查看: 1298|回复: 3
[转贴]:修改图块内所有属性性质
发表于 2003-3-24 12:53:13 | 显示全部楼层 |阅读模式
  1. 修改图块内所有属性性质
  2. ;;By 龙龙仔
  3. ;;修改图块内所有属性性质
  4. ;;USAGE: (CHANGE_ATT "LAYER" "DIM")
  5. ;;USAGE: (CHANGE_ATT "COLOR" "1")
  6. (defun CHANGE_ATT (PROPERTY LNAME / BLK BLKREF BNAME BLKDEF ENT)
  7.   (vl-load-com)
  8.   (while
  9.     (or (not (setq BLK (car (entsel "\n选取带属性图块: "))))
  10. (progn
  11.   (setq BLKREF (vlax-ename->vla-object BLK))
  12.   (not (= (vla-get-objectname BLKREF) "AcDbBlockReference"))
  13. )
  14.     )
  15.   )
  16.   (setq BNAME  (vla-get-name BLKREF)
  17. BLKDEF (vla-item (vla-get-blocks
  18.    (vla-get-activedocument (vlax-get-acad-object))
  19. )
  20. BNAME
  21.        )
  22.   )
  23.   (vlax-for ENT BLKDEF
  24.     (if (= (vla-get-objectname ENT) "AcDbAttributeDefinition")
  25.       ((eval (read (strcat "vla-put-" PROPERTY))) ENT LNAME)
  26.     )
  27.   )
  28.   (command "_.attsync" "n" BNAME)
  29.   (princ)
  30. )
发表于 2003-4-3 00:14:33 | 显示全部楼层
不错,copy 一下,学习学习!
已领礼包: 593个
发表于 2003-4-3 00:41:25 | 显示全部楼层
vla-getattributes 可以得到块中的所有属性的集合。
发表于 2003-4-3 08:24:49 | 显示全部楼层
  1. getattributes是对block reference.
  2. 原问题是要改变所有block中属性
  3. 对block reference属性修改
  4. ;;By (LUCAS)龙龙仔
  5. ;;修改BLOCK REF内所有属性性质
  6. ;;USAGE: (CHANGE_ATTT "LAYER" "DIM")
  7. ;;USAGE: (CHANGE_ATTT "COLOR" "1")
  8. (defun CHANGE_ATTT (PROPERTY LNAME / BLK BLKREF BNAME BLKDEF ENT)
  9.   (vl-load-com)
  10.   (while
  11.     (or        (not (setq BLK (car (entsel "\n选取带属性图块: "))))
  12.         (progn
  13.           (setq BLKREF (vlax-ename->vla-object BLK))
  14.           (not (= (vla-get-objectname BLKREF) "AcDbBlockReference"))
  15.         )
  16.     )
  17.   )
  18.   (foreach ENT (vlax-safearray->list
  19.                  (vlax-variant-value (vla-getattributes BLKREF))
  20.                )
  21.     ((eval (read (strcat "vla-put-" PROPERTY))) ENT LNAME)
  22.   )
  23.   (princ)
  24. )
GMT+8, 2026-11-3 17:39 , Processed in 0.465958 second(s), 38 queries , Gzip On.
