查看: 1295|回复: 5
[LISP函数]:实现自动于图上注上日期
发表于 2004-12-13 14:51:58 | 显示全部楼层 |阅读模式
; 编写: BDYCAD
; 时间: 2003-5-4
; 功能: 自动打字
(defun c:tf (/ CTABC DD DDP EL ELL ERASE FILE FPATH LIAN MODEL OSMODE RT SPOINT TP)
  (SETvar "CMDECHO" 0)
  (setq osmode (getvar "osmode"))
  (setvar "osmode" 0)
  (setq file   (strcase (getvar "dwgprefix")) ;---|
el     (STRCASE (getvar "dwgname")) ;       |
ctabc  (getvar "ctab")
MODEL  (STRCAT "Model")
;;FILE (STRCASE (GETvar "SAVENAME"));; -|
dd     (strcat "File in the CAD layout :" ctabc)
ell    (strcase (getvar "loginname"))
;;;提取电脑号码(电脑名称)
fpath  (strcat "File search path is: " ell "- " file el)
     ;fi le)
rt     (rtos (getvar "cdate") 2 6)
;;;; get the time or date
lian   (strcat "Draw date:"
         (substr rt 7 2)
         (substr rt 5 2)
         (substr rt 1 4)
spoint (GETPOINT
   "\n现在运行写文件路径程序,请点选或输入文件路径放置起点﹕"
tp     (list (car spoint) (- (cadr spoint) 5))
ddp    (list (car tp) (- (cadr tp) 5))
  (if (= ctabc MODEL)
    (SETQ dd (strcat "File in the Auto CAD MODEL"))
  (command "text" spoint "2.5" "" fpath)
  (command "text" tp "" "" dd)
  (command "text" ddp "" "" LIAN)
  (command "circle" "0,0" "6")
  (setq erase (entlast))
  (command "erase" erase "")
  (SETvar "CMDECHO" 1)
  (setvar "osmode" osmode)
  (princ)
发表于 2004-12-13 23:20:18 | 显示全部楼层
我试过了,非常好
楼主对系统变量真是了解呀,值得学习
谢谢了
发表于 2004-12-14 10:14:52 | 显示全部楼层
  我觉得程序没有太大的用处。如果是要打印出来,可在打印机设置中完成此功能。文件路径在CAD标题栏就有。
  另外应该定义一种含有中文的字体,如果图名或路径中有中文,而当前字体不含有大字体的时候会出现乱码。
发表于 2005-2-25 10:03:58 | 显示全部楼层
谢谢,编目录时可省下时间了
发表于 2005-2-25 23:03:02 | 显示全部楼层
好用啊,不错的软体
发表于 2005-2-25 23:51:55 | 显示全部楼层
功能同1楼,增加可读性:
[php]
(defun c:test (/ osmode ctabe FPATH LIAN SPOINT TP ddp dd)
  (setvar "osmode" 0)
        fpath  (strcat "File search path is : "
                       (getvar "dwgname"))
        lian   (strcat "Draw date : " (menucmd "M=$(edtime,$(getvar,date),YYYY.M.D)"))
        spoint (GETPOINT "\n请点选放置起点 : ")
  (if (= ctabc "Model")
    (setq dd (strcat "File in the CAD layout :" ctabc))
  (COMMAND "style" "仿宋" "仿宋_GB2312" "2.5" "1" "0" "" "")
  (command "text" "j" "ml" spoint 0 fpath)
  (command "text" "j" "ml" tp 0 dd)
  (command "text" "j" "ml" ddp 0 LIAN)
  (princ)
[/php]
GMT+8, 2026-11-5 22:54 , Processed in 0.432589 second(s), 42 queries , Gzip On.
