查看: 4705|回复: 15
[LISP程序]:把文字转为立体3D字
发表于 2002-3-14 03:49:26 | 显示全部楼层 |阅读模式
  1. ;;;    功能:把文字转为立体3D字
  2. ;;;    修改EXPRESSTOOL中的TXTEXP.LSP作子程序
  3. ;;;    虽安装EXPRESSTOOL 及 配合XDRX_API
  4. ;;;    只能转TTF字型,非TTF字型转为"标楷体"
  5. ;;;    程序设计:赖云龙
  6. ;;;    注意:字型直线多的如"细明体系列"容易出错
  7. ;;;    我是用繁体字,简体字效果?????????未知!!!!!!!
  8. ;;;----------------------------------------------------------------
  9. (defun TXTEXP (SS      /       GRPLST  GETGNAME               BLKNM   GLST
  10.                GDICT   VIEW    UPLFT   TMPFIL  TBX     TMPFIL  CNT
  11.                PT1     PT2     ENT     TXT     TXTYP   PTLST   ZM
  12.                LOCKED  GNAM
  13.               )
  14.   (ACET-ERROR-INIT
  15.     (list
  16.       (list "cmdecho"  0          "highlight"                1
  17.             "osmode"   0          "Mirrtext" 1                "limcheck"
  18.             0
  19.            )
  20.       t
  21.     )
  22.   )
  23.   (defun ACET-TXTEXP-GRPLST (/ GRP ITM NAM ENT GLST)
  24.     (setq GRP (dictsearch (namedobjdict) "ACAD_GROUP"))
  25.     (while (setq ITM (car GRP))
  26.       (if (= (car ITM) 3)
  27.         (setq NAM  (cdr ITM)
  28.               GRP  (cdr GRP)
  29.               ITM  (car GRP)
  30.               ENT  (cdr ITM)
  31.               GRP  (cdr GRP)
  32.               GLST
  33.                    (if GLST
  34.                      (append GLST (list (cons ENT NAM)))
  35.                      (list (cons ENT NAM))
  36.                    )
  37.         )
  38.         (setq GRP (cdr GRP))
  39.       )
  40.     )
  41.     GLST
  42.   )
  43.   (defun ACET-TXTEXP-GETGNAME (ENT GLST / GRP GDATA NAM NLST)
  44.     (if        (and GLST (listp GLST))
  45.       (progn
  46.         (foreach GRP GLST
  47.           (setq GDATA (entget (car GRP)))
  48.           (foreach ITM GDATA
  49.             (if        (and
  50.                   (= (car ITM) 340)
  51.                   (eq (setq NAM (cdr ITM)) ENT)
  52.                 )
  53.               (setq NLST
  54.                      (if NLST
  55.                        (append NLST (list (cons (car GRP) (cdr GRP))))
  56.                        (list (cons (car GRP) (cdr GRP)))
  57.                      )
  58.               )
  59.             )
  60.           )
  61.         )
  62.       )
  63.     )
  64.     NLST
  65.   )
  66.   (if (and
  67.         (equal (car (getvar "viewdir")) 0 0.00001)
  68.         (equal (cadr (getvar "viewdir")) 0 0.00001)
  69.         (> (caddr (getvar "viewdir")) 0)
  70.       )
  71.     (progn
  72.       (setq GLST  (ACET-TXTEXP-GRPLST)
  73.             GDICT (if GLST
  74.                     (dictsearch (namedobjdict) "ACAD_GROUP")
  75.                   )
  76.             CNT          0
  77.       )
  78.       (if SS
  79.         (setq SS (car (BNS_SS_MOD SS 1 t)))
  80.       )
  81.       (if SS
  82.         (progn
  83.           (setq CNT 0)
  84.           (while (setq ENT (ssname SS CNT))
  85.             (and
  86.               GLST
  87.               (setq GNAM (ACET-TXTEXP-GETGNAME ENT GLST))
  88.               (foreach GRP GNAM
  89.                 (command "_.-group"
  90.                          "_r"
  91.                          (cdr GRP)
  92.                          ENT
  93.                          ""
  94.                 )
  95.               )
  96.             )
  97.             (setq TBX (ACET-GEOM-TEXTBOX (entget ENT) 0))
  98.             (setq TBX (mapcar '(lambda (X)
  99.                                  (trans X 1 0)
  100.                                )
  101.                               TBX
  102.                       )
  103.             )
  104.             (setq PTLST (append PTLST TBX))
  105.             (setq CNT (1+ CNT))
  106.           )
  107.           (setq        PTLST (mapcar '(lambda (X)
  108.                                  (trans X 0 1)
  109.                                )
  110.                               PTLST
  111.                       )
  112.           )
  113.           (if (setq ZM (ACET-GEOM-ZOOM-FOR-SELECT PTLST))
  114.             (progn
  115.               (setq ZM
  116.                      (list
  117.                        (list (- (caar ZM) (ACET-GEOM-PIXEL-UNIT))
  118.                              (- (cadar ZM) (ACET-GEOM-PIXEL-UNIT))
  119.                              (caddar ZM)
  120.                        )
  121.                        (list (+ (caadr ZM) (ACET-GEOM-PIXEL-UNIT))
  122.                              (+ (cadadr ZM) (ACET-GEOM-PIXEL-UNIT))
  123.                              (caddr (cadr ZM))
  124.                        )
  125.                      )
  126.               )
  127.               (command "_.zoom" "_w" (car ZM) (cadr ZM))
  128.             )
  129.           )
  130.           (setq        VIEW   (ACET-GEOM-VIEW-POINTS)
  131.                 TMPFIL (strcat (getvar "tempprefix") "txtexp.wmf")
  132.                 PT1    (ACET-GEOM-MIDPOINT (car VIEW) (cadr VIEW))
  133.                 PT2    (list (car PT1) (cadadr VIEW))
  134.           )
  135.           (if (ACET-LAYER-LOCKED (getvar "clayer"))
  136.             (progn
  137.               (command "_.layer" "_unl" (getvar "clayer") "")
  138.               (setq LOCKED t)
  139.             )
  140.           )
  141.           (command "_.mirror"             SS              ""       PT1
  142.                    PT2            "_y"     "_.WMFOUT"               TMPFIL
  143.                    SS            ""
  144.                   )
  145.           (if (findfile TMPFIL)
  146.             (progn
  147.               (command "_.ERASE" SS "")
  148.               (setq SS (ACET-WMFIN TMPFIL))
  149.               (command "_.mirror" SS "" PT1 PT2 "_y")
  150.             )
  151.           )
  152.           (if LOCKED
  153.             (command "_.layer" "_lock" (getvar "clayer") "")
  154.           )
  155.           (if ZM
  156.             (command "_.zoom" "_p")
  157.           )
  158.           (prompt (acet-str-format
  159.                     "\n%1 text object(s) have been exploded to lines."
  160.                     CNT
  161.                   )
  162.           )
  163.           (prompt "\nThe line objects have been placed on layer 0.")
  164.         )
  165.       )
  166.     )
  167.     (prompt "\nView needs to be in plan (0 0 1).")
  168.   )
  169.   (ACET-ERROR-RESTORE)
  170.   (princ)
  171. )
  172. ;;;以上为txtexp
  173. (arxload "xdrx_api15" NIL)
  174. (setq HOLDECHO (getvar "CMDECHO"))
  175. (setvar "CMDECHO" 0)
  176. (if (not ACET-ERROR-INIT)
  177.   (load "acetutil")
  178. )
  179. (if (not (tblsearch "style" "标楷体"))
  180.   (progn
  181.     (setq HOLDTEXTSTYLE (getvar "TEXTSTYLE"))
  182.     (command "style" "标楷体" "标楷体" "0" "1" "0" "n" "n")
  183.     (setvar "TEXTSTYLE" HOLDTEXTSTYLE)
  184.     (setq HOLDTEXTSTYLE NIL)
  185.   )
  186. )
  187. (setvar "CMDECHO" HOLDECHO)
  188. (setq HOLDECHO NIL)
  189. (defun C:3D_TEXT (/ N A S1 S2 S3 SS SSL SH LL LLL)
  190.   (setq        SS (ssget '((-4 . "<AND")
  191.                     (-4 . "<OR")
  192.                     (0 . "MTEXT")
  193.                     (0 . "TEXT")
  194.                     (-4 . "OR>")
  195.                     (-4 . "<NOT")
  196.                     (102 . "{ACAD_REACTORS")
  197.                     (-4 . "NOT>")
  198.                     (-4 . "AND>")
  199.                    )
  200.            )
  201.   )
  202.   (command "_.VIEW" "S" "3D_TEXT")
  203.   (command "_.VIEW" "TOP")
  204.   (setq SSL (sslength SS))
  205.   (setq N 0)
  206.   (repeat SSL
  207.     (setq A (entget (ssname SS N)))
  208.     (setq SH (cdr (assoc 3 (tblsearch "style" (cdr (assoc 7 A))))))
  209.     (if        (/= "TTF" (strcase (substr SH (- (strlen SH) 2) 3)))
  210.       (progn
  211.         (setq A (subst (cons 7 "标楷体") (assoc 7 A) A))
  212.         (entmod A)
  213.       )
  214.     )
  215.     (setq N (1+ N))
  216.   )
  217.   (TXTEXP SS)
  218.   (command "_.VIEW" "R" "3D_TEXT")
  219.   (command "_.VIEW" "D" "3D_TEXT")
  220.   (c:xdrx_setmark)
  221.   (setq S2 (ssget "p"))
  222.   (command "_.region" S2 "")
  223.   (command "_.union" (c:xdrx_getss) "")
  224.   (setq S3 (ssget "P"))
  225.   (setq N 0)
  226.   (c:xdrx_setmark)
  227.   (command "_.select" S2 "")
  228.   (setq S2 (ssget "p" '((0 . "POLYLINE"))))
  229.   (if S2
  230.     (progn
  231.       (repeat (sslength S2)
  232.         (command "_.explode" (ssname S2 N))
  233.         (xdrx_curve_intersectbreak (ssget "p"))
  234.         (setq N (1+ N))
  235.       )
  236.       (setq S1 (c:xdrx_getss))
  237.     )
  238.   )
  239.   (c:xdrx_setmark)
  240.   (command "_.region" S1 "")
  241.   (setq S1 (c:xdrx_getss))
  242.   (if (ssget "p" '((0 . "LINE")))
  243.     (command "_.erase" (ssget "p" '((0 . "LINE"))) "")
  244.   )
  245.   (command "_.union" S1 S3 "")
  246.   (command "_.extrude" (ssget "p") "")
  247.   (princ)
  248. )
  249. (prompt "\nType 3d_text")
  250. (princ)
 楼主| 发表于 2002-3-14 03:59:36 | 显示全部楼层
为何回复时才看到下半截程序
发表于 2002-3-14 10:47:52 | 显示全部楼层
没贴完,好像版面出错了。
最好用文件附件。
发表于 2003-5-4 18:52:39 | 显示全部楼层
把未贴完的也贴上来吧
 楼主| 发表于 2003-5-5 14:29:10 | 显示全部楼层
档案太大不能贴完整,但第2贴不是有上传档案了吗?
发表于 2007-8-3 14:29:36 | 显示全部楼层
到底LISP完整吗?
发表于 2008-11-9 14:06:38 | 显示全部楼层
贴上来的代码不完整,下在附件是繁体版本的
发表于 2009-9-4 11:01:11 | 显示全部楼层
转成3D的有什么用?
发表于 2009-10-7 15:54:43 | 显示全部楼层
贴上来的代码不完整,不过做三维立体字也不难哈
发表于 2010-1-11 12:58:19 | 显示全部楼层
不知道效果怎么样?
发表于 2010-1-24 14:49:07 | 显示全部楼层
3D是何样呢
发表于 2014-7-5 18:27:51 | 显示全部楼层
好代码   先看看
发表于 2014-7-5 18:28:33 | 显示全部楼层
错误: LOAD 失败: "acetutil"
发表于 2015-2-1 11:34:11 | 显示全部楼层
回复看下,谢谢楼主分享
发表于 2017-10-13 09:26:08 | 显示全部楼层
;谢谢楼主 好像不全
GMT+8, 2026-11-22 09:52 , Processed in 0.338063 second(s), 38 queries , Gzip On, File On.
