查看: 419|回复: 0
[下载]:Autocad DWF Viewer 5 Install Error 解决了
发表于 2004-12-5 01:22:04 | 显示全部楼层 |阅读模式
折磨我仅一个星期,几近绝望之际,在Google搜了一下,居然在Autocad网站上也在讨论这个问题,下载了一个官方附件,终于搞定,注意,仅win98/me有这个错,我的winme初装也无问题,但用了德国优化软件TuneUp Utilities 2004后就出了错,无法安装,现贴出以资共享。
Posted by: jetstorm
Date: Sep/22/04 - 19:44 (GMT)
Windows 98SE, IE 6.0 SP1, MDAC 2.8.....receiving the following error when installing DWF Viewer 5.0: "0001\F7\DWFViewer.dll There was a problem registering this file. The installation will be cancelled"
How do I correct this????????
Reply From: Sriram Gopalakrishnan - Autodesk
Date: Sep/28/04 - 20:52 (GMT)
    Re: DWF Viewer Install Error
THIS IS FOR WINDOWS 98/ME SYSTEMS ONLY
Attached is a zip file that has a batch file.
Before running the batch file, make sure you run the installer and following
the
registration error when you get a Yes/No prompt to remove the files,
choose No (to keep the files).
Now, run the batch file as follows:
regadv5 [INSTALLDIR]
If you’ve installed to the default directory, you don’t need to specify
INSTALLDIR. If you are specifying a directory with spaces, you will need to
enclose it in double quotes.
Autodesk
GMT+8, 2026-10-21 15:58 , Processed in 0.454493 second(s), 32 queries , Gzip On.
