查看: 975|回复: 3
[求助] [求助]:这个选择集为什么不正确呀
发表于 2005-6-20 10:23:53 | 显示全部楼层 |阅读模式
我编了一个程序,想通过图元过滤器表选择所要的图形.
(command "layer" "m" "压力表" "c" 2 "" "")
  (command "circle" dc 2)
  (setq hx (car dc))
  (setq hy (cadr dc))
  (setq hy1 (+ hy 1))
  (setq hy2 (- hy 1))
  (setq hx1 (- hx (* 2 (sin (/ (* 60 pi) 180)))))
  (setq hx2 (+ hx (* 2 (sin (/ (* 60 pi) 180)))))
  (setq zh1 (list hx1 hy1))
  (setq zh2 (list hx2 hy1))
  (setq zh3 (list hx1 hy2))
  (setq zh4 (list hx2 hy2))
  (command "line" zh1 zh2 "")
  (command "line" zh3 zh4 "")
  ;(setq a (entget (entlast)))
  (setq z1x (- hx 3))
  (setq z1y (+ hy 3))
  (setq z2x (+ hx 3))
  (setq z2y (- hy 3))
  (setq z1 (list z1x z1y))
  (setq z2 (list z2x z2y))
  (setq se1 (ssget "W" z1 z4 '((8 . "压力表"))))
  (setq bname (getstring "请输入块名"))
(command "-block" bname z1 se1 "")
  (command "-insert" bname z1 "" "" "")
可程序运行时却显示
错误: 错误的点参数
请哪位高手给看一下
已领礼包: 12493个
发表于 2005-6-20 11:06:37 | 显示全部楼层
点变量DC未赋值。
 楼主| 发表于 2005-6-20 14:51:59 | 显示全部楼层
已经赋值了,只不过前面的程序我没有粘上
发表于 2005-6-20 15:37:49 | 显示全部楼层
应该是(setq se1 (ssget "W" z1 z2 '((8 . "压力表"))))吧?
GMT+8, 2026-11-6 09:16 , Processed in 0.442668 second(s), 38 queries , Gzip On.
