查看: 1118|回复: 7
[LISP程序]:给PFD8667的等分点连线程序!!
发表于 2005-4-5 20:34:51 | 显示全部楼层 |阅读模式
不知道我说的你明不明白.现帮你随便写了一下不知道
能不能符合你的要求...
(defun c:linkline(/ en lisp 13list  i  24list )
  (setvar "cmdecho" 0)
  (setvar "osmode" 0)
(WHILE (NOT (setq en (car(entsel "\n請選擇一段線"))))
  (hy_apline en)
  (setq lisp (hy_polpoint (entlast)))
  (setq i 0)
  (setq 13list '())
  (setq 24list '())
  (foreach item lisp (if i (progn (if (and (= (rem i 2) 0) (/= i 1))
                           (setq 13list (cons item 13list))
                           (setq 24list (cons item 24list))
                          (setq i (1+ i))
  (command "pline")
  (foreach item 13list (command item))
  (command "")
  (command "change" (entlast) "" "p" "color" "1" "")
  (command "pline")
  (foreach item 24list (command item))
  (command "")
  (princ "-------->> pline ok!! <<--------")
  (prin1)
  (defun hy_polpoint(object / endata i endata_li)
  (setq point_list '())
  (setq endata (entget object))
  (setq i 0)
  (while (< i (length endata))
    (setq endata_li (nth i endata))
    (if (= (car endata_li) 10) (setq point_list (cons (cdr endata_li) point_list)))
    (setq i (1+ i))
  (setq point_list (reverse point_list))
(defun hy_apline(ename1 / vla-obj endpoint ename startpoint i ss1 nn ssm ssn itemx);;;選擇一條線串接與之相聯的圖元為多義線
  (if (= "LWPOLYLINE" (cdr(assoc 0 (entget ename1)))) (command "._explode" ename ""))
  (setq ename (entlast))
  (setq vla-obj (vlax-ename->vla-object ename))
   (setq startpoint (vlax-curve-getstartpoint vla-obj)
         endpoint (vlax-curve-getendpoint vla-obj))
;(safearray-value(vlax-variant-value(vla-get-endpoint vla-obj))))
  (if (OR (= "POLYLINE" (cdr(assoc 0 (entget ename))))
          (= "LWPOLYLINE" (cdr(assoc 0 (entget ename)))))
  (setq i 1)(SETQ I 0))
  (setq j 0);;計數器歸0
  (setq nn 0)
  (princ " ─── \r")
  (while (> (distance startpoint endpoint) 0.0000001);(= (vla-get-closed vla-obj) :vlax-false)
    ;(setq ss1 (ssget "x" (list (cons -4  "<or") (cons 10 endpoint)(cons 11 endpoint) (cons -4  "or>"))))
    (setq ss1 (ssadd))
    (setq ssn (ssget "f" (list endpoint (polar endpoint 0.8 0.1))))
    (foreach itemx (ap-sslist ssn)
      (if (or (< (distance endpoint (vlax-curve-getstartpoint (vlax-ename->vla-object itemx))) 0.0000001)
              (< (distance endpoint (vlax-curve-getendpoint (vlax-ename->vla-object itemx))) 0.0000001))
          (setq ss1 (ssadd itemx ss1))
   (setq ss2 (ssadd))
   (setq ssm (ssget "f" (list startpoint (polar startpoint 0.8 0.1))))
    (foreach itemx (ap-sslist ssm)
      (if (or (< (distance startpoint (vlax-curve-getstartpoint (vlax-ename->vla-object itemx))) 0.0000001)
              (< (distance startpoint (vlax-curve-getendpoint (vlax-ename->vla-object itemx))) 0.0000001))
          (setq ss2 (ssadd itemx ss2))
   (setq ssg (addss ss1 ss2))
   (if (= 0 i)(command "pedit" ename "y" "j" ssg "" "")
               (command "pedit" ename  "j" ssg "" ""))
    (setq i (1+ i))
    (setq nn (1+ nn))
    (cond ((= nn 15)(princ  (strcat "線很長..正在串接中,請稍侯 ......  ───" "\r")))
          ((= nn 30)(princ  (strcat "線很長..正在串接中,請稍侯 ......  ﹨﹨﹨" "\r")))
          ((= nn 45)(princ  (strcat "線很長..正在串接中,請稍侯 ......  │││" "\r")))
          ((= nn 60)(princ  (strcat "線很長..正在串接中,請稍侯 ......  ∕∕∕" "\r")))
    (if (> nn 60) (setq nn 1))
    (setq j (1+ j))
    (IF (and (= 1 (sslength ssg))(= (vla-get-closed vla-obj) :vlax-false))
          (setq startpoint '(0 0 0) endpoint '(0 0 0)));(alert "\n請注意!****串接不線不能封閉!")
  (if (> j 1000)(prompt (strcat "\n恭喜你一共把" (itoa (+ (* 2 j) 3)) "條線串接成了一個封閉的復線!")))
执行LINKLINE....
发表于 2005-4-6 04:57:04 | 显示全部楼层
舟自横您好!
谢谢您的帮助,不好意思我没讲清楚,我一点都不懂编程,我每一条线都是单独的直线,但也各自相连的,这是一个展开图,形成后,将中间的线全部删除,形成一个轮廓图形,再创建成多义线或面域,但按您的思路编程,好像更复杂化了,我原这需用直线命令连接上就可以了,但现在却要
1...取得所有顶点做成一个列表
2...按奇偶数分为两个列表
请教能不能按我能一次或分上下二次就形成如图2的线段所示编个程,因而提高工作效率.
 楼主| 发表于 2005-4-6 09:19:02 | 显示全部楼层
我说的是编程的思路不是让你操作的方法
你可以先用一下我的程序看就知道了...
应该没问题..
具体方法:
1...先加载程序..相信你会吧
2...执行LINKLINE命令如果你不喜欢这个命令可以自己改
3..点选其中任何一段线,就可以了,程序就会帮你把线连好了....
发表于 2005-4-6 10:49:08 | 显示全部楼层
先谢谢您的热心帮助,我将程序试了还是不行,不好意思,麻烦您帮再修改一下吧?我将需连的线的图传上.
发表于 2005-4-6 11:12:13 | 显示全部楼层
(foreach itemx (ap-sslist ssn)中的ap-sslist函数在哪儿?
 楼主| 发表于 2005-4-6 11:17:19 | 显示全部楼层
哦,不好意思漏了一个,补上就好了!!
一起加载
发表于 2005-4-6 13:47:18 | 显示全部楼层
牛刀小试,就拿你这个题目来祭旗。
[php]
(defun c:zko (/ i pt i pts1 pts2 pts)
  (vl-cmdf ".undo" "be")
  (princ "\n 求多条首尾相接的线条展开图的轮廓--------by 狂刀.2005.4")
  (vl-cmdf ".pedit" "m" (ssget) "" "Y" "J" 1e-2 "")
  (setq i 0
        o (vlax-ename->vla-object(entlast)))
  (while (not(vl-catch-all-error-p(setq pt(vl-catch-all-apply 'vla-get-coordinate (list o i)))))
    (setq pt (vlax-safearray->list (vlax-variant-value pt)))
    (if (= 0 (rem i 2))
      (setq pts1 (cons pt pts1))
      (setq pts2 (cons pt pts2))
    (setq i (1+ i))
  (setq pts (append (reverse pts1) pts2))
  (vl-cmdf ".U")
  (vl-cmdf ".pline")
  (mapcar 'vl-cmdf pts)
  (vl-cmdf "cl")
  (vl-cmdf ".undo" "e")
  (princ)
[/php]
发表于 2005-4-6 14:24:17 | 显示全部楼层
太谢谢狂刀兄了,您真是编程高手,也真正是狂刀,您真叫我高兴的发狂编的程序太好用了,我在这图形一扫,回车就形成了多段线的轮廓了,又省了我下一步形成多段线的步骤,再次表示感谢!
在此也对舟自横您表示谢意,您的程序,不知为什么我总是下不了载,我会再找时间下载,用后回复您对我的帮助.
总算下载了,不好意思,还是不行,但还是谢谢您的热心了.
GMT+8, 2026-11-6 02:41 , Processed in 0.473010 second(s), 47 queries , Gzip On.
