查看: 1396|回复: 8
[求助] [求助]:老问题了,对话框的嵌套
发表于 2005-1-25 15:07:04 | 显示全部楼层 |阅读模式
tushi: dialog{label= "图示";
   :image
  {  key="sld" ;
  aspect_ratio=0.8;
  width=40;
   color=-2;
: button {
    label = "关闭";
    key = "hide";
   ok_only;
t:dialog{label="嵌套窗口";
  : button {
    label = "显示";
    is_cancel = true;
    key = "show";
    width = 12;
    fixed_width = true;}
    ok_cancel;
;**************以上为DCL内容
(defun c:qq ()
  (defun tushi_show ()
    (new_dialog "tushi" dcl_id)
    (action_tile "hide" "(done_dialog 2)")
    (start_dialog)
  (setq dcl_id (load_dialog "ssk"))
  (new_dialog "t" dcl_id)
  (action_tile "show" "(tushi_show)")
  (start_dialog)
;**************以上为LSP内容
每次要关闭嵌套的对话框,程序就会关闭
实在找不着原因,请大侠帮助
发表于 2005-1-25 15:30:31 | 显示全部楼层
  1. (defun c:qq ()
  2.   (defun tushi_show ()
  3.     (new_dialog "tushi" dcl_id)
  4.     (action_tile "hide" "(done_dialog 2)")
  5.     (start_dialog)
  6.   )
  7.   (setq aa 1)
  8.   (setq dcl_id (load_dialog "ssk"))
  9.   (while (< aa 3)
  10.     (new_dialog "t" dcl_id)
  11.     (action_tile "show" "(tushi_show)")
  12.     (action_tile "accept" "(unload_dialog dia_id)")
  13.     (setq aa (start_dialog))
  14.   )
  15. )
 楼主| 发表于 2005-1-25 15:45:23 | 显示全部楼层
那我这到底是什么原因呢?
ts1:dialog{
   label="测试对话框";
   :button{ label="新对话框";key="ts1";}
   ok_cancel;
ts2:dialog{
   label="测试对话框";
   :edit_box{label="测试";key="box";}
   :button{label="&sup1;关闭;key="dn2";}
   ok_cancel;
LISP文件:
(defun c:ts ()
  (defun newdlg ()
    (new_dialog "ts2" dcl_id)
    (set_tile "box" "测试文件")
    (action_tile "dn2" "(done_dialog 2)")
    (start_dialog)
  (setq dcl_id (load_dialog "ts1"))
  (new_dialog "ts1" dcl_id)
  (action_tile "ts1" "(newdlg)")
  (start_dialog)
这是晓东上以前的一个帖子,很正常
我的为什么就不行啊?
还有:楼上这位仁兄,像你那样的话,第一个对话框的内容就会恢复为原始值,请教怎么解决。
已领礼包: 488个
发表于 2005-1-25 23:15:10 | 显示全部楼层
讲了很多次了:
退出对话框时保存数据,就是把该保留的读出来保存到变量(基本是get_tile)
等再要对话框时,再加入你保存的数据.
(setq abc "...") ;;;你肯定有个要加入初始值的
(defun save()...(setq abc(get_tile ...)) ...(done_dialog 0) ...) ;;;这是要退出时作保存
(defun add() ...(set_tile ... abc) ...);;;有对话时加入数据
(add)  ;;;不管什么时候进去,肯定要加入数据
(action_tile "hide" "(save)");;;暂时退出时,新数据保存进变量
 楼主| 发表于 2005-1-26 12:15:23 | 显示全部楼层
这是zhynt以前的程序
bg : dialog {
   label = "标高标注设置 <作者:张越 2000.6.12>";
     : column {
          : row {
          : boxed_column {
             label = "基准点:";
            : button {
               label = "基准点:〈";
               key = "pick";
           : edit_box {
               label = "起始标高:";
               key = "ssbg";
         : boxed_column {
         label = "标高值:";
          fixed_width = true ;
            : toggle {
               label = "手工输入标高值";
                 key = "yn";
            : edit_box {
            label = "标高值:";
            is_enabled = false;
            key = "bgz";
            : row {
             : boxed_column {
              label = "比例:";
            : edit_box {
              label = "作图比例:";
              key = "scale1";
              value = "100";
            : edit_box {
              label = "图纸比例:";
              key = "scale2";
              value = "100";
            : boxed_column {
            label = "标高式样:";
          // fixed_width = true ;
            : toggle {
               label = "画出引出线";
               key = "yt";
            : toggle {
               label = "使之与基线平行";
          //fixed_width = true ;
               key = "ym";
         : boxed_column {
         label = "选择字型:";
            : popup_list {
              label = "选择字型:";
              key = "styl";
               fixed_height = true;
            : concatenation {
                : text_part {
                    label = "当前字型:";
                    width = 10;
                 : text_part {
                   key = "csty";
                   width = 10;
       spacer;
      : row {
          ok_cancel;
          : button {
             label = "说明(&H)";
              fixed_width = true;
              key = "shuoming";
          spacer;
shuoming : dialog{
      label= "简要说明";
             : column {
                : button  {
                   label = "基准点";
                   key = "shuom1";
                : button  {
                   label = "手工输入标高";
                   key = "shuom2";
                : button  {
                   label = "作图比例";
                   key = "shuom3";
                : button  {
                   label = "图纸比例";
                   key = "shuom4";
                : button  {
                   label = "选择字型";
                   key = "shuom5";
                : button  {
                   label = "使之与基线平行";
                   key = "shuom6";
                ok_only;
shuom1 : dialog {
      label= "简要说明";
     : boxed_column {
      label= "基准点说明";
        fixed_widht = true;
        : text {
           label = " 用于设置基准标高值的位置。";
     ok_only;
shuom2 : dialog {
      label= "简要说明";
     : boxed_column {
      label= "手工标高输入说明";
        fixed_widht = true;
        : text {
           label = " 打开时程序将提示你输入标高值。";
        : text {
           label = " 有记忆功能。";
        : text {
           label = " 关闭时程序将直接画出插入点的标高。";
     ok_only;
shuom3 : dialog {
      label= "简要说明";
     : boxed_column {
      label= "作图比例说明";
        fixed_widht = true;
        : text {
           label = " 即你所要进行标注的大样图或立面图的比例。";
     ok_only;
shuom4 : dialog {
      label= "简要说明";
     : boxed_column {
        label= "图纸比例说明";
        fixed_widht = true;
        : text {
           label = " 即出图时所用的比例。";
     ok_only;
shuom5 : dialog {
label= "简要说明";
: boxed_column {
label= "选择字型说明";
fixed_widht = true;
: text {
label = " 即画标高时所用的字型。";
ok_only;
shuom6 : dialog {
label= "简要说明";
: boxed_column {
label= "与基线平行说明";
fixed_widht = true;
: text {
label = " 用于水暖作图时,将标高方向同管道。";
ok_only;
;;;       |             标高自动标注软件                 |
;;;       |         版本: V4.0   作者: 张越 (99.7.9-29)  |
;;;       |         修改于2000.6                         |
(defun C:bg (/           dx         dy    dx1   dx2   dy1         pt    txt   txt2
             oldsty         lay   pt1   pt2   pt3         pt4   pt5   ptt
             sc1   sc2
(defun dxf (code elist)
  (cdr (assoc code elist))
  (setvar "CMDECHO" 0)
  (setq lay (getvar "clayer"))
  (command "color" "bylayer")
  (if (= nil (tblsearch "layer" "wz"))
    (command "layer" "m" "wz" "c" "7" "" "")
  (if (= nil (tblsearch "layer" "bg"))
    (command "layer" "m" "bg" "c" "9" "" "")
  (if (not ztsc)
    (progn
      (alert
        "    您还没有进行必要的设置\n工作,请先使用“sbg”命令。\n祝您工作愉快!\n\n
----------------作者:张越"
      (exit)
  (setq sc1 (atoi tzsc))
  (setq sc2 (/ (atof ztsc) 100))
  (setq os (getvar "osmode"))
  (setvar "osmode" 547)
  (if (= ym1 "1")
    (progn
      (setq obline (car (entsel "请选择一条基准线")))
      (command "ucs" "OB" obline)
  (setq pt (getpoint "\n插入点: "))
  (setvar "osmode" 0)
  (setq orth (getvar "orthomode"))
  (setvar "orthomode" 0)
  (setq ang (getangle pt "\n方向 <用鼠标指取,直接回车为右上>:"))
  (if (= ang nil)
    (setq ang 0.5)
  (setvar "orthomode" orth)
  (if (= ssbg nil)
    (setq ssbg1 0.000)
    (setq ssbg1 (atof ssbg))
  (if (= yn1 "1")
    (progn
      (prompt "\n输入标高值<")
      (prompt bgz1)
      (setq txt2 (getstring ">"))
      (if (= txt2 "")
        (setq txt2 bgz1)
        (setq bgz1 txt2)
      (if (or (= txt2 "0") (= txt2 "0.000"))
        (setq txt2 "%%1290.000")
    (progn
      (if (= opt nil)
        (progn
          (setq opt pt)
          (setq ypt (cadr opt))
          (setq xpt (car opt))
      (setq dy (- (cadr pt) ypt))
      (setq txt (+ (* (/ dy (* sc1 10)) sc2) ssbg1))
      (setq txt2 (rtos txt 2 3))
      (if (or (= txt2 "0.000") (= txt2 "0"))
  (setq pt1 (polar pt 3.14159 (* 6 sc1)))
  (setq pt2 (polar pt 0 (* 3 sc1)))
  (setvar "clayer" "bg")
  (if (= yt1 "1")
    (command "line" pt1 pt2 "")
  (if (/= sty0 nil)
    (setvar "textstyle" sty0)
  (cond
    ((and (> ang 0)
          (< ang (/ pi 2))
     (setq pt4 (polar pt 0.785398 (* 3.5 sc1)))
     (setq pt3 (polar pt 2.356194 (* 3.5 sc1)))
     (setq pt5 (polar pt3 0 (* 15 sc1)))
     (setq ptt (polar pt5 2.094395 (* 1.1547 sc1)))
     (setq high (* 3 sc1))
     (setvar "clayer" "wz")
     (command "text" "r" ptt high "0" txt2)
    ((and (> ang 4.88691)
          (< ang 6.283185)
     (setq pt4 (polar pt 5.497787 (* 3.5 sc1)))
     (setq pt3 (polar pt 3.926991 (* 3.5 sc1)))
     (setq ptt (polar pt5 4.188790 (* 1.1547 sc1)))
     (command "text" "tr" ptt high "0" txt2)
    ((and (> ang (/ pi 2))
          (< ang pi)
     (setq pt3 (polar pt 0.785398 (* 3.5 sc1)))
     (setq pt4 (polar pt 2.356194 (* 3.5 sc1)))
     (setq pt5 (polar pt3 pi (* 15 sc1)))
     (setq ptt (polar pt5 1.047198 (* 1.1547 sc1)))
     (command "text" ptt high "0" txt2)
    ((and (> ang 3.141593)
          (< ang 4.886922)
     (setq pt4 (polar pt 3.926991 (* 3.5 sc1)))
     (setq pt3 (polar pt 5.497787 (* 3.5 sc1)))
     (setq ptt (polar pt5 5.325988 (* 1.1547 sc1)))
     (command "text" "tl" ptt high "0" txt2)
  (setq ww (getvar "plinewid"))
  (setvar "plinewid" 0)
  (command "pline" pt4 pt pt3 pt5 "")
  (setvar "plinewid" ww)
  (setvar "clayer" lay)
  (setvar "osmode" os)
  (IF (= ym1 "1")
    (COMMAND "UCS" "")
  (princ)
;;;;;              初始值设置
(defun c:sbg (/ whet_next dia_id sty_zh opt osan)
  (defun style ()
    (setq n (atoi (get_tile "styl")))
    (setq sty (nth n stytab))
    (setq sty0 sty)
    (set_tile "csty" sty)
(defun fdzx (/ sty1 sty2 first tab sm1 sm2)
  (setq first T)
  (setq tab '())
  (setq stytab '())
  (setq sty_zh '())
  (while (setq sty1 (tblnext "style" first)) ;搜索图中字型
    (if        (= first T)
      (setq first nil)
    (if        (/= sty1 nil)
      (progn
        (setq tab (cons sty1 tab))
        (setq sty1 (nth 0 tab))
        (setq sty2 (dxf 2 sty1))        ;字型名称
        (setq sm1 (dxf 3 sty1))                ;所用小字体文件的名称
        (setq sm2 (dxf 4 sty1))                ;所用大字体文件的名称
        (setq stytab (cons sty2 stytab))
        (if (and sm2 (/= sm2 ""))
          (setq sty_zh (cons (strcat sty2 " : < " sm1 " , " sm2 " >") sty_zh))
          (setq sty_zh (cons (strcat sty2 " : < " sm1 " >") sty_zh))
  (defun bgzh ()
    (setq yn1 (get_tile "yn"))
    (if        (= yn1 "1")
      (progn
        (mode_tile "pick" 1)
        (mode_tile "ssbg" 1)
        (mode_tile "bgz" 0)
      (progn
        (mode_tile "pick" 0)
        (mode_tile "ssbg" 0)
        (mode_tile "bgz" 1)
  (defun shuo ()
    (if        (not (new_dialog "shuoming" dia_id))
      (exit)
    (action_tile "shuom1" "(shuo1)")
    (action_tile "shuom2" "(shuo2)")
    (action_tile "shuom3" "(shuo3)")
    (action_tile "shuom4" "(shuo4)")
    (action_tile "shuom5" "(shuo5)")
    (action_tile "shuom6" "(shuo6)")
    (action_tile "accept" "(done_dialog 6)")
    (start_dialog)
  (defun shuo1 ()
    (if        (not (new_dialog "shuom1" dia_id))
      (exit)
    (start_dialog)
  (defun shuo2 ()
    (if        (not (new_dialog "shuom2" dia_id))
      (exit)
    (start_dialog)
  (defun shuo3 ()
    (if        (not (new_dialog "shuom3" dia_id))
      (exit)
    (start_dialog)
  (defun shuo4 ()
    (if        (not (new_dialog "shuom4" dia_id))
      (exit)
    (start_dialog)
  (defun shuo5 ()
    (if        (not (new_dialog "shuom5" dia_id))
      (exit)
    (start_dialog)
  (defun shuo6 ()
    (if        (not (new_dialog "shuom6" dia_id))
      (exit)
    (start_dialog)
  (fdzx)
  (setq sty0 (getvar "textstyle"))
  (setq oldsty sty0)
  (setq whet_next 6)
  (if (and (not dia_id) (< (setq dia_id (load_dialog "bg")) 0))
    (exit)
  (while (< 2 whet_next)
    (if        (not (new_dialog "bg" dia_id))
      (exit)
    (if        (= ssbg nil)
      (set_tile "ssbg" "0.000")
      (set_tile "ssbg" ssbg)
    (if        (= ztsc nil)
      (progn
        (set_tile "scale1" "100")
        (setq ztsc "100")
      (set_tile "scale1" ztsc)
    (if        (= tzsc nil)
      (progn
        (set_tile "scale2" "100")
        (setq tzsc "100")
      (set_tile "scale2" tzsc)
    (if        (= yn1 nil)
      (set_tile "yn" "0")
      (set_tile "yn" yn1)
    (if        (= yn1 "1")
      (progn
        (mode_tile "bgz" 0)
    (if        (= yt1 nil)
      (set_tile "yt" "0")
      (set_tile "yt" yt1)
    (if        (= ym1 nil)
      (set_tile "ym" "0")
      (set_tile "ym" ym1)
    (if        (= bgz1 nil)
      (progn
        (set_tile "bgz" "0.000")
        (setq bgz1 "0.000")
      (set_tile "bgz" bgz1)
    (action_tile "pick" "(done_dialog 4)")
    (action_tile "ssbg" "(setq ssbg $value)")
    (action_tile "yn" "(bgzh)")
    (ACTION_TILE "yt" "(SETQ yt1 $VALUE)")
    (ACTION_TILE "ym" "(setq ym1 $VALUE)")
    (action_tile "bgz" "(setq bgz1 $value)")
    (action_tile "scale1" "(setq ztsc $value)")
    (action_tile "scale2" "(setq tzsc $value)")
    (start_list "styl")                        ;字型列表
    (mapcar 'add_list sty_zh)
    (end_list)
    (setq n (- (length stytab) (length (member sty0 stytab))))
    (set_tile "styl" (itoa n))                ;聚焦在所用字型上
    (action_tile "styl" "(style)")
    (if        (= sty nil)
      (set_tile "csty" sty0)
    (action_tile "shuoming" "(shuo)")
    (action_tile "accept" "(done_dialog 1)")
    (action_tile "cancel" "(unload_dialog dia_id)")
                                        ;(action_tile "erase" "(done_dialog 0)(setq ztsc nil)
                                        ;                     (setq tzsc nil)(setq ypt nil)(setq xpt nil)")
    (setq whet_next (start_dialog))
    (if        (/= sty nil)
      (setvar "textstyle" sty)
    (if        (= whet_next 4)
      (progn
        (setq osan (getvar "osmode"))
        (setvar "osmode" 512)
        (setq opt (getpoint "\n选择基准点:"))
        (setvar "osmode" osan)
发表于 2005-1-26 12:30:11 | 显示全部楼层
那你看看我现在怎么做的
http://www.xdcad.net/forum/showt ... 39&pagenumber=2
就是那个画曲线的程序,里面有一个嵌套对话框。
打开第二个对话框时,第一个消失,将第二个关闭后第一个又会出现,且数据会根据第二个的执行情况更新。
 楼主| 发表于 2005-1-26 15:57:57 | 显示全部楼层
谢谢两位仁兄了。
兄弟到底可以实现了
可是真的加了好多行语句!
谢谢!
发表于 2005-1-28 02:14:10 | 显示全部楼层
你可以调用doslib对话框来嵌套,比较简单。
 楼主| 发表于 2005-1-28 12:11:53 | 显示全部楼层
能举个例子吗?
GMT+8, 2026-11-6 02:41 , Processed in 0.522136 second(s), 48 queries , Gzip On.
