查看: 909|回复: 5
[求助]:如何将计算的点连接
发表于 2004-10-30 13:39:24 | 显示全部楼层 |阅读模式
如何将计算的点用pline一次性连接,一位仁兄提供了个函数"(command "pline" (foreach i ptlist (command i)) "") "
可我还是不知如何用它,,现将计算的点过程书写如下,还望给以指教,拜托拜托
(defun c:hh()
(setq Ls (getreal"Ls:"))
(setq R (getreal"R:"))
(setq c (* Ls R))
(setq i -1)
(setq L 1)
(while (< i (- Ls 1))
(setq i (c:cal "i+L"))
(setq x (c:cal "i-i^5/(40*c*c)"))
(setq y (c:cal "i^3/(6*c)-i^7/(336*c^3)"))
(setq p1 (list x y))
(setq x+dx (c:cal "(i+L)-(i+L)^5/(40*c*c)"))
(setq y+dy (c:cal "(i+L)^3/(6*c)-(i+L)^7/(336*c^3)"))
(setq pt (list x+dx y+dy))
(command "point" pt "")
发表于 2004-10-30 15:14:10 | 显示全部楼层
  1. (defun c:hh (/ ls r c r l i x y p1 x+dy y+dy pt)
  2.   (setq Ls (getreal "\nLs = "))
  3.   (setq R (getreal "\nR = "))
  4.   (setq c (* Ls R))
  5.   (setq i -1)
  6.   (setq L 1)
  7.   (while (< i (- Ls 1))
  8.     (setq i (c:cal "i+L"))
  9.     (setq x (c:cal "i-i^5/(40*c*c)"))
  10.     (setq y (c:cal "i^3/(6*c)-i^7/(336*c^3)"))
  11.     (setq p1 (list x y))
  12.     (setq x+dx (c:cal "(i+L)-(i+L)^5/(40*c*c)"))
  13.     (setq y+dy (c:cal "(i+L)^3/(6*c)-(i+L)^7/(336*c^3)"))
  14.     (setq pt (cons (list x+dx y+dy) pt))
  15.   )
  16.   (apply 'command (cons ".pline" pt))
  17.   (command)
  18.   (princ)
  19. )
发表于 2004-11-8 10:50:17 | 显示全部楼层
用excel导入是不是可以
 楼主| 发表于 2004-11-8 21:53:45 | 显示全部楼层
你是说复制粘贴功能吗?那样好象不是很方便,我有用过,可以是可以,只是不如以上程序的方便啊,如果我理解有误,望指教!
发表于 2004-11-9 12:40:18 | 显示全部楼层
直接计算,很简单,
 楼主| 发表于 2004-11-9 21:41:25 | 显示全部楼层
如何直接计算而达到目的呢?还望能够明示,或者举个例子可以吗?
GMT+8, 2026-11-6 11:59 , Processed in 0.538227 second(s), 41 queries , Gzip On.
