查看: 1088|回复: 2
[LISP程序]:sin曲线为何出问题?
发表于 2005-5-8 10:36:56 | 显示全部楼层 |阅读模式
我编制的sin曲线单独画是正常的,如果相交或捕捉端点头尾相连时就变形了。在R10版本下好用,高版本就不行了,烦请哪位高手赐教,多谢!代码见下:
(defun slin()
(setq p0 (getpoint "please enter begin point:"))
(setq pn (getpoint "\n please enter end point:"))
(setq A (getreal "\n please enter A:"))
(setq L (getreal "\n please enter L:"))
(setq beta (/ (* (angle p0 pn) 180) 3.1416))
(setq dd (distance p0 pn))
(setq ln (fix (/ dd L)))
(setq m 1)
(setq nn (* 4 m))
(setq x (/ (* 3.1416 nn) L))
(setq y (* A (sin x)))
(setq p1 (list nn y))
(command "ucs" "origin" p0)
(command "ucs" "z" beta)
(command "pline" '(0 0))
(while (<= nn (* L ln))
  (command p1)
  (setq m (+ 1 m))
  (setq nn (* 4 m))
  (setq y (* A (sin x))))
(setq p3 (list (* L ln) 0))
(command p3 "")
(command)
(command "ucs" "")
(command)
(command "redraw" "")
(command)
发表于 2005-5-8 10:43:31 | 显示全部楼层
osmode这个系统变量关闭了吗?
发表于 2005-5-8 13:10:36 | 显示全部楼层
试试这个:
[php]
(load "xyp_lib")                        ;加载通用函数
如果已经下载xyp_lib并放到搜索路径下可以不再下载!
利用以下任何一种方式即可加载和运行通用函数内的所有子程序:
1.在acad.lsp中增加(load"xyp_lib")
2.在每个程序内增加(load"xyp_lib")
3.在command下,输入(load"xyp_lib")
4.在菜单.mnl中增加(load"xyp_lib")
通用函数下载地址:http://www.xdcad.net/forum/showthread.php?s=&threadid=325268
;;;正弦曲线
(DEFUN c:zxqx ()
  (cmdla0)
  (mkla "正弦曲线" 3)
  (setq        pt0        (list 0 0)
        pt_last        pt0
        x        0
        NO2        (ureal 1 "" "单位角度 " NO2)
        NO3        (ureal 1 "" "全波数 " NO3)
        dx        (* (/ no2 180) pi)
        angel_a        (* (* PI 2) NO3)
  (command ".undo" "BE")
  (command "pline" pt_last)
  (while (and (>= x (- 0 angel_a)) (<= x angel_a))
    (setq x          (+ x dx)
          y          (sin x)
          pt_next (list x y)
    (command pt_last pt_next)
    (setq Pt_last pt_next)
  (command)
  (mkla "轴线" 1)
  (command "line" pt0 pt_last "")
  (command ".undo" "E")
  (cmdla1)
)[/php]
GMT+8, 2026-11-22 08:09 , Processed in 0.333641 second(s), 14 queries , Gzip On, File On.
