查看: 992|回复: 8
[求助]:如何绘制带箭头的直线???
发表于 2005-6-22 07:10:13 | 显示全部楼层 |阅读模式
小弟初学CAD,不知道如何绘制带箭头的直线,希望各位大虾帮忙!!!
小弟在这里先谢过大家!
发表于 2005-6-22 13:00:35 | 显示全部楼层
天正里自带了画箭头的命令的,直接用就行了。
发表于 2005-6-22 13:02:56 | 显示全部楼层
用引线标注
发表于 2005-6-22 13:06:05 | 显示全部楼层
(defun ureal (bit kwd msg def / inp)
(if def
(setq msg (strcat "\n" msg "<" (rtos def) ">: ")
bit (* 2 (fix (/ bit 2)))
(if (= " " (substr msg (strlen msg) 1))
(setq msg (strcat "\n" (substr msg 1 (1- (strlen msg))) ": "))
(setq msg (strcat "\n" msg ": "))
(initget bit kwd)
(setq inp (getreal msg))
(if inp inp def)
(defun upoint (bit kwd msg def bpt / inp)
(if def
(setq pts (strcat
(rtos (car def))
(rtos (cadr def))
(if
(and (caddr def) (= 0 (getvar "FLATLAND")))
(strcat "," (rtos (caddr def)))
msg (strcat "\n" msg "<" pts ">: ")
(initget bit kwd)
(setq inp
(if bpt
(getpoint msg bpt)
(getpoint msg)
(if inp inp def)
(setq cm(getvar "cmdecho"))
(setvar "cmdecho" 0)
(defun C:ARR ( / #dwgsc w v pt1 pt2 pt3 )
(if(= arscl nil)(setq arscl 0.1875))
(setq #dwgsc(getvar "DIMSCALE")
W(getvar "PLINEWID")
V(getvar "OSMODE")
L(getvar "CLAYER"))
(setq arscl(ureal 7 "" "请输入箭头长度" arscl))
(setvar "OSMODE" 1)
(setq pt1 (upoint 1 "" "指定箭头顶点" nil nil))
(setvar "OSMODE" 512)
(setq PT(entsel "\n选择直线上要画箭头一端的任意一点"))
(setq PT2(cadr PT))
(setq ED(entget(car PT)))
(setq PT3 (polar PT1 (angle PT1 PT2) (* #dwgsc arscl)))
(command "PLINE" pt1 "w" "0" (* #dwgsc (/ arscl 3)) pt3 "")
(setvar "OSMODE" V)
(setvar "CLAYER" L)
(setvar "plinewid" W)
(princ)
(setvar "cmdecho" cm)
(princ)
发表于 2005-6-22 13:18:54 | 显示全部楼层
不知道好的方法就用笨的:画三角后填充!!!!!!!!!!!!!!!
其实用pl命令就行!!!!!
试试
发表于 2005-6-22 13:40:07 | 显示全部楼层
如果没天正理正的话,还是用多义线就是楼上说的PL挺不错的!!
发表于 2005-6-22 15:21:45 | 显示全部楼层
PLINE线就可以的
发表于 2005-6-25 13:05:38 | 显示全部楼层
qlerder
发表于 2005-6-26 10:05:43 | 显示全部楼层
可以用多段线,设置不同的宽度。
GMT+8, 2026-11-3 20:44 , Processed in 0.685416 second(s), 48 queries , Gzip On.
