查看: 868|回复: 2
[LISP函数]:实现自动于图上注上日期
发表于 2004-12-13 14:35:21 | 显示全部楼层 |阅读模式
; 编写: BDYCAD
; 时间: 2003-5-4
; 功能: 自动打字
(defun c:tf (/ CTABC DD DDP EL ELL ERASE FILE FPATH LIAN MODEL OSMODE RT SPOINT TP)
  (SETvar "CMDECHO" 0)
  (setq osmode (getvar "osmode"))
  (setvar "osmode" 0)
  (setq file   (strcase (getvar "dwgprefix")) ;---|
el     (STRCASE (getvar "dwgname")) ;       |
ctabc  (getvar "ctab")
MODEL  (STRCAT "Model")
;;FILE (STRCASE (GETvar "SAVENAME"));; -|
dd     (strcat "File in the CAD layout :" ctabc)
ell    (strcase (getvar "loginname"))
;;;提取电脑号码(电脑名称)
fpath  (strcat "File search path is: " ell "- " file el)
     ;fi le)
rt     (rtos (getvar "cdate") 2 6)
;;;; get the time or date
lian   (strcat "Draw date:"
         (substr rt 7 2)
         (substr rt 5 2)
         (substr rt 1 4)
spoint (GETPOINT
   "\n现在运行写文件路径程序,请点选或输入文件路径放置起点﹕"
tp     (list (car spoint) (- (cadr spoint) 5))
ddp    (list (car tp) (- (cadr tp) 5))
  (if (= ctabc MODEL)
    (SETQ dd (strcat "File in the Auto CAD MODEL"))
  (command "text" spoint "2.5" "" fpath)
  (command "text" tp "" "" dd)
  (command "text" ddp "" "" LIAN)
  (command "circle" "0,0" "6")
  (setq erase (entlast))
  (command "erase" erase "")
  (SETvar "CMDECHO" 1)
  (setvar "osmode" osmode)
  (princ)
发表于 2004-12-19 18:09:17 | 显示全部楼层
高手 程序不错 很使用 比打印标戳好使 :)
发表于 2004-12-21 21:39:51 | 显示全部楼层
我正好在找这个
GMT+8, 2026-11-5 16:33 , Processed in 0.372850 second(s), 36 queries , Gzip On.
