查看: 2356|回复: 9
[LISP程序]:剪贴图面到WORD(背景白色)
发表于 2002-4-2 01:53:14 | 显示全部楼层 |阅读模式
  1. ;;;工作平台:AUTOCAD 2000以上
  2. ;;;功能:剪贴图面到WORD(背景白色)
  3. ;;;配合:XDRX_API15 及 doslib6.0 BETA
  4. ;;;程序设计:赖云龙
  5. ;;;----------------------------------
  6. (defun LRBT (PT1     PT2     /             HOLDECHO             HOLDBLIP
  7.              HOLDOSMODE             ANG     DIST    H             W             CTR
  8.              RT             LB             RB             LT
  9.             )
  10.   (setq HOLDECHO (getvar "cmdecho"))
  11.   (setq HOLDBLIP (getvar "blipmode"))
  12.   (setq HOLDOSMODE (getvar "osmode"))
  13.   (setvar "cmdecho" 0)
  14.   (setvar "blipmode" 0)
  15.   (setvar "osmode" 0)
  16.   (setq ANG (angle PT1 PT2))
  17.   (setq DIST (distance PT1 PT2))
  18.   (setq H (abs (- (cadr PT1) (cadr PT2))))
  19.   (setq W (abs (- (car PT1) (car PT2))))
  20.   (setq CTR (polar PT1 ANG (/ DIST 2.0)))
  21.   (setq        RT (list (+ (car CTR) (/ W 2))
  22.                  (+ (cadr CTR) (/ H 2))
  23.            )
  24.   )
  25.   (setq        LB (list (- (car CTR) (/ W 2))
  26.                  (- (cadr CTR) (/ H 2))
  27.            )
  28.   )
  29.   (setq        RB (list (+ (car CTR) (/ W 2))
  30.                  (- (cadr CTR) (/ H 2))
  31.            )
  32.   )
  33.   (setq        LT (list (- (car CTR) (/ W 2))
  34.                  (+ (cadr CTR) (/ H 2))
  35.            )
  36.   )
  37.   (grdraw LB RB 3 1)
  38.   (grdraw RB RT 3 1)
  39.   (grdraw RT LT 3 1)
  40.   (grdraw LT LB 3 1)
  41.   (setvar "blipmode" HOLDBLIP)
  42.   (setvar "cmdecho" HOLDECHO)
  43.   (setvar "osmode" HOLDOSMODE)
  44.   (princ)
  45. )
  46. (arxload "xdrx_api15" NIL)
  47. (arxload "doslib2k" NIL)
  48. (defun CLIP (FLAG         /             PT1         PT2
  49.              HOLDVIEWPORT             HOLDCOLOR         ACADOBJECT
  50.              PREF         PREF_DISPLAY
  51.             )
  52. ;;;截录自明经通道
  53. ;;;十进制转换为其它进制
  54. ;;;-------------------------------------------------------------------
  55.   (defun DECIMALTOBASE (BASE VAL / RESULT TMP)
  56.     (setq RESULT "")
  57.     (while (> VAL 0)
  58.       (setq RESULT (strcat (if (> (setq TMP (rem VAL BASE)) 9)
  59.                              (chr (+ TMP 55))
  60.                              (itoa TMP)
  61.                            )
  62.                            RESULT
  63.                    )
  64.             VAL           (fix (/ VAL BASE))
  65.       )
  66.     )
  67.     RESULT
  68.   )
  69. ;;;截录自明经通道
  70. ;;;其它进制转换为十进制
  71. ;;;-------------------------------------------------------------------
  72.   (defun BASETODECIMAL (BASE VAL / POS POWER RESULT TMP)
  73.     (setq POS         (1+ (strlen VAL))
  74.           POWER         -1
  75.           RESULT 0
  76.           VAL         (strcase VAL)
  77.     )
  78.     (while (> (setq POS (1- POS)) 0)
  79.       (setq
  80.         RESULT (+ RESULT
  81.                   (* (if (> (setq TMP (ascii (substr VAL POS 1))) 64)
  82.                        (- TMP 55)
  83.                        (- TMP 48)
  84.                      )
  85.                      (expt BASE (setq POWER (1+ POWER)))
  86.                   )
  87.                )
  88.       )
  89.     )
  90.     RESULT
  91.   )
  92. ;;;-------------------------------------------------------------------
  93. ;;;命令:dwgblack
  94. ;;;将图中所有实体(包括块,嵌套块,尺寸中的无名块)都改变
  95. ;;;颜色、图层、线型。
  96. ;;;原作: XDsoft
  97. ;;;通用组码修改  cnum0  组码   cnum  组码值
  98.   (defun DWGBLACK (PT1 PT2 / HOLDCLRD HOLDCLRT N1 LTLST SS KEY NUM NUM0 N E)
  99.     (setq HOLDCLRD (getvar "dimclrd"))
  100.     (setq HOLDCLRT (getvar "dimclrt"))
  101.     (defun #CHG_DXF (E CNUM0 CNUM / TF BLKNA)
  102.       (xdrx_setenttodb E)
  103.       (setq TF (xdrx_getentdxf 0))
  104.       (cond
  105.         ((or
  106.            (= TF "INSERT")
  107.            (= TF "DIMENSION")
  108.          )
  109.          (setq BLKNA (xdrx_getentdxf 2))
  110.          (setq BLKNA (tblsearch "block" BLKNA))
  111.          (setq E (cdr (assoc -2 BLKNA)))
  112.          (while        E
  113.            (xdrx_setenttodb E)
  114.            (setq TF (xdrx_getentdxf 0))
  115.            (if (or
  116.                  (= TF "INSERT")
  117.                  (= TF "DIMENSION")
  118.                )
  119.              (progn
  120.                (#CHG_DXF E CNUM0 CNUM)
  121.              )
  122.              (progn
  123.                (xdrx_setenttodb E)
  124.                (xdrx_modent CNUM0 CNUM)
  125.              )
  126.            )
  127.            (setq E (entnext E))
  128.          )
  129.         )
  130.         ((= TF "TOLERANCE")
  131.          (setvar "dimclrd" CNUM)
  132.          (setvar "dimclrt" CNUM)
  133.          (command "_dim1" "update" E "")
  134.         )
  135.         (t
  136.          (xdrx_modent CNUM0 CNUM)
  137.         )
  138.       )
  139.     )
  140.     (defun GETLTP (NO / TF LYR LYRL)
  141.       (setq TF t)
  142.       (while (setq LYR (tblnext "ltype" TF))
  143.         (setq LYRL (cons LYR LYRL))
  144.         (setq TF NIL)
  145.       )
  146.       (mapcar '(lambda (X) (cdr (assoc NO X))) (reverse LYRL))
  147.     )
  148.     (xdrx_begin)
  149.     (setq SS (ssget "C" PT1 PT2))
  150.     (setq N        0
  151.           N1        0
  152.           LTLST        (GETLTP 2)
  153.     )
  154.     (initget "1 2 3")
  155.     (setq KEY (getstring "\n<1>改颜色/<2>改层/<3>改线型<原样>: "))
  156.     (cond
  157.       ((= KEY "1")
  158.        (setq NUM (acad_colordlg 7))
  159.        (setq NUM0 62)
  160.       )
  161.       ((= KEY "2")
  162.        (setq NUM (getstring "\n图层名称: "))
  163.        (setq NUM0 8)
  164.       )
  165.       ((= KEY "3")
  166.        (if (< (length LTLST)
  167.               9
  168.            )
  169.          (progn
  170.            (princ "\n[")
  171.            (repeat (length LTLST)
  172.              (princ (strcat (rtos N1 2 0)
  173.                             " "
  174.                             (nth N1 LTLST)
  175.                             (if        (< N1
  176.                                    (1- (length LTLST))
  177.                                 )
  178.                               "/"
  179.                               ""
  180.                             )
  181.                     )
  182.              )
  183.              (setq N1 (1+ N1))
  184.            )
  185.            (princ "]<0>")
  186.          )
  187.        )
  188.        (setq NUM (getstring "\n线型名称<continuous>: "))
  189.        (cond ((= NUM NIL)
  190.               (setq NUM "continuous")
  191.              )
  192.              ((<= (ascii NUM) 57)
  193.               (setq NUM (nth (read NUM) LTLST))
  194.              )
  195.              (t)
  196.        )
  197.        (setq NUM0 6)
  198.       )
  199.     )
  200.     (if        (/= KEY "")
  201.       (progn
  202.         (xdrx_setsstodb SS 0)
  203.         (xdrx_pbarbegin "已经完成:" (sslength SS))
  204.         (while (setq E (xdrx_getentdata 0))
  205.           (xdrx_pbarsetpos N)
  206.           (setq N (1+ N))
  207.           (#CHG_DXF E NUM0 NUM)
  208.           (entupd E)
  209.         )
  210.         (xdrx_pbarend)
  211.       )
  212.     )
  213.     (xdrx_end)
  214.     (setvar "dimclrd" HOLDCLRD)
  215.     (setvar "dimclrt" HOLDCLRT)
  216.     (princ)
  217.   )
  218. ;;;背景颜色
  219. ;;;-----------------------------------------------------------
  220.   (defun BACK (/ NOS N AAA A1)
  221.     (setq NOS (dos_getcolor "设定背景颜色" 7))
  222.     (setq N 2)
  223.     (setq AAA "")
  224.     (repeat 3
  225.       (if (= (DECIMALTOBASE 16 (nth N NOS)) "")
  226.         (setq A1 "00")
  227.         (setq A1 (DECIMALTOBASE 16 (nth N NOS)))
  228.       )
  229.       (setq AAA (strcat AAA A1))
  230.       (setq N (1- N))
  231.     )
  232.     (setq COLOR (BASETODECIMAL 16 AAA))
  233.   )
  234. ;;;-----------------------------------------------------------
  235.   (command "_.undo" "m")
  236.   (vl-load-com)
  237.   (setq ACADOBJECT (vlax-get-acad-object))
  238.   (setq PREF (vla-get-preferences ACADOBJECT))
  239.   (setq PREF_DISPLAY (vla-get-display PREF))
  240.   (setq PT1 (getpoint "\n框选第一点: "))
  241.   (setq PT2 (getcorner PT1 "\n框选第二点: \n"))
  242.   (if (= (getvar "CVPORT") 2)
  243.     (progn
  244.       (setq HOLDCOLOR
  245.              (vla-get-graphicswinlayoutbackgrndcolor PREF_DISPLAY)
  246.       )
  247.       (setq HOLDVIEWPORT (vla-get-layoutcreateviewport PREF_DISPLAY))
  248.       (vla-put-layoutcreateviewport PREF_DISPLAY :vlax-false)
  249.       (command "_layout" "new" "layout_temp")
  250.       (setvar "ctab" "layout_temp")
  251.       (command "_.mview" PT1 PT2)
  252.       (command "_.zoom" "W" PT1 PT2)
  253.       (command "_.mspace")
  254.       (command "_.zoom" "W" PT1 PT2)
  255.       (command "_.regen")
  256.       (if (= FLAG 1)
  257.         (progn
  258.           (DWGBLACK PT1 PT2)
  259.           (BACK)
  260.         )
  261.         (setq COLOR 16777215)
  262.       )
  263.       (command "_.regen")
  264.       (vla-put-graphicswinlayoutbackgrndcolor
  265.         PREF_DISPLAY
  266.         COLOR
  267.       )
  268.       (command "_.copyclip" "C" PT1 PT2 "")
  269.       (vla-put-graphicswinlayoutbackgrndcolor
  270.         PREF_DISPLAY
  271.         HOLDCOLOR
  272.       )
  273.       (vla-put-layoutcreateviewport PREF_DISPLAY HOLDVIEWPORT)
  274.     )
  275.     (progn
  276.       (setq HOLDCOLOR
  277.              (vla-get-graphicswinlayoutbackgrndcolor PREF_DISPLAY)
  278.       )
  279.       (command "_.zoom" "W" PT1 PT2)
  280.       (command "_.regen")
  281.       (if (= FLAG 1)
  282.         (progn
  283.           (LRBT PT1 PT2)
  284.           (DWGBLACK PT1 PT2)
  285.           (BACK)
  286.         )
  287.         (setq COLOR 16777215)
  288.       )
  289.       (command "_.regen")
  290.       (vla-put-graphicswinlayoutbackgrndcolor
  291.         PREF_DISPLAY
  292.         COLOR
  293.       )
  294.       (command "_.copyclip" "C" PT1 PT2 "")
  295.       (vla-put-graphicswinlayoutbackgrndcolor
  296.         PREF_DISPLAY
  297.         HOLDCOLOR
  298.       )
  299.     )
  300.   )
  301.   (command "_.undo" "b")
  302.   (princ)
  303. )
  304. (defun C:CLIP_WORD () (CLIP 0))
  305. (defun C:CLIP_WORD_COLOR () (CLIP 1))
  306. (prompt
  307.   "\nType CLIP_WORD for 快速剪贴 , Type CLIP_WORD_COLOR for 设定颜色 "
  308. )
  309. (princ)
发表于 2004-2-18 14:06:17 | 显示全部楼层
佩服,真的佩服
这些东西太好了,解决了我工作急需!
希望班竹再接再厉!
坚决支持-----晓东空间!
发表于 2004-2-26 20:37:02 | 显示全部楼层
我看不出来其中的奥妙,但是我还是很佩服。单从题目来看,遍程序要比直接操作麻烦,能讲讲为什么要边这个吗,我很想了解他,我也想学!
发表于 2004-2-27 02:43:16 | 显示全部楼层
最初由 ws555 发布
[B]我看不出来其中的奥妙,但是我还是很佩服。单从题目来看,遍程序要比直接操作麻烦,能讲讲为什么要边这个吗,我很想了解他,我也想学! [/B]
我与3楼的有同感,只要把绘图的背景换一下就行了,为什么这么做?
发表于 2004-2-28 16:57:03 | 显示全部楼层
非常好!
发表于 2004-3-6 23:09:27 | 显示全部楼层
到底是改图块颜色还是贴图。
发表于 2004-3-9 18:37:30 | 显示全部楼层
最初由 shirley9996 发布
[B]
我与3楼的有同感,只要把... [/B]
不要这么急功近利啊,龙兄提供的是一种技术上的可能,
对大家都是很好的学习机会。不要问为什么,要问的话你
该去问外科医生,为什么杀白鼠杀兔子,干嘛不直接杀人。
发表于 2004-3-21 15:22:46 | 显示全部楼层
這麼長的程序不好搞.
发表于 2004-3-24 11:21:50 | 显示全部楼层
能解释用法吗?
已领礼包: 8个
发表于 2004-3-29 12:18:38 | 显示全部楼层
最初由 cy956 发布
[B]
该去问外?.. [/B]
严重同意.
是一种技术.
何况也有实际用途/
GMT+8, 2026-11-3 07:33 , Processed in 0.557792 second(s), 50 queries , Gzip On.
