查看: 782|回复: 0
[求助] [求助]:很简单的动态标注,有点问题求教
发表于 2004-12-5 11:54:10 | 显示全部楼层 |阅读模式
这个可以实现动态标注,不过有点问题:就是在动态过程中按鼠标中键缩放时会发生多余的问题!帮帮忙看看
(defun c:m_bz(/ m_ent m_pt1 m_pt2)
  (setq m_pt1 (getpoint "\n基点:"))(princ m_pt1)
  (princ "\n标注位置点:")
  (setq m_ent nil);;必须
  (while (/= 3 (car (setq m_pt2 (grread T 5))))
        (if m_ent (progn (command "undo" "1")(command)))
            (command "undo" "BE")(command)
            (command "leader" m_pt1 (cadr m_pt2) "a" "标注文字" "")(command)
            (command "undo" "e")(command)
            (setq m_ent (entlast))
  (princ)
GMT+8, 2026-11-5 16:29 , Processed in 0.413881 second(s), 32 queries , Gzip On.
