查看: 832|回复: 2
[求助] [求助]:旋转命令为什么不对呀
发表于 2005-7-18 09:42:31 | 显示全部楼层 |阅读模式
我的旋转命令不执行,请各位给看看
部分代码如下
(setq tyname (entget (entlast)))
(initget "y n")
  (setq pand (getkword "是否需要旋转[是(y) 否(n)]\n:"))
  (if (= pand "y")
   (progn
    (setq jiaod (getint "请输入旋转角度\n"))
    (setq tuyuan (nth 0 tyname))
    (command "rotate" tuyuan "" xuanz jiaod)
发表于 2005-7-18 11:13:31 | 显示全部楼层
(defun c:lll()
(setq tuyuan (car (entsel)))
(initget "y n")
(if (= pand "y")
(progn
(setq jiaod (getint "\n请输入旋转角度"))
(command "rotate" tuyuan "" pause jiaod )
 楼主| 发表于 2005-7-18 14:36:07 | 显示全部楼层
我想达到的效果是系统自动判断,也就是说我的图元是已经绘好的,并已定义为块
GMT+8, 2026-11-6 10:18 , Processed in 0.417961 second(s), 36 queries , Gzip On.
