查看: 1493|回复: 2
[求助] [求助]:vl-arx-import 用法
发表于 2005-4-9 20:16:47 | 显示全部楼层 |阅读模式
想用vl-arx-import ,CAD老是提示错误
命令: (vl-arx-import 'MATCHPROP (findfile"acmatch.arx"))
错误;输入数据非法(MATCHPROP C:\Program Files\AutoCAD 2002\acmatch.arx)
命令: (vl-arx-import 'c:cal "geomcal.arx"))
错误;输入数据非法(C:CAL geomcal.arx)
哪位能正确调用码,烦写出相应的语句,谢谢先
发表于 2005-4-10 09:44:30 | 显示全部楼层
请查看函数手册上的对应内容。
已领礼包: 488个
发表于 2005-4-10 17:58:27 | 显示全部楼层
帮助里的
  1. Examples
  2. To see how vl-arx-import works, try the following:
  3. 1        Copy the following code into the VLISP editor and save the file:
  4. (vl-doc-export 'testarx)
  5. (defun testarx ()
  6.    (princ "This function tests invoking an ARX app ")
  7.    (vl-arx-import 'c:cal)
  8.    (c:cal)
  9. )
  10. 2        Use Make Application to build a VLX with this code. Select  Separate- Namespace Application Options.
  11. 3        Load geomcal.arx, if it is not already loaded.
  12. 4        Load and run the application.
  13. To verify the effect of vl-arx-import, comment out the vl-arx-import call in the code, save the change,
  14. then rebuild and run the application. Without the vl-arx-import call, the c:cal function will not be found.
  15. In the example above, you could have replaced the vl-arx-import call with the following:
  16. (vl-arx-import "geomcal.arx")
  17. This would import all functions defined in geomcal.arx, including c:cal.
GMT+8, 2026-11-2 16:45 , Processed in 0.471612 second(s), 36 queries , Gzip On.
