查看: 827|回复: 0
[编程申请]:求一个绘制梁轴线的程序
发表于 2005-3-8 17:38:14 | 显示全部楼层 |阅读模式
如果,图中已经有梁线,如何实现选两根梁线即可绘出轴线,并且,指定轴线的两个端线,轴线可以延伸到端线呢?
我只完成了第1步,请问如何实现第2步“延长”?
(defun c:x (/ os pt1 pt2 s1 ds1)
  (princ "\n梁轴线绘制程序")
  (setvar "cmdecho" 0)
  (command "undo" "be")
  (setq os (getvar "osmode"))
  (setvar "osmode" 679)
  (setq        pt1 (getpoint "\n请选择第1根梁线:")
        pt2 (getpoint pt1 "\n请选择第2根梁线:")
  (setq s1 (ssname (ssget pt1) 0))
  (setq ds1 (/ (distance pt1 pt2) 2))
  (command "offset" ds1 s1 pt2 "")
  (setq s2 (entlast))
  (command "change" s2 "" "p" "layer" "dote" "")  ;dote 是我的轴线层
  (setvar "osmode" os)
  (command "undo" "e")
  (setvar "cmdecho" 1)
GMT+8, 2026-11-6 07:08 , Processed in 0.427747 second(s), 32 queries , Gzip On.
