查看: 1083|回复: 4
[LISP程序]:关于多义线偏移复制的程序
发表于 2004-12-9 15:55:00 | 显示全部楼层 |阅读模式
(defun c:oo (/ od ss_1 s1 s3 s2 sa sa1 ssK3 e)
  (Setvar "cmdecho" 0)
  (command "_undo" "g")
  (setq od (getvar 'offsetdist))
(princ "\n 请输入偏移复制距离<")
     (princ od)
     (princ ">")
        (setq od (getreal))
      (if od
    (setvar 'offsetdist od)
      (prompt "\n 请选择要偏移复制的图元")
    (SETQ ss_1 NIL)
    (WHILE (null ss_1)
      (setq ss_1 (entsel))
   (SETQ S1 (CaR SS_1))
  (redraw s1 3)
   (prompt "\n 请选择偏移复制方向")
  (setq s3 (getpoint))
(IF (= (cdr (assoc 0 (entget s1))) "LWPOLYLINE")
  (PROGN
    (setq s2 (CAR (cdr ss_1)))
   (setq sa (entlast))
    (command "_explode" s1)
  (setq sa1 (ssnamex (ssget s2)))
    (setq ssk3 (ssadd))
    (setq e (entnext sa))
    (ssadd e ssk3)
    (while e
      (setq e (entnext e))
      (if e
        (ssadd e ssk3)
(SETQ s1 (nth 1 (car sa1)))
   (command "_offset" "" s1 s3"")
(command "_pedit" s1"" "j" ssk3"")
(command)
(command "_undo" "e")
(princ)
发表于 2004-12-12 14:13:27 | 显示全部楼层
多重偏移
加载DCPY.lsp,运行DCPY。
发表于 2004-12-12 14:15:14 | 显示全部楼层
程序示意:
发表于 2004-12-12 23:06:53 | 显示全部楼层
多重偏移程序,支持比例尺!
地址见下!
发表于 2005-2-16 18:19:59 | 显示全部楼层
好用的复制命令,不知对spl线能否实现前后一样多的顶点数呢?
GMT+8, 2026-11-3 06:06 , Processed in 0.565179 second(s), 41 queries , Gzip On.
