查看: 924|回复: 2
[LISP程序]:设计中问题求教~
发表于 2005-5-24 10:39:16 | 显示全部楼层 |阅读模式
你好:
      我编好一个DCL对话框和LISP程序的代码,但是我不知道怎么衔接这两个方面,使我在DCL对话框中输入参数,就可以调用运行LISP程序!谢谢!
DCL代码:
sunshade: dialog {
      label = "绘制日照棒影图";
      :row{
      :boxed_column{
          label = "数据输入窗口";
          :edit_box{label = "太阳 赤纬角 &δ (度):";
                edit_width = 10;
                key = "δ";
                value = "";
          :edit_box{label = "地 理 纬 度 &Φ (度):";
                width = 10;
                mnemonic= "Φ";
                key = "Φ";
                value = "";
           :edit_box{label = "棒       高 &Η (mm):";
                width = 10;
                mnemonic= "Η";
                key = "Η";
                value = "";
       ok_cancel;
LISP代码:
;;;convert angle in degrees to radians
(defun dtr (a)
  (* pi (/ a 180.0))
(defun c:SUNSHADE (/   pt  hg  φ  δ  Ω  A1  A10 A11 A12 A13 A14 A15
           A16 A17 A2  A3  A4  A5  A6  A7  A8  A9  AS  C   H
           TT  X   Y   Z
  (setvar "cmdecho" 0)
  (setq pt (getpoint "\n enter a point:"))
  (setq hg (getreal "\n enter a high:"))
  (setq δ (getangle "\n 输入地区太阳赤纬角 δ=:"))
  (setq φ (getangle "\n 输入地区地理纬度 φ=:"))
;;;(command "layer" "m" "2" "on" "2" "1" "continuous" "2" "")
;;;(command "color" 2)
  (setq tt 4)
  (setq Ω (* 15 tt))
  (setq    x (+ (* (sin φ) (sin δ))
         (* (cos φ) (cos δ) (cos (dtr Ω)))
  (setq y (sqrt (- 1 (* x x))))
  (setq H (* hg (/ y x)) ;y/x====x/y
  (setq z (/ (* (sin (dtr Ω)) (cos δ)) y))
  (setq as (atan (/ z (sqrt (- 1 (* z z)))))
  (setq a1 (polar pt (- as (/ pi 2)) H))
  (command "line" pt a1 "")
  (command "text" a1 40 "" "8时")
  (setq tt 3.5)
  (setq Ω (* 15 tt))
  (setq a2 (polar pt (- as (/ pi 2)) H))
  (command "line" pt a2 "")
  (setq tt 3)
  (setq Ω (* 15 tt))
  (setq a3 (polar pt (- as (/ pi 2)) H))
  (command "line" pt a3 "")
  (command "text" a3 40 "" "9时")
  (setq tt 2.5)
  (setq Ω (* 15 tt))
  (setq a4 (polar pt (- as (/ pi 2)) H))
  (command "line" pt a4 "")
  (setq tt 2)
  (setq Ω (* 15 tt))
  (setq a5 (polar pt (- as (/ pi 2)) H))
  (command "line" pt a5 "")
  (command "text" a5 40 "" "10时")
  (setq tt 1.5)
  (setq Ω (* 15 tt))
  (setq a6 (polar pt (- as (/ pi 2)) H))
  (command "line" pt a6 "")
  (setq tt 1)
  (setq Ω (* 15 tt))
  (setq a7 (polar pt (- as (/ pi 2)) H))
  (command "line" pt a7 "")
  (command "text" a7 40 "" "11时")
  (setq tt 0.5)
  (setq Ω (* 15 tt))
  (setq a8 (polar pt (- as (/ pi 2)) H))
  (command "line" pt a8 "")
  (setq tt 0)
  (setq Ω (* 15 tt))
  (setq a9 (polar pt (- as (/ pi 2)) H))
  (command "line" pt a9 "")
  (command "text" a9 40 "" "12时")
  (setq tt -0.5)
  (setq Ω (* 15 tt))
  (setq a10 (polar pt (- as (/ pi 2)) H))
  (command "line" pt a10 "")
  (setq tt -1)
  (setq Ω (* 15 tt))
  (setq a11 (polar pt (- as (/ pi 2)) H))
  (command "line" pt a11 "")
  (command "text" a11 40 "" "13时")
  (setq tt -1.5)
  (setq Ω (* 15 tt))
  (setq a12 (polar pt (- as (/ pi 2)) H))
  (command "line" pt a12 "")
  (setq tt -2)
  (setq Ω (* 15 tt))
  (setq a13 (polar pt (- as (/ pi 2)) H))
  (command "line" pt a13 "")
  (command "text" a13 40 "" "14时")
  (setq tt -2.5)
  (setq Ω (* 15 tt))
  (setq a14 (polar pt (- as (/ pi 2)) H))
  (command "line" pt a14 "")
  (setq tt -3)
  (setq Ω (* 15 tt))
  (setq a15 (polar pt (- as (/ pi 2)) H))
  (command "line" pt a15 "")
  (command "text" a15 40 "" "15时")
  (setq tt -3.5)
  (setq Ω (* 15 tt))
  (setq a16 (polar pt (- as (/ pi 2)) H))
  (command "line" pt a16 "")
  (setq tt -4)
  (setq Ω (* 15 tt))
  (setq a17 (polar pt (- as (/ pi 2)) H))
  (command "line" pt a17 "")
  (command "text" "r" a17 40 "" "16时")
  (command "line" a1 a2    a3 a4 a5 a6 a7 a8 a9 a10 a11 a12 a13 a14 a15 a16
       a17 "")
  (command "zoom" "e")
发表于 2005-5-24 19:51:00 | 显示全部楼层
[PHP]
(defun dtr (a)
(* pi (/ a 180.0))
TT X Y Z
(dcl_sunshade)
(prin1)
(defun dcl_sunshade()
  (setq dcl_id (load_dialog "sunshade")) ;载入DCL文件
  (new_dialog "sunshade" dcl_id)
  (set_tile "hg1" "150")                ;设定值
  (set_tile "δ1" "80")
  (set_tile "φ1" "50")
  (action_tile "draw_ok" "(get_sun)(done_dialog 1)")
  (start_dialog)
  (sunshade1)
(defun get_sun()
  (setq hg (atof (get_tile "hg1")))
  (setq δ (atof (get_tile "δ1")))
  (setq φ (atof (get_tile "φ1")))
(defun sunshade1()
;;;(setq hg (getreal "\n enter a high:"))
;;;(setq δ (getangle "\n 输入地区太阳赤纬角 δ=:"))
;;;(setq φ (getangle "\n 输入地区地理纬度 φ=:"))
(setq tt 4)
(setq Ω (* 15 tt))
(setq tt 3.5)
(setq Ω (* 15 tt))
(setq tt 3)
(setq Ω (* 15 tt))
(setq tt 2.5)
(setq Ω (* 15 tt))
(setq tt 2)
(setq Ω (* 15 tt))
(setq tt 1.5)
(setq Ω (* 15 tt))
(setq tt 1)
(setq Ω (* 15 tt))
(setq tt 0.5)
(setq Ω (* 15 tt))
(setq tt 0)
(setq Ω (* 15 tt))
(setq tt -0.5)
(setq Ω (* 15 tt))
(setq tt -1)
(setq Ω (* 15 tt))
(setq tt -1.5)
(setq Ω (* 15 tt))
(setq tt -2)
(setq Ω (* 15 tt))
(setq tt -2.5)
(setq Ω (* 15 tt))
(setq tt -3)
(setq Ω (* 15 tt))
(setq tt -3.5)
(setq Ω (* 15 tt))
(setq tt -4)
(setq Ω (* 15 tt))
a17 "")
[/PHP]
[PHP]
sunshade: dialog {
label = "绘制日照棒影图";
:row{
:boxed_column{
label = "数据输入窗口";
edit_width = 10;
key = "δ1";
value = "";
width = 10;
mnemonic= "φ";
key = "φ1";
value = "";
width = 10;
mnemonic= "Η";
key = "hg1";
value = "";
:row{
fixed_width=true;
alignment=centered;
:button{label="确定";key="draw_ok";width=4;}
cancel_button;
[/PHP]
发表于 2005-5-25 19:31:18 | 显示全部楼层
徐州的兄弟吧,怎么换马甲了?
GMT+8, 2026-11-3 16:17 , Processed in 0.872144 second(s), 35 queries , Gzip On.
