查看: 815|回复: 0
[求助] [求助]:在非模态对话框中打开cad数据库出错!
发表于 2005-5-12 11:12:55 | 显示全部楼层 |阅读模式
在非模态对话框中一个按钮,点击该按钮时,需要打cad的数据库进行相应的块插入操作.可是,为什么运行到打开数据库时就出错. 在模态对话框中是可以打开cad数据库的. 还请各位指点!
void CElemInsertDlg::OnButtonNext()
        // TODO: Add your control notification handler code here
        nCount=m_SldList.GetCount();
        if (nIndex<nCount-1)
        nIndex++;
        ShowSld(nIndex);
        acutPrintf("\nnIndex=%d",nIndex);
        acutPrintf("\n%s",sldPath);
           //得到块名
        CString name,temp;
        int len=sldPath.GetLength();
        int start=sldPath.ReverseFind('\\');
        temp=sldPath.Right(len-start-1);
        name=temp.Left(len-start-5);
        acutPrintf("\n%s\n",name);
    AcDbBlockTable *BlockTable ;
        Acad::ErrorStatus es=acdbHostApplicationServices()-  >workingDatabase()->
                getSymbolTable(BlockTable,AcDb::kForWrite);
        if (es!=Acad::eOk)
                acutPrintf("\nFail Open BlockTable!\n");
//----------------------每次运行到这里就出错,为什么????-----------------------------
                return;
        BlockTable->close();
        AcDbObjectId blockId ;
    if ( BlockTable->has (name) != Adesk::kTrue )
            acutPrintf("\n没有块 %s\n",name);
                BlockTable->close () ;
                AcDbDatabase *pDwg =new AcDbDatabase (Adesk::kFalse) ;
                char buffer[100];
        sprintf( buffer, "%s", dwgPath );
                acutPrintf("\n%s",buffer);
        es=pDwg->readDwgFile (buffer);
                if (es!= Acad::eOk )
            acutPrintf ("\n读取dwg文件失败!\n") ;
                        return;
                es=acdbHostApplicationServices()->workingDatabase()->
                        insert(blockId,name,pDwg,Adesk::kFalse);
        if ( es != Acad::eOk )
            acutPrintf ("\n插入块错误.\n") ;
                        return;
        delete pDwg ;
        else
                acutPrintf("\n存在块 %s",name);
        BlockTable->getAt (name, blockId, false) ;
GMT+8, 2026-11-6 08:14 , Processed in 0.450769 second(s), 32 queries , Gzip On.
