查看: 1160|回复: 4
[LISP程序]:改進後的球標智能標注程序原碼
发表于 2004-11-10 20:27:19 | 显示全部楼层 |阅读模式
命令行輸入  num          or             num_01
(defun c:num( / cc i ien it lay nn os te tt)
  (lspst)
  (princ "球標標注程式")
  (setq tt (getreal "\n請輸入字體的大小<2.5>:")) (if (null tt) (setq tt 2.5))
  (setq cc (* 2 tt))
  (setq te (getint "\n請輸入起始值的大小<1>:")) (if (null te) (setq te 1))
  (setq it te)
  (setq i 0)
  (if (setq nn (getpoint "\n請選擇初始球標的放置點:"))
    (progn
      (while nn
        (setvar "osmode" 0)
        (setq lay (getvar "clayer"))
        (if (null (tblsearch "layer" "cirdim"))
          (command ".layer" "m" "CIRDIM" "")
          (command ".layer" "t" "cirdim" "s" "cirdim" "")
        (command ".circle" nn "d" cc)
        (command ".text" "j" "m" nn tt "" te)
        (command ".layer" "s" lay "")
        (setq te (1+ te))
        (setq ien (+ i it))
        (setq i (1+ i))
        (setvar "osmode" os)
        (princ  (strcat "\n下一個球標"(itoa te)"的放置點:"))
        (setq nn (getpoint))
      (princ (strcat "-----★ 總共作了" (itoa i) "個球標標注,起始值為:" (itoa it) "、終止值為:" (itoa ien)" ★-----"))
    (progn
      (princ "\n無任何動作,程式退出!")
  (lspend)
(defun c:num_01( / cc i ien it lay nn os te tt te1 te2)
  (setvar "cmdecho" 0)
  (setq os (getvar "osmode")
  (command ".undo" "be")
  (princ "球標標注程式")
  (setq cc (* 3 tt))
  (setq te1 (getstring "請輸入起始標頭<A1>:"))(if (= te1 "") (Setq te1 "A1"))
  (if (= (strlen te1) 2)
    (Setq te (atoi (substr te1 2 1)))
    (Setq te (atoi (substr te1 2 2)))
  (setq it te)
  (setq i 0)
    (progn
      (while nn
        (setvar "osmode" 0)
        (Setq te2 (strcat (substr te1 1 1) (itoa te)))
        (command ".text" "j" "m" nn tt "" te2)
        (setq te (1+ te))
        (setq ien (+ i it))
        (setq i (1+ i))
        (princ  (strcat "\n下一個球標"(substr te1 1 1)(itoa te)"的放置點:"))
      (princ (strcat "★總共作了" (itoa i) "個球標標注,起始值為:" (itoa it) "、終止值為:" (itoa ien) ",其中標頭為< " (substr te1 1 1)" >""★"))
    (progn
  (setvar "cmdecho" 1)
  (prin1)
发表于 2004-11-12 08:45:26 | 显示全部楼层
1. (lspst), (lspend) 函数未定义;
2. (setq os (getvar "osmode") 后缺少一个 ")";
3 不能连续生成.
 楼主| 发表于 2004-11-12 11:16:59 | 显示全部楼层
(setq os (getvar "osmode"))
(princ "球標標注程式")
(setq cc (* 2 tt))
(setq it te)
(setq i 0)
(progn
(while nn
(setvar "osmode" 0)
(setq te (1+ te))
(setq ien (+ i it))
(setq i (1+ i))
(progn
(prin1)
(princ "球標標注程式")
(setq cc (* 3 tt))
(setq te1 (getstring "請輸入起始標頭:"))(if (= te1 "") (Setq te1 "A1"))
(setq it te)
(setq i 0)
(progn
(while nn
(setvar "osmode" 0)
(setq te (1+ te))
(setq ien (+ i it))
(setq i (1+ i))
(progn
(prin1)
发表于 2004-11-21 21:52:11 | 显示全部楼层
球标标注是什么意思?
 楼主| 发表于 2004-11-22 12:18:34 | 显示全部楼层
己驗證,可以連續標注。
GMT+8, 2026-11-3 06:03 , Processed in 0.493391 second(s), 40 queries , Gzip On.
