查看: 1290|回复: 0
[VBA程序]:AddLightWeightPolyline不能创建可变的多线段吗?
发表于 2005-6-24 16:31:44 | 显示全部楼层 |阅读模式
Dim points(0 To 5) As Double
' 为二维多段线顶点赋值
points(0) = 2: points(1) = 4
points(2) = 4: points(3) = 2
points(4) = 6: points(5) = 4
Set plineObj = doc1.ModelSpace.AddLightWeightPolyline(points)
上面的没有任何问题
但如果我有一个字符串如下:
dim objstr as string=
"0,0|740.4857,0|740.4857,-89.8498|0,-89.8498"
通过objstr创建一个多线段,怎么老是出错呢?
            'db是ado的一个记录集 dim db as new adodb.recordset
            Dim points
            dim objsum,i as integer
            objstr = Replace(objstr, "|", ",")
            points = Split(objstr, ",")
            objsum = db("summit_sum") * 2 - 1  'db("summit_sum") 是多线段的顶点个数
            ReDim repoints(0 To objsum) As double
           'ReDim repoints(0 To objsum) As variant  这两种定义方式都不行
           ''ReDim repoints(0 To objsum)
            For i = 0 To objsum
                repoints(i) = points(i)
                Debug.Print points(i)
            Next
            '这一句添加时老是出错:无效的过程调用或参数
            '我试了上面好几种定义方式都不行,
GMT+8, 2026-11-22 08:05 , Processed in 0.534837 second(s), 10 queries , Gzip On, File On.
