查看: 1043|回复: 4
[LISP程序]:标注文本的归位
发表于 2005-5-23 21:13:13 | 显示全部楼层 |阅读模式
标注文本的归位
此程序在r14中可以用,但在2002中却没有作用,望高人指点!
(DEFUN c:dimhome (/ et e s f)
  (IF (SETQ et (ENTSEL "\n选择要文本归位的标注:"))
    (PROGN (SETQ e (ENTGET (CAR et)))
           (SETQ s (CDR (SETQ f (ASSOC 70 e))))
           (IF (> s 128)
             (PROGN (SETQ s (- s 128)) (ENTMOD (SUBST (CONS 70 s) f e)))
           ) ;_ end of if
    ) ;_ end of progn
  ) ;_ end of if
  (PRINC)
) ;_ end of defun
已领礼包: 488个
发表于 2005-5-23 21:50:21 | 显示全部楼层
(command "_dim1""_hometext")
 楼主| 发表于 2005-5-23 21:56:59 | 显示全部楼层
用(command)是个好办法
发表于 2005-5-23 22:13:03 | 显示全部楼层
[php](DEFUN c:test ()
  (setq        ss (ssget '((0 . "DIMENSION")))
        i  -1
  (while (setq s1 (ssname ss (setq i (1+ i))))
    (if        (> (dxf 70 (entget s1)) 32)
      (command "dim" "home" (list s1 '(0 0 0)) "" "exit")
  (princ)
(defun dxf (code elist) (cdr (assoc code elist)))[/php]
 楼主| 发表于 2005-5-31 20:39:09 | 显示全部楼层
不用Command,用lsp如何完成?
GMT+8, 2026-11-6 10:08 , Processed in 0.472336 second(s), 40 queries , Gzip On.
