查看: 1516|回复: 6
[原创]:地形测量中好用“LISP快速展点程序”
已领礼包: 111个
发表于 2005-6-14 16:04:59 | 显示全部楼层 |阅读模式
地形测量中好用“LISP快速展点程序”
;地形测量中好用“LISP展点程序”
;展1000点:在HP(AMD Athlon64  3000+  256MB)电胶上仅耗时0.142秒;
:展257272点:在HP(AMD Athlon64  3000+  256MB)电胶上仅耗时94秒;
;                    在金利(Geleron(R) CPU 2.40GHz 256MB)电胶上耗时0.882秒
;数据文件格式为:每一点的数据(点号、X、Y、H)为一行,用逗号或空格作为分隔符,即
;点号1  X1  Y1 H1   或者 点号1,  X1,  Y1, H1
;点号2  X2  Y2 H2   或者 点号2,  X2,  Y2, H2
;点号3  X3  Y3 H3   或者 点号3,  X3,  Y3, H3
;点号n  Xn  Yn Hn   或者 点号n,  Xn,  Yn, Hn1
(defun c:kszd()
    (setq  ff (open (getfiled "请选择要展点的数据文件" "" "txt" 2) "r")
              fhb nil  t0 (getvar "cdate")
      cm (getvar "cmdecho") os (getvar "osmode")
             tcm1 "高程注记"   tcm2 "点记"
    (setvar "cmdecho" 0)(setvar "osmode" 0)
    (if (= (tblsearch "layer" tcm1) nil) (command "layer" "n" tcm1 ""))
    (if (= (tblsearch "layer" tcm2) nil) (command "layer" "n"  tcm2 ""))
    (while (setq zb (read-line ff))
        (while (vl-string-search "," zb) (setq zb (vl-string-subst " " "," zb)))
(setq zb  (read (strcat "(" zb ")"))
                 zb  (list (list (nth 2 zb) (nth 1 zb)) (vl-princ-to-string  (last zb)));注记高程
                ;zb  (list (list (nth 2 zb) (nth 1 zb)) (vl-princ-to-string  (car zb)));提示:注记点号请用该行
          fhb (append fhb (list zb))
    (setq t1 (getvar "cdate"))
    (close ff)
    (setq zb (vl-sort fhb '(lambda (e1 e2) (< (car (car e1)) (car (car e2)))))
   x0 (car (car (car zb)))  x1 (car (car (last zb)))
   zb (vl-sort fhb '(lambda (e1 e2) (< (cadr (car e1)) (cadr (car e2)))))
   y0 (cadr (car (car zb)))  y1 (cadr (car (last zb)))
    (command "zoom" "w" (list x0 y0) (list x1 y1))
    (setq t2 (getvar "cdate"))
    (foreach zb fhb
        (setq zfc (last zb)
       pt  (mapcar '+ (car zb) '(1.5 -1.25))
        (entmake (list '(0 . "TEXT") '(100 . "AcDbEntity") '(100 . "AcDbText")
         '(62 . 1) '(40 . 2.5) '(50 . 0.0)
          (cons 8 tcm1)   (cons 1 zfc)  (cons 10 pt)
        (entmake (list '(0 . "POINT") '(100 . "AcDbEntity") '(100 . "AcDbPoint")
         '(62 . 2)
          (cons 8 tcm2)  (cons 10 pt)
    (setq t3 (getvar "cdate")
   dt1 (* 1000000 (- t1 t0))
   dt2 (* 1000000 (- t3 t2))
    (princ (strcat "
读入数据共耗时:" (rtos dt1 2 3) "秒   展点共耗时" (rtos dt2 2 3) "秒"
展点数:" (itoa (length fhb)) "个  每展一点耗时:" (rtos (/ dt2 (length fhb)) 2 10) "秒"
    (setvar "cmdecho" cm)(setvar "osmode" os)(princ)
发表于 2005-6-14 16:13:02 | 显示全部楼层
太专业了,如何能更清楚的了解一下子它的用途?
发表于 2005-6-14 17:12:38 | 显示全部楼层
是不是已知直线座标和标高,通过LISP直接绘制图形?
已领礼包: 111个
 楼主| 发表于 2005-7-2 09:45:52 | 显示全部楼层
将地形测量中所得的每一个地形特征点及高程展绘于图中(用点表示点位、高程字符串表示高程值),用于构建数字地面高程模型、计算土方数量等。
发表于 2013-8-10 15:40:09 | 显示全部楼层
过来学习一下!
发表于 2013-8-11 13:50:46 | 显示全部楼层
谢谢楼主的分享!很有用啊!
发表于 2016-4-18 21:16:06 | 显示全部楼层
展点后,点不带高程,如何建模?
GMT+8, 2026-11-6 00:09 , Processed in 0.401785 second(s), 44 queries , Gzip On.
