查看: 924|回复: 1
[求助] [求助]:如何在VLISP中用代码修改对象特性properties的子项?
发表于 2004-12-20 22:05:40 | 显示全部楼层 |阅读模式
用properties命令或工具栏按钮可以查看或修改选定对象特性的子项,比如线型、线宽等,那么怎么实现在程序中用代码来修改选定对象特性的子项呢?恳请高手赐招。。。
发表于 2004-12-21 01:18:50 | 显示全部楼层
Sets the property of an ActiveX object
(vlax-put-property obj property arg)
This function was formerly known as vlax-put.
Arguments
obj
A VLA-object.
property
A symbol or string naming the property to be set.
arg
The value to be set.
Return Values
Nil, if successful.
Examples
Color an object red:
_$ (vlax-put-property vlaobj 'Color 1)
nil
GMT+8, 2026-11-5 14:40 , Processed in 0.466586 second(s), 34 queries , Gzip On.
