查看: 1004|回复: 7
[测试]:我的AC8R2中找不到存为窗的命令
发表于 2003-3-22 17:38:25 | 显示全部楼层 |阅读模式
我的AC8R2中找不到存为*.WIN或是*.DOR的命令,我的版本是ISO,有知道的朋友请告知这是什么原因,或者在哪儿有这个命令,否则自制门窗就不可能啦.
发表于 2003-3-22 20:13:45 | 显示全部楼层
我粗看了一下,因为我在汉化时看到GDL部件多了个子类项。应该是这样的,利用GDL OBJECT里面的命令先把你的物件存在GSM,然后设定该物件打开时是作为门、窗、楼梯....等。
GDL Object Subtypes
All GDL Objects have a subtype, organized in a tree hierarchy based on the IFC (Industrial Foundation Classes) entity structure. Subtypes allow you to organize your library parts into a logical system. Add-Ons also use subtypes to identify their corresponding library parts.
ArchiCAD subtypes are controlled by subtype object templates. When you create a new GDL Object, ArchiCAD will allow you to choose one of the available subtypes for your element.
Each subtype has a set of compulsory parameters that define the behavior or functionality of the elements that belong to it.
Some of the subtypes include additional features called handlers. These define whether the elements that belong to the subtype can be accessed as general objects by clicking the Object tool's icon and choosing them in the Object Settings dialog box, or as specific objects that either have their own tool icon in the Toolbox (for example Door, Window, Corner Window, Skylight, Label, Stair) or are placed by special commands or functions (for example Zone stamps, RoofMaker objects, Accessory objects, etc.).
时间仓促,您老自己去研究吧!
 楼主| 发表于 2003-3-22 22:32:23 | 显示全部楼层
你说的是对的,我试了一下,可以,但是我还没有搞懂,截二张图给你看看.     平面窗错误
 楼主| 发表于 2003-3-22 22:34:12 | 显示全部楼层
立面窗错位
发表于 2003-3-23 11:49:35 | 显示全部楼层
窗户被挡到了,还要把它移动一下
 楼主| 发表于 2003-3-23 16:17:53 | 显示全部楼层
最初由 navo 发布
[B]窗户被挡到了,还要把它移动一下 [/B]
那你告诉我在GDL SCRIPT中怎么改啊,别告诉我用DRAG命令啊.
 楼主| 发表于 2003-3-23 21:40:19 | 显示全部楼层
搞定啦!  关键:在原点绘制,  在SAVE AS *.GSM中选门或窗选项,在3D Script中把rotx 270 改为rotx 0!  (好象在7.0中不需要改rot值啊,变笨啦?)
 楼主| 发表于 2003-3-23 21:41:41 | 显示全部楼层
透视,
GMT+8, 2026-11-22 11:01 , Processed in 0.406219 second(s), 24 queries , Gzip On, File On.
