse用el好记不好用啊,还是用es方便。
发表于 2005-3-24 23:18:05 | 显示全部楼层
不是左手銉,犹其是M字头,用得比较多,把它改为W字头不就好了!其它的类推!
发表于 2005-3-31 13:49:07 | 显示全部楼层
对CAD2004有用吗
发表于 2005-3-31 13:56:31 | 显示全部楼层
这么多啊
对啊,对CAD2004 有用吗?
发表于 2005-4-1 23:06:01 | 显示全部楼层
我觉得对画图还是很有用的,我改了以后,line,move,offset,mirror等等命令就不用两手回键盘敲了,画图快了许多。最好是自己摸索着改,改自己常用的,自己改的也好记,真的很有用的。在acad.pgp文件里改。
发表于 2005-4-2 06:17:43 | 显示全部楼层
1楼的快捷键太科学了
把大部分快捷键设定为左手才好
而且没有ET的快捷键啊
我来补充一下ET用的左手键,大家参考一下
1,         *LAYON
11,        *LAYTHW
2,         *LAYISO
3,         *LAYOFF
33,        *LAYFRZ
4,         *AI_MOLC
CC,        *LAYLCK
DC,        *LAYULK
其中DC是设计中心的快捷键,要先找到删掉它 因为没什么用,CTRL+2就可以打开设计中心
发表于 2005-4-2 07:31:56 | 显示全部楼层
最初由 clearbrook 发布
[B]6楼的根本不是左手键嘛,ellipse用el好记不好用啊,还是用es方便。 [/B]
改为 EE 不是更好!?
发表于 2005-4-2 10:45:12 | 显示全部楼层
我还没开始用过快捷键
GMT+8, 2026-10-23 08:12 , Processed in 0.536458 second(s), 61 queries , Gzip On.
