查看: 2373|回复: 0
[分享] 以一个点打断曲线
发表于 2013-9-1 16:28:03 | 显示全部楼层 |阅读模式
To break a curve at a point, use the AcDbCurve::getSplitCurves method. All you need to know are some points or parameters where you want to break the curve. Here is a sample that lets you select a AcDbCurve (Line, Spline, Arc, ...) and a point near the curve. The point that is on the curve and closest to the selected point is chosen. It then splits the curve and adds the new curve segments to the model space.
static void ADSProjectBreak(void)
    AcDbObjectId id;
    AcGePoint3d pick;
    AcDbEntity* pEnt;
    // Let the user select a curve
    pEnt = selectEntity(
                            _T("\nSelect curve : "),
                            id,
                            pick,
                            AcDb::kForRead
    if(! pEnt)
        acutPrintf(_T("\nSelection failed "));
        return;
    // Check that it is really a curve
    AcDbCurve* pCurve = AcDbCurve::cast(pEnt);
    if(! pCurve)
        acutPrintf(L"\nYou didn't select a curve");
        pEnt->close();
        return;
    // Get the break position and convert to WC coordinates
    AcGePoint3d breakPnt;
    if(acedGetPoint (     0,
                        L"\nPick a point on the curve: ",
                        asDblArray(breakPnt)
                    ) != RTNORM)
        pCurve->close();
        return;
    acdbUcs2Wcs (     asDblArray(breakPnt),
                    Adesk::kFalse
    // Check that the point is on the curve or
    // calculate the closest point tothe curve
    Acad::ErrorStatus es;
    double dist;
    es = pCurve->getDistAtPoint(breakPnt, dist);
    if(es != Acad::eOk)
        es = pCurve->getClosestPointTo(breakPnt, breakPnt);
        if(es != Acad::eOk)
            acutPrintf(
                        L"\ngetClosestPointTo failed : es =%s",
                        acadErrorStatusText(es)
            pCurve->close();
            return;
    AcGePoint3dArray breakPoints;
    AcDbVoidPtrArray newCurves;
    // Get the segments according to the trim points
    breakPoints.append(breakPnt);
    es = pCurve->getSplitCurves(breakPoints, newCurves);
    if(es != Acad::eOk)
        acutPrintf  (
                        L"\ngetSplitCurves failed : es = %s",
        pCurve->close();
        return;
    pCurve->close();
    // Here we add the segements to the database with different colors
    for(int i=0; i < newCurves.length(); i++)
        pEnt = (AcDbEntity*)newCurves;
        pEnt->setColorIndex(i+1);
        appendToBlock(    pEnt,
                        id,
                        ACDB_MODEL_SPACE,
                        acdbHostApplicationServices()->workingDatabase());
        pEnt->close();
static AcDbEntity* selectEntity(    const ACHAR* prompt,
                                    AcDbObjectId& id,
                                    AcGePoint3d& pick,
                                    AcDb::OpenMode openMode
    AcDbEntity* ent = NULL;
    ads_name ename;
    if(acedEntSel(prompt, ename, asDblArray(pick)) != RTNORM)
        return ent;
    if(acdbGetObjectId(id,ename) != Acad::eOk)
        return ent;
    if((es = acdbOpenAcDbEntity(ent,id,openMode)) != Acad::eOk)
        acutPrintf(
                    _T("\nselectEntity : acdbOpenEntity failed es =%s"),
        return NULL;
    return ent;
static Acad::ErrorStatus appendToBlock(    AcDbEntity* pEnt,
                                        AcDbObjectId& idEnt,
                                        const ACHAR* pcBlockName,
                                        AcDbDatabase * pDb
    // Default to current database
    if(!pDb)
        pDb= acdbHostApplicationServices()->workingDatabase();
    AcDbBlockTable      * pBlockTable = NULL;
    // Get block table
    es = pDb->getBlockTable( pBlockTable, AcDb::kForRead );
    if(es != Acad::eOk)
        return es;
    // Find block record
    AcDbBlockTableRecord  * pBlockTableRecord = NULL;
    es = pBlockTable->getAt (
                                pcBlockName,
                                pBlockTableRecord,
                                AcDb::kForWrite
    if(es != Acad::eOk)
        pBlockTable->close();
        return es;
    // append new entity to block:
    es = pBlockTableRecord->appendAcDbEntity( idEnt, pEnt );
    pBlockTableRecord->close();
    return es;
GMT+8, 2026-11-22 07:56 , Processed in 0.234911 second(s), 10 queries , Gzip On, File On.
