查看: 1185|回复: 3
[LISP程序]:多功能序号球生成及编辑程序集
发表于 2004-11-16 11:31:24 | 显示全部楼层 |阅读模式
多功能序号球生成及编辑程序集(部分子程序前已贴出):
[PHP]
序号球生成程序一:
点击零件上点和序号球所在点, 循环生成由引线,号码和圆组成的序号球. 可选起始号码,字高,引线端部结构. 并具有后序球自动水平或垂直对其前一个序号球.
(defun generatenumball ()
  (setvar "osmode" 0)
  (setvar "orthomode" 0)
  (initget "A D N")
  (setq        kw (getkword "\nSelect Point Style[Arrow/Dot/None]: "))
  (if (null kw)(setq kw "A"))
  (setq ldr (getvar "DIMLDRBLK"))
  (cond
    ((= kw "A")(setvar "DIMLDRBLK" "."))
    ((= kw "D")(setvar "DIMLDRBLK" "dot"))
    ((= kw "N")(setvar "DIMLDRBLK" "none"))
  (setq sn (getint (strcat "\nType in Start Number:<1>")))
  (if sn nil (setq sn 1))
  (setq th0 (* 1.5 (getvar "dimscale")(getvar "dimtxt")))
  (setq th (getreal (strcat "\nHeight of Text: <" (rtos th0 2 2) ">")))
  (if th nil (setq th th0))
  (setq  r (* 1.2 th))
  (setq p0 (getpoint "\nInput point"))
  (while sn
    (if pe (setq pe0 pe))
    (setq pe (getpoint p0 "\nPick End Point"))
    (princ "\nItem Number or Break: n <")
    (princ sn)
    (setq sn0 (getstring ">:"))
    (if pe0
      (if (< (abs (- (car pe)(car pe0)))(abs (- (cadr pe)(cadr pe0))))
        (setq pe (list (car pe0)(cadr pe)))
        (setq pe (list (car pe)(cadr pe0)))
    (command "leader" p0 (polar pe (angle pe p0) r) "" "" "n")
    (vl-cmdf "circle"  pe r)
    (if (= (type inum) 'STR)(setq sn (atoi sn)))
    (vl-cmdf "text" "j" "m" pe th 0 (itoa sn) "")
    (setq p0 (getpoint "\nPick start Point"))
    (setq sn (1+ sn))
序号球生成程序二:
批量点击零件上诸点, 点击序号球希望所在直线两端点(水平或垂直) 自动等间隔生成序号球. 可选起始号码,字高,引线端部结构.
(defun batchnumball ( / p pl)
  (setvar "osmode" 0)
  (initget "A D N")
  (cond
  (setq  r (* 1.2 th))
  (while (setq p (getpoint "\nPick Point in Part: "))
    (setq pl (cons p pl))
  (setvar "orthomode" 1)
  (setq ps (getpoint "\nPick the First Point: "))
  (setq pe (getpoint ps "\nPick the First Point: "))
  (if (equal (cadr ps)(cadr pe) 0.0001)
    (setq pl (vl-sort pl '(lambda (p1 p2)(< (car p1)(car p2)))))
    (setq pl (vl-sort pl '(lambda (p1 p2)(< (cadr p1)(cadr p2)))))
  (if (or (> (car ps)(car pe))(> (cadr ps)(cadr pe)))
    (setq pl (reverse pl))
  (setq l (/ (distance ps pe)(1- (length pl))))
  (setq n 0)
  (while (< n (length pl))
    (vl-cmdf "circle" ps r)
    (vl-cmdf "text" "j" "m" ps th 0 (itoa (1+ n)) "")
    (setq pte (polar ps (angle ps (nth n pl)) r))
    (command "leader" (nth n pl) pte "" "" "n")
    (setq ps (polar ps (angle ps pe) l))
    (setq n (1+ n))
鼠标拖动编辑序号球:
框选序号球(单个)依鼠标点击位置整体移动序号球,引线自动伸缩且保持原点不变。
(defun dragnumball (/ leobj liobj)
  (vl-load-com)
  (setq loop t)
  (setq ss (ssget))
  (setq n 0)
  (while (< n (sslength ss))
    (setq obj (vlax-ename->vla-object (ssname ss n)))
    (setq oname (vla-get-ObjectName obj))
    (cond
      ((= oname "AcDbLeader")
       (setq leobj obj
             p1           (vlax-curve-getstartpoint (ssname ss n))))
      ((= oname "AcDbLine")
       (setq liobj obj
             p2           (vlax-curve-getendpoint (ssname ss n))))
      ((= oname "AcDbCircle")
       (setq ccobj obj
             pc           (cdr (assoc 10 (entget (ssname ss n))))))
      ((= oname "AcDbText") (setq ttobj obj))
    (setq n (1+ n))
  (if liobj
    (if        (< (distance p1 pc) (distance p2 pc))
      (setq p0 p1            p1 p2            p2 p0      )
  (while loop
    (setq p (grread T))
    (if        (= (car p) 3)      (setq loop nil)    )
    (vla-put-center ccobj (vlax-3d-point (cadr p)))
    (vla-put-textalignmentpoint ttobj (vlax-3d-point (cadr p)))
    (setq pc (vlax-safearray->list
               (vlax-variant-value (vla-get-center ccobj))             )
    (setq p2 (polar pc (angle pc p1) (vla-get-radius ccobj)))
    (cond
      (leobj
       (setq sl (vlax-make-safearray vlax-vbdouble '(0 . 5)))
       (setq sa (vlax-safearray-fill sl (append p1 p2)))
       (vla-put-coordinates leobj sa)
       (vla-update leobj)
      (liobj
       (vla-put-startpoint liobj (vlax-3d-point p1))
       (vla-put-endpoint liobj (vlax-3d-point p2))
       (vla-update liobj)
批量修改序号球引线端部结构:
(defun headtype ()
  (setq ss (ssget '((0 . "LEADER"))) n 0)
  (setq        at (getint "\nSelect New ArrowHeadType code: "))
    (vla-put-arrowheadtype obj (itoa at))
    (setq n (1+ n))
水平或垂直对齐序号球:
先点击参考点,框选序号球。
(defun alignnumball (/ lst tts ees)
  (vl-load-com)
  (setvar "osmode" 4)
  (setq pc0 (getpoint "\nPcik Alignment Point:"))
  (prompt "\nSelect NumberBall:")
  (setq ss (ssget) n 0)
  (setq al (getstring "\nSelect Alignment Style[Horizontal/Vertical] "))
  (if (or (null al)(= al ""))(setq al "H"))
  (setq cc (ssadd) tt (ssadd) ee (ssadd) ll (ssadd))
    (cond
       (ssadd (ssname ss n) ee))
       (ssadd (ssname ss n) ll))
       (ssadd (ssname ss n) cc))
       (ssadd (ssname ss n) tt))
    (setq n (1+ n))
  (if (= (strcase al) "H")
    (setq cc (acet-ss-sort cc 'getx) ee (acet-ss-sort ee 'getx)
          tt (acet-ss-sort tt 'getx) ll (acet-ss-sort ll 'getx))
    (setq cc (acet-ss-sort cc 'gety) ee (acet-ss-sort ee 'gety)
          tt (acet-ss-sort tt 'gety) ll (acet-ss-sort ll 'gety))
  (setq n 0)
  (while (< n (sslength cc))
    (setq obj (vlax-ename->vla-object (ssname cc n)))
    (setq pc (vtol (vla-get-center obj)))
      (setq pc1 (list (car pc)(cadr pc0)(last pc)))
      (setq pc1 (list (car pc0)(cadr pc)(last pc)))
    (vla-put-center obj (vlax-3d-point pc1))
    (vla-put-textalignmentpoint (vlax-ename->vla-object (ssname tt n))(vlax-3d-point pc1))
    (setq p1 (vlax-curve-getstartpoint (vlax-ename->vla-object (ssname ee n))))
    (setq p2 (polar pc1 (angle pc1 p1)(vla-get-radius obj)))
       (vla-put-coordinates (vlax-ename->vla-object (ssname ee n)) sa)
       (vla-update (vlax-ename->vla-object (ssname ee n)))
    (setq n (1+ n))
(defun vtol (v)(vlax-safearray->list (vlax-variant-value v)))
(defun getx (ent)(car (cdr (assoc 10 ent))))
(defun gety (ent)(cadr (cdr (assoc 10 ent))))
等间隔重新排列序号球:
框选序号球,提示缺省间隔值,可选间隔,自动依所选序号球趋于水平或垂直排列。
(defun arraynumball ()
  (vl-load-com)
    (cond
    (setq n (1+ n))
  (setq bb (acet-geom-ss-extents cc t))
  (setq x (- (car (cadr bb))(car (car bb))))
  (setq y (- (cadr (cadr bb))(cadr (car bb))))
  (setq r (cdr (assoc 40 (entget (ssname cc 0)))))
  (if (> x y)
           d0 (/ (- x r r )(1- (sslength cc))))
           d0 (/ (- y r r )(1- (sslength cc))))
  (setq d (getdist (strcat "\New Gap <" (rtos d0 2 2) "> :")))
  (if (or (null d)(= d ""))(setq d d0))
  (setq obj (vlax-ename->vla-object (ssname cc 0)))
  (setq pc0 (vtol (vla-get-center obj)))
  (setq n 1)
    (if (> x y)
      (setq pc1 (list (+ (car pc0) d)(cadr pc)(last pc)) pc0 pc1)
      (setq pc1 (list (car pc)(+ (cadr pc0) d)(last pc)) pc0 pc1)
    (setq n (1+ n))
  (setvar "osmode" 37)
序号球序号重新排序:
框选序号球,自动重新排列序号。可选起始方向,起始号码。
(defun sortnumball (/ ssl ttl)
  (setq ss (ssget '((0 . "TEXT"))) n 0)
    (setq ssl (cons (ssname ss n) ssl))
    (setq n (1+ n))
  (initget "L R T B")
  (setq        kw (getkword "\nSelect Start End[Left/Right/Top/Bottom]: "))
  (cond
    ((= kw "L")
      (setq ssl (vl-sort ssl '(lambda (p1 p2)(< (car (cdr (assoc 10 (entget p1))))
                                         (car (cdr (assoc 10 (entget p2)))))))))
    ((= kw "R")
      (setq ssl (vl-sort ssl '(lambda (p1 p2)(> (car (cdr (assoc 10 (entget p1))))
    ((= kw "B")
      (setq ssl (vl-sort ssl '(lambda (p1 p2)(< (cadr (cdr (assoc 10 (entget p1))))
                                    (cadr (cdr (assoc 10 (entget p2)))))))))
    ((= kw "T")
      (setq ssl (vl-sort ssl '(lambda (p1 p2)(> (cadr (cdr (assoc 10 (entget p1))))
  (setq ttl (vl-sort ssl '(lambda (p1 p2)(< (atoi (cdr (assoc 1 (entget p1))))
                                    (atoi (cdr (assoc 1 (entget p2))))))))
  (setq ns0 (cdr (assoc 1 (entget (car ttl)))))
  (setq ns (getint (strcat "\nStart Number<" ns0 ">:")))
  (if ns nil (setq ns (atoi ns0)))
  (setq n 0)
  (while (< n (length ssl))
    (setq obj (vlax-ename->vla-object (nth n ssl)))
    (vla-put-textstring obj (itoa (+ ns n)))
    (setq n (1+ n))
[/PHP]
发表于 2004-12-8 16:11:48 | 显示全部楼层
发表于 2004-12-9 16:13:05 | 显示全部楼层
太棒了!大大真是厲害!
发表于 2005-1-1 15:40:53 | 显示全部楼层
能说明一下吗怎么用?谢谢了。
GMT+8, 2026-11-3 06:58 , Processed in 0.608068 second(s), 38 queries , Gzip On.
