查看: 1133|回复: 5
[LISP程序]:请各位帮看一下吧,遇到一个很郁闷的问题!
发表于 2005-4-1 21:57:12 | 显示全部楼层 |阅读模式
下面说有参数类型错误,我很郁闷我找不出来,请指点!!非常感谢!!
(defun c:yuanpan()
        (new_dialog "fldlg" (load_dialog "yuanpan"))
        (start_image "fl")
        (slide_image 0 0 (dimx_tile "fl") (dimy_tile "fl") "fl")
        (end_image)
        (set_tile "r1" "")
        (set_tile "r2" "")
        (set_tile "r3" "")
        (set_tile "n" "")
        (set_tile "x" "")
        (set_tile "y" "")
        (action_tile "r1" "(setq s1 $value)")
        (action_tile "r2" "(setq s2 $value)")
        (action_tile "r3" "(setq s3 $value)")
        (action_tile "n" "(setq n1 $value)")
        (action_tile "x" "(setq x1 $value)")
        (action_tile "y" "(setq y1 $value)")
        (start_dialog)
        (if (= 0 (start_dialog))
                (progn (setq r1 (atof s1)
                                   r2 (atof s2)
                                   r3(atof s3)
                                   n (atoi n1)
                                   x (atof x1)
                                   y (atof y1)
                                        (setq pt (list x y 0.0))
        (setq r2 (/ (+ r1 r3) 2))
                     (setq r (/ (- r1 r3) 2))
        (setq pt1 (polar pt (/ pi 2.0)(+ r3 3))
                 pt2 (polar pt (- (/ pi 2.0))(+ r3 3))
                pt3 (polar pt pi (+ r3 3))
                pt4 (polar pt 0.0 (+ r3 3))
        (command "itscale" 10)
        (command "layer" "m" "0" "1" "continuous" "0" "c" "green" "0" "")
        (command "circle" pt r1)
        (command "circle" pt r3)
        (command "circle" (polar pt 0 r2) r)
        (command "array" "1" "" "p" pt n 360 "n")
        (command "itscal" "30")
        (command "lay" "m" "1" "1" "center" "1" "c" "red" "1" "")
        (command "circle" pt r2)
        (command "line" pt1 pt2 "")
        (command "line" pt3 pt4 "")
        (command "redraw")
        (setq area (* pi (- (* r1 r1)(* n r r))))
命令: yuanpan
; 错误: 参数类型错误: stringp nil
不好意思,谢谢啦!!又一次烦这个错误!!
发表于 2005-4-1 22:17:05 | 显示全部楼层
(new_dialog "fldlg" (load_dialog(findfile "yuanpan.dcl")))
应该把dcl文件上传才知道你哪里错了。
还有个,可以把第一个(start_dialog)删了
 楼主| 发表于 2005-4-2 10:18:47 | 显示全部楼层
回楼上:我把dcl写在下面
fldlg:dialog{
label="圆盘";
:column{
:boxed_column{
:image{
key="my-image";
width=30;
aspect_ratio=1;
color=5;
:row{
:boxed_column{
label="请输入插入点";
:edit_box{
label="坐标x";
key="x";
//value="0";
spacer;
spacer;
:edit_box{
label="坐标y";
key="y";
//value="0";
:boxed_column{
label="请输入圆盘参数";
:edit_box{
label="外径R1";
key="r1";
//value="1000";
edit_width=7;
:edit_box{
label="内径R2";
key="r2";
//value="500";
edit_width=7;
:edit_box{
label="圆盘孔半径R3";
key="r3";
//value="20";
edit_width=7;
:edit_box{
label="圆盘孔个数n";
key="n";
//value="2";
edit_width=7;
ok_cancel;
好了,这个对话框显示没有任何问题的
谢谢了!!看lisp里到底问题在哪啊?
发表于 2005-4-2 12:49:35 | 显示全部楼层
我修改过的,
(defun c:yuanpan ()
  (start_image "fl")
  (end_image)
  (set_tile "r1" "")
  (set_tile "r2" "")
  (set_tile "r3" "")
  (set_tile "n" "")
  (set_tile "x" "")
  (set_tile "y" "")
  (start_dialog)
                 r2 (atof s2)
                 r3 (atof s3)
                 n  (atoi n1)
                 x  (atof x1)
                 y  (atof y1)
  (setq r (/ (+ r1 r2) 2))
  (setq        pt1 (polar pt (/ pi 2.0) (+ r1  3))
        pt2 (polar pt (- (/ pi 2.0)) (+  r1  3))
        pt3 (polar pt pi (+  r1 3))
        pt4 (polar pt 0.0 (+ r1  3))
  (setvar "osmode" 0)
  (command "circle" (polar pt 0 r) r3)
  (command "array" "l" "" "p" pt n 360 "n")
  (command "circle" pt r)
  (command "redraw")
  (setvar "osmode" 37)
  (setq area (* pi (- (* r1 r1) (* n r r))));_这句你自己改吧
程序当中有个(setq r2 (/ (+ r1 r3) 2)),r2不是已经有附值了吗,为什么还要加这句,还要看清楚R3是什么半径?
 楼主| 发表于 2005-4-2 20:10:19 | 显示全部楼层
回楼上的
那几个计算公式没什么,主要的问题是参数错误,我可能这个概念老是搞混,我设断点运行时,参数错误出现在:
                             r2 (atof s2)
                              r3(atof s3)
                              n (atoi n1)
                              x (atof x1)
                              y (atof y1)
错误在这个一块里
我看楼上的函数,这一块没有改动啊,为什么我运行说这里的参数错误呢,不知哪里出问题了
发表于 2005-4-2 21:05:44 | 显示全部楼层
Re: 回楼上的
最初由 一生有你 发布
[B]那几个计算公式没什么,主要的问题是参数错误,我可能这个概念老是搞混,我设断点运行时,参数错误出现在:
                             r2 (atof s2)
                              r3(atof s3)
... [/B]
这几句有没有问题关键还要看你对话框输入的内容是否有误,如果空输入,那么上面这几句肯定会出错。
我检查过这几句,应该没什么问题。而且我测试过,出来的结果也是正确的
GMT+8, 2026-11-6 02:38 , Processed in 0.488563 second(s), 42 queries , Gzip On.
