查看: 806|回复: 0
[求助]:用过MFC和ARX帮一下忙
发表于 2004-12-30 22:06:42 | 显示全部楼层 |阅读模式
看看我的问题错在哪里了
#include "stdafx.h"
#include "AsdkAcUiSample.h"
#include "AsdkAcUiDialogSample.h"
#include "AcExtensionModule.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
extern "C" HWND adsw_acadMainWnd();
// Define the sole extension module object.
AC_IMPLEMENT_EXTENSION_MODULE(theArxDLL);
static void initApp()
CAcModuleResourceOverride resOverride;
static void unloadApp()
extern "C" int APIENTRY
DllMain(HINSTANCE hInstance, DWORD dwReason, LPVOID lpReserved)
UNREFERENCED_PARAMETER(lpReserved);
if (dwReason == DLL_PROCESS_ATTACH)
{ theArxDLL.AttachInstance(hInstance); } //这里出错,是什么原因
else if (dwReason == DLL_PROCESS_DETACH)
{ theArxDLL.DetachInstance(); }
return 1; // ok
extern "C" AcRx::AppRetCode acrxEntryPoint( AcRx::AppMsgCode msg, void* appId)
switch( msg )
case AcRx::kInitAppMsg:
acrxDynamicLinker->unlockApplication(appId);
acrxDynamicLinker->registerAppMDIAware(appId);
initApp();
break;
case AcRx::kUnloadAppMsg:
unloadApp();
break;
case AcRx::kInitDialogMsg:
break;
default:
break;
return AcRx::kRetOK;
有可能是设置出错,但我参照帮助文档资料,和里面的设置一样,仍旧不行,请指教!
GMT+8, 2026-11-3 08:53 , Processed in 0.485808 second(s), 32 queries , Gzip On.
