查看: 1409|回复: 3
[求助] [求助]:Is there any function that can convert MInserted object (Block) into nor
发表于 2003-2-28 00:05:01 | 显示全部楼层 |阅读模式
Is there any function that can convert MInserted object (Block) into normal block?
发表于 2003-2-28 00:19:32 | 显示全部楼层
重新insert一下就可以。你也可以写成程序,要查一下比例,转角和间距。
已领礼包: 145个
发表于 2003-2-28 02:31:41 | 显示全部楼层
Re: [求助]:Is there any function that can convert MInserted object (Block) into no
最初由 mmmm 发布
[B]Is there any function that can convert MInserted object (Block) into normal block? [/B]
晓东工具箱提供了“保持位置的MINSERT-->INSERT的转换”工具。
看下面链接:
http://www.xdcad.net/forum/showthread.php?postid=20670#post20670
已领礼包: 488个
发表于 2003-3-8 11:42:44 | 显示全部楼层
Re: Re: [求助]:Is there any function that can convert MInserted object (Block) int
最初由 XDSoft 发布
[B]
看下... [/B]
块有属性提问就不行了,
没考虑周全
GMT+8, 2026-11-3 12:42 , Processed in 0.669211 second(s), 38 queries , Gzip On.
