查看: 1196|回复: 17
[求助]:安了理正试用版,功能都不能用,这是为什么?就是这样的吗
发表于 2005-2-25 16:28:05 | 显示全部楼层 |阅读模式
我是在XP系统下的,安是安好了,但功能都不能用,这是为什么?就是这样的吗?
发表于 2005-2-25 21:57:43 | 显示全部楼层
XP安装没问题的!是不是在管理员下安装的?
发表于 2005-2-25 22:01:45 | 显示全部楼层
肯定是可以用的,否则没这么多的用户了!!
安装运行进入界面,如不能使用功能请按下F2键,将其中内容贴出看一下!!
 楼主| 发表于 2005-2-26 08:38:25 | 显示全部楼层
什么叫在管理员下安装?不懂呀
引用命令显示:
Command: tkshch
Unknown command "TKSHCH".  Press F1 for help.
Command:
Command:
Command: tkrk
Unknown command "TKRK".  Press F1 for help.
Command:
Command:
Command: qarcfg
Unknown command "QARCFG".  Press F1 for help.
Command:
Command:
Command: dycch
Unknown command "DYCCH".  Press F1 for help.
发表于 2005-2-26 13:31:43 | 显示全部楼层
要贴刚进入ACAD时的命令行内容!
 楼主| 发表于 2005-3-1 11:28:21 | 显示全部楼层
A U T O C A D (R)
Copyright (c) 1982-1997  Autodesk, Inc.  All Rights Reserved.
Release 14.0 (97-5-6) Microsoft Windows NT Version 5.1 (x86)
Serial Number:  117-99703105
-- NOT FOR RESALE
Licensed to:    gf, gfg
Obtained from:  fg - 4232493
Menu loaded successfully. MENUGROUP: QAR
Command:
Can't open "inet.lsp" for input
error: LOAD failed
PROTECTED
Regenerating drawing.
Command: error: bad argument type
(STRCAT APP_DATA "mnucvt")
(GETCFG (STRCAT APP_DATA "mnucvt"))
(SETQ TF (GETCFG (STRCAT APP_DATA "mnucvt")) TF (IF TF (READ TF)))
(PROGN (SETQ TF (GETCFG (STRCAT APP_DATA "mnucvt")) TF (IF TF (READ TF))) (IF
TF (IF (NOT LZBAR) (ARXLOAD "scmenubar.arx")) (PROGN (SETQ TF (GETCFG (STRCAT
APP_DATA "mnucvt1")) TF (IF TF (READ TF)) TF (IF TF TF 1)) (IF (OR (= -1 TF) (=
-2 TF) (NOT TF)) (MENUCMD "s=acad.screen") (PROGN (IF (/= 2 TF) (SETQ TF 1))
(IF (AND (= 2 TF) (NOT (MENUGROUP "qarl"))) (COMMAND ".menuload"
"qarlong.mnu")) (MENUCMD (IF (= 1 TF) "s=qar.screen" "s=qarl.screen")) (SCRMNU
TF))))))
(IF _FIRST (PROGN (SETQ TF (GETCFG (STRCAT APP_DATA "mnucvt")) TF (IF TF (READ
TF))) (IF TF (IF (NOT LZBAR) (ARXLOAD "scmenubar.arx")) (PROGN (SETQ TF (GETCFG
(STRCAT APP_DATA "mnucvt1")) TF (IF TF (READ TF)) TF (IF TF TF 1)) (IF (OR (=
-1 TF) (= -2 TF) (NOT TF)) (MENUCMD "s=acad.screen") (PROGN (IF (/= 2 TF) (SETQ
TF 1)) (IF (AND (= 2 TF) (NOT (MENUGROUP "qarl"))) (COMMAND ".menuload"
TF)))))))
(LOAD "D:\\Program Files\\LiZheng\\LAr14\\sys\\Qar.mnl")
发表于 2005-3-1 14:16:09 | 显示全部楼层
查查你的工作目录下是否有一个acad.lsp文件。
 楼主| 发表于 2005-3-1 16:17:24 | 显示全部楼层
有,在D:\Program Files\LiZheng\LAr14\sys\,有什么问题吗?
发表于 2005-3-1 17:31:35 | 显示全部楼层
这个acad.lsp是应该有的。除了这个acad.lsp之外的工作目录下,是否有,如果有的话,可能会在启动时用了错误的acad.lsp,所以应该删掉。
 楼主| 发表于 2005-3-2 14:28:50 | 显示全部楼层
没有呀,就这么一个,那怎么办?
发表于 2005-3-2 17:24:04 | 显示全部楼层
将下面内容贴到理正环境下的命令行,看看返回什么内容?
(findfile "acad.lsp")
 楼主| 发表于 2005-3-3 16:27:05 | 显示全部楼层
我删了CAD中文版,安英文版后再安理正,用是可以用了,但很多CAD常用命令输入都不行,如CO变成改颜色了,这样不方便呀
发表于 2005-3-3 16:51:27 | 显示全部楼层
这是因为你习惯的简化命令文件(acad.pgp)跟理正提供的不一样(理正的COPY是C);解决方法:找到你的ACAD.PGP文件,用【初始设置】里面“简化命令”中的“合并”功能,将你的简化命令合并到理正的简化命令中去。
 楼主| 发表于 2005-3-4 16:34:21 | 显示全部楼层
谢谢QUN,你说的不会搞.能不能给我一个理正的所有快捷键?
发表于 2005-3-14 17:23:36 | 显示全部楼层
我在AUTOCAD 2005 下用理正试用板很好的,有试用期限吗?谢谢
GMT+8, 2026-11-5 08:00 , Processed in 0.430587 second(s), 60 queries , Gzip On.
