查看: 1300|回复: 14
[求助]:有谁用左手键的吗?
发表于 2004-12-4 13:50:42 | 显示全部楼层 |阅读模式
有用左手键的吗?
能不能把快捷键上传一下?在此先谢谢了~
发表于 2004-12-4 15:30:57 | 显示全部楼层
有相关的贴子搜一下
发表于 2004-12-4 16:44:35 | 显示全部楼层
控制面板里的鼠标
 楼主| 发表于 2004-12-5 11:26:51 | 显示全部楼层
;  AutoCAD Program Parameters File For AutoCAD Release 14
;  External Command and Command Alias Definitions
;  Copyright (C) 1997 by Autodesk, Inc.
;  Each time you open a new or existing drawing, AutoCAD searches
;  the support path and reads the first acad.pgp file that it finds.
;  While AutoCAD is running, you can invoke other programs or utilities,
;  such Windows system commands, utilities, and applications.
;  You define external commands by specifying a command name to be used
;  from the AutoCAD command prompt and an executable command string
;  that is passed to the operating system.
;  You can abbreviate frequently used AutoCAD commands by defining
;  aliases for them in the command alias section of acad.pgp.
;  You can create a command alias for any AutoCAD command,
;  device driver command, or external command.
;  Recommendation: back up this file before editing it.
;  There is a bonus application for editing command aliases as well as
;  a sample acad.pgp file with many more command aliases.
;  See the bonus\cadtools folder for more details.
;  External command format:
;  <Command name>,[<DOS request>],<Bit flag>,
  • <Prompt>,
    ;  The bits of the bit flag have the following meanings:
    ;  First bit (1): if set, don't wait for the application to finish
    ;  Second bit (2): if set, run the application minimized
    ;  Third bit (4): if set, run the application "hidden"
    ;  Bits 2 and 4 are mutually exclusive; if both are specified only the 2 bit is used.
    ;  The most useful values are likely to be 0 (start the application and wait
    ;  for it to finish), 1 (start the application and don't wait), 3 (minimize and don't
    ;  wait), and 5 (hide and don't wait). Values of 2 and 4 should normally be avoided,
    ;  as they make AutoCAD unavailable until the application has completed.
    ;  Examples of external commands for command windows
    CATALOG,   DIR /W,         0,File specification: ,
    DEL,       DEL,            0,File to delete: ,
    DIR,       DIR,            0,File specification: ,
    EDIT,      START EDIT,     1,File to edit: ,
    SH,        ,               1,*OS Command: ,
    SHELL,     ,               1,*OS Command: ,
    START,     START,          1,*Application to start: ,
    TYPE,      TYPE,           0,File to list: ,
    ; Examples of external commands for Windows
    ; See also the STARTAPP AutoLISP function for an alternative method.
    EXPLORER,  START EXPLORER, 1,,
    NOTEPAD,   START NOTEPAD,  1,*File to edit: ,
    PBRUSH,    START PBRUSH,   1,,
    ; Command alias format:
    ;   <Alias>,*<Full command name>
    ;  The following are guidelines for creating new command aliases.
    ;  1.  Try the first character of the command, then try the first two,
    ;         then the first three.
    ;  2.  Ignore "DD" at the beginning of a command.
    ;  3.  Abbreviate the following prefixes:
    ;        Examples: 3 for 3D, A for ASE, D for Dim, I for Image, R for render.
    ;  4.  Once an alias is defined, add suffixes for related aliases:
    ;        Examples: R for Redraw, RA for Redrawall, L for Line, LT for Linetype.
    ;  5.  An alias should reduce a command by at least two characters.
    ;  6.  Commands with a control key equivalent, status bar button, or function key
    ;        do not require a command alias.
    ;        Examples: Use Control-N, -O, -P, and -S for New, Open, Print, and Save
    ;  7.  Use a hyphen to differentiate between command line and dialog box commands.
    ;  8.  Exceptions to the rules include AA for Area, T for Mtext, X for Explode.
    ;  Sample aliases for AutoCAD commands
    ;  These examples include most frequently used commands.
    3A,        *3DARRAY
    3F,        *3DFACE
    3P,        *3DPOLY
    A,         *ARC
    AA,        *AREA
    AL,        *ALIGN
    AP,        *APPLOAD
    AR,        *ARRAY
    AAD,       *ASEADMIN
    AEX,       *ASEEXPORT
    ALI,       *ASELINKS
    ASQ,       *ASESQLED
    ARO,       *ASEROWS
    ASE,       *ASESELECT
    AT,        *DDATTDEF
    -AT,       *ATTDEF
    ATE,       *DDATTE
    -ATE,      *ATTEDIT
    B,         *BMAKE
    -B,        *BLOCK
    BH,        *BHATCH
    BO,        *BOUNDARY
    -BO,       *-BOUNDARY
    BR,        *BREAK
    C,         *CIRCLE
    CH,        *DDCHPROP
    -CH,       *CHANGE
    CHA,       *CHAMFER
    COL,       *DDCOLOR
    CO,        *COPY
    D,         *DDIM
    DAL,       *DIMALIGNED
    DAN,       *DIMANGULAR
    DBA,       *DIMBASELINE
    DCE,       *DIMCENTER
    DCO,       *DIMCONTINUE
    DDI,       *DIMDIAMETER
    DED,       *DIMEDIT
    DI,        *DIST
    DIV,       *DIVIDE
    DLI,       *DIMLINEAR
    DO,        *DONUT
    DOR,       *DIMORDINATE
    DOV,       *DIMOVERRIDE
    DR,        *DRAWORDER
    DRA,       *DIMRADIUS
    DST,       *DIMSTYLE
    DT,        *DTEXT
    DV,        *DVIEW
    E,         *ERASE
    ED,        *DDEDIT
    EL,        *ELLIPSE
    EX,        *EXTEND
    EXIT,      *QUIT
    EXP,       *EXPORT
    EXT,       *EXTRUDE
    F,         *FILLET
    FI,        *FILTER
    G,         *GROUP
    -G,        *GROUP
    GR,        *DDGRIPS
    H,         *BHATCH
    -H,        *HATCH
    HE,        *HATCHEDIT
    HI,        *HIDE
    I,         *DDINSERT
    -I,        *INSERT
    IAD,       *IMAGEADJUST
    IAT,       *IMAGEATTACH
    ICL,       *IMAGECLIP
    IM,        *IMAGE
    -IM,       *-IMAGE
    IMP,       *IMPORT
    IN,        *INTERSECT
    INF,       *INTERFERE
    IO,        *INSERTOBJ
    L,         *LINE
    LA,        *LAYER
    -LA,       *-LAYER
    LE,        *LEADER
    LEN,       *LENGTHEN
    LI,        *LIST
    LS,        *LIST
    LT,        *LINETYPE
    -LT,       *-LINETYPE
    LTS,       *LTSCALE
    M,         *MOVE
    MA,        *MATCHPROP
    ME,        *MEASURE
    MI,        *MIRROR
    ML,        *MLINE
    MO,        *DDMODIFY
    MS,        *MSPACE
    MT,        *MTEXT
    MV,        *MVIEW
    O,         *OFFSET
    OS,        *DDOSNAP
    -OS,       *-OSNAP
    P,         *PAN
    -P,        *-PAN
    PA,        *PASTESPEC
    PE,        *PEDIT
    PL,        *PLINE
    PO,        *POINT
    POL,       *POLYGON
    PR,        *PREFERENCES
    PRE,       *PREVIEW
    PRINT,     *PLOT
    PS,        *PSPACE
    PU,        *PURGE
    R,         *REDRAW
    RA,        *REDRAWALL
    RE,        *REGEN
    REA,       *REGENALL
    REC,       *RECTANGLE
    REG,       *REGION
    REN,       *DDRENAME
    -REN,      *RENAME
    REV,       *REVOLVE
    RM,        *DDRMODES
    RO,        *ROTATE
    RPR,       *RPREF
    RR,        *RENDER
    S,         *STRETCH
    SC,        *SCALE
    SCR,       *SCRIPT
    SE,        *DDSELECT
    SEC,       *SECTION
    SET,       *SETVAR
    SHA,       *SHADE
    SL,        *SLICE
    SN,        *SNAP
    SO,        *SOLID
    SP,        *SPELL
    SPL,       *SPLINE
    SPE,       *SPLINEDIT
    ST,        *STYLE
    SU,        *SUBTRACT
    T,         *MTEXT
    -T,        *-MTEXT
    TA,        *TABLET
    TH,        *THICKNESS
    TI,        *TILEMODE
    TO,        *TOOLBAR
    TOL,       *TOLERANCE
    TOR,       *TORUS
    TR,        *TRIM
    UC,        *DDUCS
    UCP,       *DDUCSP
    UN,        *DDUNITS
    -UN,       *UNITS
    UNI,       *UNION
    V,         *DDVIEW
    -V,        *VIEW
    VP,        *DDVPOINT
    -VP,       *VPOINT
    W,         *WBLOCK
    WE,        *WEDGE
    X,         *EXPLODE
    XA,        *XATTACH
    XB,        *XBIND
    -XB,       *-XBIND
    XC,        *XCLIP
    XL,        *XLINE
    XR,        *XREF
    -XR,       *-XREF
    Z,         *ZOOM
    ; The following are alternative aliases and aliases as supplied in AutoCAD Release 13.
    AV,        *DSVIEWER
    CP,        *COPY
    DIMALI,    *DIMALIGNED
    DIMANG,    *DIMANGULAR
    DIMBASE,   *DIMBASELINE
    DIMCONT,   *DIMCONTINUE
    DIMDIA,    *DIMDIAMETER
    DIMED,     *DIMEDIT
    DIMTED,    *DIMTEDIT
    DIMLIN,    *DIMLINEAR
    DIMORD,    *DIMORDINATE
    DIMRAD,    *DIMRADIUS
    DIMSTY,    *DIMSTYLE
    DIMOVER,   *DIMOVERRIDE
    LEAD,      *LEADER
    TM,        *TILEMODE
    ; The following support leftkey operation for the AutoCAD 2000
    ; Writen by zot
    A,         *ARC
    AD,        *ATTEDIT
    AA,        *AREA
    AG,        *ALIGN
    AP,        *APPLOAD
    AR,        *ARRAY
    AT,        *MATCHPROP
    ATT,       *ATTDEF
    AV,        *DSVIEWER
    ATD,       *ATTDISP
    BD,        *BOUNDARY
    BR,        *BREAK
    C,         *CIRCLE
    CA,        *CAL
    CC,        *COPY
    CF,        *CHAMFER
    CT,        *CUTCLIP
    CR,        *COLOR
    D,         *DDIM
    DA,        *DIMANGULAR
    DB,        *DIMBASELINE
    DC,        *DIMCONTINUE
    DD,        *DIMDIAMETER
    DE,        *DIMLINEAR
    DG,       *DIMALIGNED
    DRA,       *DIMRADIUS
    DS,       *DSETTINGS
    DT,       *DIST
    DV,       *DVIEW
    DZ,       *LEADER
    DF,       *DDINSERT
    DDF,      *DDATTDEF
    DW,       *DIVIDE
    E,        *ERASE
    ED,       *DDEDIT
    ES,       *ELLIPSE
    EG,       *LENGTHEN
    EX,       *EXTEND
    ER,       *LAYER
    EE,       *LINETYPE
    F,        *FILLET
    FC,       *POLYGON
    FD,       *OPEN
    FE,       *EXPORT
    FF,       *LINE
    FFF,      *MLINE
    FG,       *PLINE
    FGE,      *PEDIT
    FW,       *LINEWEITH
    FS,       *OFFSET
    FT,       *FILTER
    FV,       *MOVE
    FX,       *DDMODIFY
    G,        *GROUP
    R,       *PAN
    RW,      *REDRAW
    RA,      *RAY
    RD,      *REDO
    RE,      *REGEN
    REC,     *RECTANG
    RT,      *ROTATE
    RR,      *RENDER
    SA,    *SAVEAS
    SV,    *SAVE
    SC,    *SCALE
    SD,    *DDSELECT
    SS,    *SPLINE
    ST,    *STYLE
    T,       *TRIM
    TB,      *TOOLBAR
    TE,      *TOLERANCE
    TT,      *TEXT
    TTT,     *MTEXT
    V,        *UNDO
    VV,      *UNITS
    VW,       *VIEW
    W,        *WBLOCK
    WW,       *MIRROR
    WE,       *WEDGE
    X,       *EXPLODE
    XA,      *XATTACH
    XB,      *XBIND
    XC,      *XCLIP
    XX,      *XLINE
    Z,        *ZOOM
    ZA,       *ZOOMALL
    ZD,       *ZOOMDYNAMIC
    ZE,       *ZOOMEXTENTS
  • 论坛插件加载方法
    发表于 2004-12-5 13:26:53 | 显示全部楼层
    楼上的好像不完全是左手键吧?
    而且copy比circle用的多,应该copy设置为c ,circle设置为cc
    发表于 2005-3-24 21:20:29 | 显示全部楼层
    5楼说的似乎有点道理,不过,要看是哪行了,搞建筑的不多用圆,可搞机械的就有很多圆啊。3楼将mline的别名设为fff ,严重赞成!
    发表于 2005-3-24 22:07:10 | 显示全部楼层
    最初由 lee1789 发布
    [B]楼上的好像不完全是左手键吧?
    而且copy比circle用的多,应该copy设置为c ,circle设置为cc [/B]
    有道理啊。复制哪都离不了啊。
    发表于 2005-4-1 23:07:09 | 显示全部楼层
    呵呵,看看我的吧。
    ; Writen by FIVEPINE
    A,         *ARC
    AD,        *ATTEDIT
    AA,        *AREA
    AG,        *ALIGN
    AP,        *APPLOAD
    AR,        *ARRAY
    AT,        *MATCHPROP
    ATT,       *ATTDEF
    AV,        *DSVIEWER
    B,         *BLOCK
    BD,        *BOUNDARY
    BR,        *BREAK
    CC,         *CIRCLE
    CA,        *CAL
    C,        *COPY
    CE,        *ai_molc
    CF,        *CHAMFER
    CT,        *CUTCLIP
    CR,        *COLOR
    D,         *DIMSTYLE
    DA,        *DIMANGULAR
    DB,        *DIMBASELINE
    DC,        *DIMORDINATE
    DD,        *DIMDIAMETER
    DDT,       *DDPTYPE
    DE,        *DIMLINER
    DG,       *DIMALIGNED
    DR,       *DIMRADIUS
    DS,       *DSETTINGS
    DT,       *DIST
    DV,       *DVIEW
    DW,       *divide
    DZ,       *LEADER
    E,        *ERASE
    ED,       *DDEDIT
    ES,       *ELLIPSE
    EG,       *LENGTHEN
    EX,       *EXTEND
    ER,       *LAYER
    EE,       *LINETYPE
    F,        *LINE
    FC,       *POLYGON
    FD,       *OPEN
    FE,       *EXPORT
    FF,       *FILLET
    FG,       *PLINE
    FGE,      *PEDIT
    FW,       *LINEWEITH
    FFS,      *OFFSET
    FT,       *FILTER
    FV,       *MOVE
    FX,       *PROPERTIES
    G,        *GROUP
    R,       *PAN
    RW,      *REDRAW
    RA,      *RAY
    RD,      *REDO
    RE,      *REGEN
    REE,     *RENAME
    RC,      *RECTANG
    RT,      *ROTATE
    RR,      *RENDER
    SA,    *SAVEAS
    SV,    *SAVE
    SC,    *SCALE
    SD,    *DDSELECT
    SS,    *HATCH
    ST,    *STYLE
    T,       *TRIM
    TR,      *EXTRIM
    TB,      *TOOLBAR
    TE,      *TOLERANCE
    TT,      *TEXT
    TTT,    *MTEXT
    V,        *UNDO
    VV,      *UNITS
    VW,       *VIEW
    W,        *WBLOCK
    WW,       *MIRROR
    WE,       *WEDGE
    X,       *EXPLODE
    XA,      *XATTACH
    XB,      *XBIND
    XC,      *XCLIP
    XX,      *XLINE
    Z,        *ZOOM
    ZA,       *ZOOMALL
    ZD,       *ZOOMDYNAMIC
    ZE,       *ZOOMEXTENTS
    发表于 2005-4-5 00:02:23 | 显示全部楼层
    8楼说的很好
    发表于 2005-4-5 08:49:46 | 显示全部楼层 |阅读模式
    其实这样的定制还是适合自己才是最好的
    发表于 2005-4-5 21:04:53 | 显示全部楼层
    查找acad.pgp文件,里面都有
    发表于 2005-4-5 21:10:03 | 显示全部楼层
    最初由 lee1789 发布
    [B]楼上的好像不完全是左手键吧?
    感觉划圆还是必要的,就像圆规在手工图的作用一样;其实我的copy是设置为y的。
    发表于 2005-4-6 02:43:33 | 显示全部楼层
    8楼是用软件改的。名叫:AutoCAD速度训练教程
    发表于 2006-3-17 14:04:54 | 显示全部楼层
    如果使用的是TSSD2004版的,请尝试这个EXCEL文件,打开后按^G,执行里面的宏,则所有的命令都变成左手键了。
    发表于 2006-3-18 00:21:12 | 显示全部楼层
    14楼的下不了
    GMT+8, 2026-8-29 19:21 , Processed in 0.490212 second(s), 62 queries , Gzip On.
